Tightening crank bolt
we be rollin'
So I decided to do things on my own but do not have a torque wrench. In any case, when the bottom bracket was installed, I used as much force as I could (as per a youtube video I saw). On the (square taper) crank bolt, I didn't want to strip it so I used just enough force. I thought it was enough but one day one side started wobbling. So I tightened it again and it stayed for a while until it started creaking. I put a reasonable amount of force this time (I think).
Now, the question. Will this continue to occur after this happens once and do I have to ask a shop to use Locktite?
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
After the initial tightening of the crank bolt, did you re-tighten after 20 miles or so? You are supposed to.
Some instructions here:
https://www.renehersecycles.com/wp-c...2016_03web.pdf
Threadlocker can be used instead of grease on the threads.
Possibly you have ruined the crank arm by riding it loose.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
That bolt requires 300 to 400 inch-pounds of torque... which is a crap-ton if you're using an ordinary socket and ratchet wrench: https://www.parktool.com/blog/repair-help/
Once a crankarm works loose, the tapers where it mates to the spindle are distorted and there's no good way to fix them. Replacing the crankarm is the only correct repair.
I've been working on bikes for 40+ years. I've never seen a crank bolt strip, but I have seen lots of crankarms ruined by insufficient torque.
Jeff Wills
Jeff Wills
Quoted: 1188 Post(s)
Liked 1,154 Times
I had a new one on my ATS Speed Drive... the washers under the bolt heads dished while I was on tour (I discovered when I got home). Cranks kept coming loose, tighten up, come loose. Fitted properly originally, re-torqued etc etc. Pulled them off when I got home and discovered the washers were made of flattened out beer cans. Because they dished they distorted the crank taper , so it became a bit of a self reinforcing problem, since the distortion was stopping the taper from properly seating. Anyway, hopefully I've fixed the problem with a high tensile washer under the bolt head and a clean up inside the crank..
You can see where the dished washer distorted the top of the taper.
Old washer, really soft and small in OD. The new one fits neatly in the crank, so should spread the load away from the edges of the taper.
New washer is much thicker and is stronger steel as well.
Quoted: 4204 Post(s)
Liked 3,862 Times
AndrewRStewart
AndrewRStewart
Liked 2,568 Times
Quoted: 1034 Post(s)
Liked 1,290 Times
No it's not, it's only 33.3 foot pounds at 400 inch-pounds. That is not, "a crap-ton." That is very easy to exceed without a torque wrench, so it is not difficult to achieve with a socket and ratchet.
we be rollin'
I have two bike builds, one mountain bike and one flat-bar road bike that are fine. The mountain bike has Shimano Alivio square taper cranks (Niagaracycle) and Stronglight bottom bracket (got from xxcycle in France). The flat-bar road bike has Shimano Sora square taper cranks (Chainreactioncycles) and Shimano BB-UN55 bottom bracket (Niagaracycle). So, if I apply force sideways on both bikes, there's no play.
However, for my winter bike, I chose to install a Suntour bottom bracket and Suntour cranks. I have the feeling the cranks are on solid now but the spindle seems to have a little bit of play in it. Is this normal for a Suntour bottom bracket?
And oil the tapers of the spindle. Then the arms will grab the spindle harder and the arms will be much easier to remove.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I use anti-seize (mounting paste) on the axle, bolt threads and face of the bolt (part that pushes against the crank).
That way I'm certain that when tightening, it slid all the way it should and that proper preload was achieved.
Never had one come loose installing them that way and they are fairly easy to get off afterwards.
Grease to should do the job, though, for mounting stuff, I prefer the mounting paste.
Liked 1,154 Times
Ummm, because the washer was separate from the bolt and it dished so badly it damaged the crank? There's even a picture of one of the washers with the bolt head impression in it. Those bolts are needed because they are drilled for the shifting mechanism shaft. I could have drilled some shouldered bolts, but putting a high tensile washer on the already drilled bolt seemed easier.
Liked 2,568 Times
Liked 742 Times
Liked 1,154 Times
For these: Welcome to ATS
Not a bad jigger actually, so far after my first tour, apart from the #$%^ cranks coming loose constantly. Comes out about 200g heavier than having a double chainring and shifters. Mostly I run it in 1:1 with a Rohloff. When I'm coming down hills I bump it into high gear and go like hell, the Rohloff runs out of gears too soon for my liking otherwise. It makes a bit of racket in high gear, which will quieten down a bit hopefully once it's worn in.
Trek 500 Kid
Quoted: 2904 Post(s)
Liked 382 Times
When I tried that without a torque wrench I wound up having to shim 2 sides, 90 degrees apart, of each side of the internal crankset tapers with spark plug gap gage material matching in thickness on each individual side of the bike...
So torque wrenches in your workplace, like tire boots and chain breakers on rides, are very occasionally more than just handy.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Hard to be 100% certain from the blurry pic, but I think the taper on that crank arm is fornicated. Either from riding while loose or from overtightening. Find a replacement left crank and throw that one in the trash.
As for the washer, generally when you have a crank bolt with a flanged head like the one shown you do not use a washer.
