CF frame in a home workstand - best way to clamp?
Old 07-01-16, 09:03 PM
the sci guy
bill nyecycles
the sci guy's Avatar
Quoted: 636 Post(s)
Liked 162 Times in 87 Posts
What's the best way to put your CF bike into your home workstand? I tried clamping it by the seat post, but there wasn't enough seatpost showing to clamp it. The seatpost is also CF, though.
I ended up clamping it lightly on the top tube - just enough to keep it from swinging, really. All I was doing was putting on some bottle cages and a saddle bag.
I hear horror stories about about clamping and crushing and whatnots - thanks for any info!
I have a Parktool PCS-10 stand.
Bike is a new Specialized Roubaix SL4 Sport.
Twitter@theSurlyBiker
Instagram@theSurlyBiker
the sci guy is offline
Old 07-01-16, 09:11 PM
TMonk
Not actually Tmonk
TMonk's Avatar
Bikes: road, track, mtb
Quoted: 1168 Post(s)
Liked 682 Times in 379 Posts
I would just extend the seatpost so you had enough purchase to clamp on the post. You can clamp a CF post, and it's for sure lower liability than clamping your frame.
"Your beauty is an aeroplane;
TMonk is offline
Likes For TMonk:
Old 07-01-16, 09:12 PM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2324 Post(s)
Liked 373 Times in 235 Posts
Either tape/mark the seatpost so you can draw it out to have enough clamping area....or get a stand that uses fork dropouts.
I really would not do what you're doing.
Marcus_Ti is offline
Old 07-01-16, 09:18 PM
FeltF2Tarmac
Woman make me faster
FeltF2Tarmac's Avatar
Bikes: 2014 Felt F2 Di2 2018 Tarmac Comp Disc
Quoted: 91 Post(s)
Liked 4 Times in 3 Posts
Top tube is bad, much cheaper to replace a crushed seatpost. I use a stand that clamps front fork and frame is supported by BB.
FeltF2Tarmac is offline
Likes For FeltF2Tarmac:
Old 07-01-16, 09:20 PM
rjones28
Mostly Harmless
rjones28's Avatar
Bikes: Have two wheels
Quoted: 8932 Post(s)
Liked 1,292 Times in 802 Posts
This.
rjones28 is offline
Old 07-01-16, 09:21 PM
mcours2006
mcours2006's Avatar
Bikes: Giant Rapid, Bianchi Advantage, Specialized Roubaix, 1985 Gardin Quatro, Norco Threshold, Raleigh Serengheti MTB
Quoted: 1928 Post(s)
Liked 259 Times in 148 Posts
I've read that you can buy a cheap alloy seatpost to use for this purpose. Just do do any sort of heavy duty wrenching work on it.
mcours2006 is offline
Old 07-01-16, 09:23 PM
TMonk
Not actually Tmonk
TMonk's Avatar
this is a good option too.
TMonk is offline
Old 07-01-16, 09:56 PM
the sci guy
bill nyecycles
Quoted: 636 Post(s)
Ah - good combo idea. I think I'll do that.
Likes For the sci guy:
Old 07-01-16, 10:25 PM
John00
Bikes: 2 TiSports and a Ho Ko E Koo
Quoted: 54 Post(s)
Liked 4 Times in 1 Post
I just clamp my bike lightly on the top tube, any heavy wrenching I would rather do with the bike on the floor.
John00 is offline
Old 07-01-16, 10:53 PM
jerbax18
i use "yakima top tube adapter". google it to see.
jerbax18 is offline
Old 07-01-16, 10:58 PM
TMonk
Not actually Tmonk
TMonk's Avatar
that probably works too.
Really, anything BUT routinely putting a tight clamp on a CF Frame should work just fine.
TMonk is offline
Old 07-01-16, 11:18 PM
rms13
Quoted: 276 Post(s)
I'd imagine it would be pretty hard to actually crush any tube on the frame with the force of a workstand clamp but I also clamp my bike by the seat post regardless of frame material
rms13 is offline
Old 07-02-16, 12:05 AM
Dean V
Quoted: 964 Post(s)
Liked 159 Times in 98 Posts
Originally Posted by john00 View Post
i just clamp my bike lightly on the top tube, any heavy wrenching i would rather do with the bike on the floor.
+1
Dean V is offline
Old 07-02-16, 05:48 AM
rpenmanparker
rpenmanparker's Avatar
Quoted: 6554 Post(s)
Liked 48 Times in 31 Posts
Perhaps a question of more interest is why your seat post has so little extension. Since most CF frames are compact design with sloping top tube, and you only need about 4 inches exposed for the clamp, that suggests the frame is considerably too large for you. Not a definitive conclusion, but that is my first guess.
