Longest distance ridden on a flat tire
Quoted: 2730 Post(s)
Liked 488 Times
My back tube popped (tire is worn out so not going to try and replace tube) right as I was leaving work, I have to ride 6.5 miles home and then another 6.5 miles back to work before I can realistically fix it. I don’t think I have a narrow enough tire at home. It feels like a bucking bronco but it’s nothing unmanageable if I keep the speed down, luckily it’s just the back tire.
how long is the longest you’ve ridden on a flat tire? What is the likely place the wheel will get damaged from doing this? I’m like 2 miles in.
Liked 488 Times
Never mind walking after 5 miles
decided to get back on the bike, when I got home part of the rim looked like this
I bent it back close to normal with some pliers, gonna see if the new tire mounts.
Edit2: tire mounted fine, bike seems to be behaving itself
Liked 3,029 Times
four feet & 7 yards give or take 9". Rim damage happens.
-Oh Hey!
-Oh Hey!
Quoted: 3980 Post(s)
Liked 7,431 Times
Likes For tomato coupe:
velo-dilettante
Quoted: 1636 Post(s)
Liked 3,147 Times
11 flattish miles.
Likes For diphthong:
Likes For ScottCommutes:
Over the hill
Quoted: 1003 Post(s)
Liked 1,222 Times
For tubular tires, as long as the rider wanted/needed to.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 569 Post(s)
Liked 599 Times
On a perfect road you could easily go for miles without damaging the rim to the point of loss if you have not the light weight rims like I and other would use on centuries.. Maybe if you're on a very flat and smooth road you could keep going for miles. For a serious failure you can go longer but risk rim damage to the rim and frame from tire rub, etc.
Liked 7,431 Times
It was on a hooked rim. Thomas De Gendt and I are no fans of hookless.
Likes For Yan:
Expired Member
Quoted: 3713 Post(s)
Liked 5,576 Times
I'm not surprised that destroying a rim seemed a smarter option to OP than replacing a tube.
Likes For shelbyfv:
Should Be More Popular
Quoted: 22667 Post(s)
Liked 8,997 Times
Quoted: 9659 Post(s)
Liked 6,366 Times
Likes For Mojo31:
yeah, keeping a spare tube, or even a patch kit in a seat tube bag are basic necessities for any cyclist. So, when I once had a flat, I went, maybe a few feet before I got off and replaced the tube. I usually check the rear tire if it is too worn and needs to be replaced every so often. The rear especially, since it wears out first. The OP made it home, but should learn from this mishap
ignominious poltroon
Quoted: 2269 Post(s)
Liked 3,487 Times
You could always fill the tire with dead leaves, pine cones and grass.
Or use run-flat tire inserts.
Likes For Polaris OBark:
Liked 488 Times
The tire was toast, I was riding it until it failed, no sense in replacing a tube in a severely damaged tire. Don’t have space in my saddle bag for a tube or patch kit
Liked 7,431 Times
Klaatu..Verata..Necktie?
Quoted: 10498 Post(s)
Liked 12,026 Times
Liked 12,026 Times
"I did something I probably shouldn't have."
Yes, that's right. You shouldn't have.
"It's not so bad, and I didn't have a choice."
Yes, you did. Here are the ways you could have avoided it.
"Where's the harm?"
Right there in the picture you posted.
Lather, rinse, repeat.
"Where's the harm?"
Likes For genejockey:
Liked 6,366 Times
Waiting on Forrest Gump to chime in.
Liked 8,997 Times
Liked 12,026 Times
I don’t have space in my saddle bag because I carry a water pipe, lighters, big bag of weed, and often a concentrate in the saddlebag. I actually am thinking of getting a bigger bag because my favorite bubbler doesn’t fit in it.
i don’t regret riding on the flat, it beats walking 6.5 miles.
Liked 12,026 Times
I actually used about 5 of them the time I road the farthest I've ever ridden on a flat tire, which was about 40 yards. I ended up with 3 pairs of snakebites, and because my spare tube's valve stem was too short, I couldn't use it and had to patch the holed tube. That got me back to the car.
Quoted: 4286 Post(s)
Liked 1,377 Times
[QUOTE=LarrySellerz;23209164]decided to get back on the bike, when I got home part of the rim looked like this
This sort of damage is nearly guaranteed (especially given your weight).
Was the effort saved here worth the cost of a damaged rim?
It's stories like this that make your repeated claims at being an "expert" ridiculous.
This. This too makes your claims ridiculous.
Liked 12,026 Times
Also worth noting - the failure rate for patches you don't have with you is 100%.
