Freewheel removal tool too large?
Hello,
I have an older diamondback hybrid bike with a shimano freewheel. The rear rim got bent and I found a new one for fairly cheap. I had a park tools FR-5 freewheel removal tool I had never used. It said it works with shimano. It looks like it would work, but when I try to put the tool in the freewheel, it just seems like it is juuuuust sliiightly too large. Is there a smaller shimano tool? This is the only tool I have, but a bike shop said all I needed was the shimano key to remove it.
I tried to use the tool on another freewheel, but I might have damaged it a little trying to get it into the initial freewheel too aggressively, so I'm not sure if it would have fit.
Thanks
Thanks
Bikes: 70's Raleigh, 1974 Schwinn Le Tour, 2007 Giant Boulder SE, no longer have 1969 Schwinn Varsity, 1997 Giant Rincon
Take a look at Park Tool's website https://www.parktool.com/category/freewheel-cassette and see if there's another tool on this page that can help.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Looks like the FR-5 is a cassette lock ring tool. Do you have a cassette or a freewheel?
Never try to teach a pig to sing...
https://www.parktool.com/blog/repair-...ewheel-removal shows which interfaces tools are meant for. FR-5 is not for freewheels, it is for cassettes, and 23.4mm in diameter. Shimano freewheels are 23mm in diameter. I ran into the same problem and ended up using a Campy lockring/bb tool (22.8mm)
Quoted: 5782 Post(s)
Liked 2,578 Times
Park doesn't make the right tool. Older Shimano freewheels take a remover of significantly smaller diameter. The giveaway si looking straight don the axle. If the freewheel's spline diameter is as small or smaller than the axle locknut. That means the modern thin wall removers that fit between the axle and freewheel can't work, and you need to start by removing the locknut to access the freewheel, then using one of these Note the thick wall, and 10.5m ID which clears the axle but not the cones or locknuts.
BTW- these are had to find and can be pricey, so your best bet might be to bring the wheel in and let a shop or co-op remove the freewheel for you.
FB
Chain-L site
FB
Chain-L site
Guessing you need an FR-1. Have not run into any DBs (and I've dealt with a lot of older DBs) with the earlier freewheel style that takes the tool FB shows.
Liked 2,578 Times
Before spending more money the OP can get a definitive answer by rolling a sheet of paper into a tube just big enough to slide over the locknut and cone. If it slips into the freewheel than he probably needs an FR-1. OTOH- if there's no way it can slip into the F/W, then he needs the old tool.
FB
Chain-L site
FB
Chain-L site
Ah thank you everyone, that should solve my problem. I'm going to try the FR-1 or whatever cheap knockoff I come across. Luckly, I only spend $1.24 at a warehouse and dent store for the FR-5. I know the difference between and cassette and a freewheel and yet, I read right over like there is none.
Thanks again everyone, in my limited experience with the board, you are a very helpful community.
In case it isn't obvious, the proper way to use a vice with a freewheel remover too is to put the flats of the tool in the vice and spin the wheel which gives you lots of torque for the most stubborn freewheels. Don't try clamping down any part of the wheel.
unfortunately there are no immovable objects in my storage locker where I work on bikes, but I have a grip exerciser at home, so I will get some reps in by the time my new tool comes in the mail haha
I can go to a vice if needed though
is the chain tool just for extremely stubborn jobs or is there a separate purpose for that?
I'm not sure chainwhips really serve any practical purpose for these freewheels. They're needed for cassettes, and before cassettes were invented, they were used for fixed cogs.
My method is to jam the wheel against the wall and the floor perpendicular to both, install the freewheel tool (preferably held in place with the skewer but not tight), put a 12" crescent on it and give the end of the crescent a few whacks with a rubber mallet while holding the wheel tight against the wall/floor. Once you break it free, remove the skewer and spin it off. Hasn't failed me yet.
Mechanic/Tourist
Not everyone has one, but a 15" crescent wrench will give you the same amount of leverage as using the wheel in a vise.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Chain whips are also used to remove the individual cogs from a freewheel, e.g. to build a custom ratio, but you need to secure the freewheel in a freewheel vice.
Would it be bad to hit the wrench with hammer? When I've had to remove stubborn freewheels, I'd smack the end of the wrench with a deadblow mallet.
Liked 2,578 Times
If it works for you then it's OK. However the hub isn't dollied very rigidly, so you don't tend to get the full energy of the hammer working for you. I've always done best with a long hard pull.
FB
Chain-L site
FB
Chain-L site
elcraft
Actually, a 1" box end wrench or (better yet), a 1" six point socket with a breaker bar (for Park pullers) is less likely to slip off the puller tool when you try to loosen the freewheel. At least, if you aren't using the method where the tool is clamped into a bench vice, and the wheel is turned.
I've had good luck with the pipe (PVC) being of close diameter with an angle allowing some of the pipe to overlap the head of the tool.
Then again, I was using freely scrounged PVC broken at an irregular angle...
M.
M.
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
I'm going to bet on either a slightly bent axle or a gunked-up tool cavity are causing the problem.
Jeff Wills
Jeff Wills
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
This peaked my interest so went out to the garage. I have a Shimano TL-FW80 and just to eyeball it, it looked the same as a Park FR-5, but when I tried on a FW, the Park is a no-go while the TL-FW80 fit like a glove. BTW, that FW is probably 95-00 vintage. My earlier FWs had the 2 or 4 prong style.
scott s.
scott s.
Really Old Senior Member
A solidly mounted vise would be better than a 3rd hand IMO.