Robert
No matter where I go, here I am...
rpenmanparker is offline
Old 07-02-16, 07:02 AM
mcours2006
mcours2006's Avatar
It could be that the clamp itself is quite long. My clamp is 4.25" long. The clampable length of my 54cm carbon bike is 4.5", so it's a pretty tight fit to begin with.
Old 07-02-16, 07:48 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3390 Post(s)
Liked 648 Times in 445 Posts
+1 I'd have to be surprised if carbon tubing is really too fragile to clamp in a bike stand that is made to service bikes. Wouldn't Park Tool for example be the first to have disclaimers? OTOH most ParkTool videos always show the seatpost being clamped. Are seatposts generally considered stronger tubing than the frames?
I've never thought about this much before. I've always clamped on the seat tube, and my bikes are Ti with CF seatpost, and Steel with alloy seatpost.
This attached snapshot from the PCS10 PT video makes me cringe a bit.. Maybe it's just me, but I'd would never consider clamping on the seatpost if working on a bike clamped at this angle.
Sy Reene is offline
Old 07-02-16, 08:00 AM
Marcus_Ti
Marcus_Ti's Avatar
Combine carelessness, with high mechanical advantage, add in some country boy biceps and you'd be amazed at what you can break. Had it happen at work yesterday.
Old 07-02-16, 08:03 AM
Marcus_Ti
Marcus_Ti's Avatar
Yes. Seat posts are designed to survive clamping forces, specifically the collar clamp. Frame tubes are designed to survive normal riding forces, not being crushed in a clamp maw
Old 07-02-16, 08:07 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Ok, but eg. look at this video (at approx. 1:40 into it). "Clamping forces" don't appear are really supposed to be all that great.
Sy Reene is offline
Old 07-02-16, 08:13 AM
TMonk
Not actually Tmonk
TMonk's Avatar
You're not going to crush a CF frame by clamping it hard, but you could induce some micro fractures that propagate over time.
TMonk is offline
Old 07-02-16, 08:34 AM
Willbird
Willbird's Avatar
Bikes: 2001 Trek Multitrack 7200, 2104 Fuji Sportif 1.5
Quoted: 18 Post(s)
I have a cheap amazon work stand, one of the $80 or so ones, I just cut down my clamp and the soft plastic end pieces to suit my Supersix Evo. I used a slide miter saw to cut the stuff, took all of ten minutes.
Bill
Willbird is offline
Old 07-02-16, 08:44 AM
gregf83
Quoted: 1109 Post(s)
Liked 214 Times in 130 Posts
Agree that seat posts are thicker and stronger than most tubes on a bike but seat post clamps are designed to provide uniform pressure on the seat post. Depending on the clamp you could end up with much higher pressure focussed on a small portion of the clamping surface.
gregf83 is offline
Old 07-02-16, 09:16 AM
Marcus_Ti
Marcus_Ti's Avatar
[u rl]https://youtu.be/MfRx0D3iPVc[/url]
Many bike major CF bike labels (all of them?) have clauses in warranties/warnings about not clamping the frame members in workstands. That might be a relic soon to pass-like warranty-voiding clauses about not using CF frames in stationary trainers...or it might not.
IMO, the extra 15 seconds of seatbag removal is worth it to use the post. Course I ride a Ti bike anyway
Old 07-02-16, 12:46 PM
on the path
Señor Blues
on the path's Avatar
Bikes: Cannondale CAAD 10, Breezer Venturi Custom Build, IRO Singlespeed
Quoted: 127 Post(s)
Liked 6 Times in 6 Posts
I don't clamp my CAAD 10 frame, especially the top tube. Don't want to do that, the top tube is very thin walled. I do, however, regularly clamp my CF seat post. If the seat post is designed to support 200+ lbs, I don't think it's really an issue to suspend an 18 lb bike from it. I try to keep the center of gravity of the suspended bike in line with the upright of the workstand, which is perpendicular to the floor in my case. I raise and lower the bike on the stand, depending on which part of the bike I'm working.
on the path is offline
Old 07-02-16, 01:43 PM
rpenmanparker
sci guy, when you are trying to clamp the seat post, and having trouble finding enough length for the clamp, are you aware you can safely clamp around the upper part of the seat tube where it extends above the top tube? Since the seat tube is supported by seat post inside it, you don't have to worry about crushing it there. On many bikes that will give you another inch or so of area to clamp onto.
Robert
Likes For rpenmanparker:
