Soap your Schwalbe tires
Old 10-04-19, 11:09 AM
gus6464
Quoted: 353 Post(s)
Liked 92 Times in 67 Posts
I have installed 6 new Schwalbe tires in the past couple of weeks and noticed this with every single one of them. The bead on them is so stiff that most of the time they will not seat 100% right and have a tire wobble after installing. It was driving me nuts because I kept thinking that I had bent wheels. So before you install just get a soapy sponge and lather the crap out of them before you install. Haven't had to do that with Maxxis or WTB but Schwalbe loves the soap I guess.
gus6464 is offline
Old 10-04-19, 10:45 PM
bgdoyle
Bikes: '18 Giant Defy,'18 Trek FX3, Early '90s Giant Iguana
Quoted: 19 Post(s)
Made a difference seating the G-Ones today. Pretty snug on the rims and needs a bit of help to seat properly.
bgdoyle is offline
Old 10-05-19, 12:51 AM
gregf83
Quoted: 1186 Post(s)
Liked 289 Times in 177 Posts
I found extra air pressure did the job. Release some air once they’re seated.
gregf83 is offline
Likes For gregf83:
Old 10-05-19, 02:19 AM
rec
Bikes: allez, p21, raleigh sscx, rockhopper, sycip, centurion
Quoted: 11 Post(s)
Odd, I've had especially good experience with many dozens of Schwalbe tires over the past 14 years mounting true on mostly Velocity rims without any special treatment. Panaracers on the other hand... The easiest fix for a wobbly tire for me has been to slightly over inflate and letting the tire sit for a day or so.
Also, some rim makers and some tire manufacturers play better together than others.
rec is offline
Old 10-05-19, 07:56 AM
csrpenfab
Quoted: 76 Post(s)
Liked 99 Times in 57 Posts
Agreed. When I mounted the G-ones on Stan’s Grail rims for my Niner, they went on so smoothly. I hit them with the compressor and they seated perfectly and held air with no sealant. So much easier than the struggle I had with Bontrager TLR tires/rims on my other bike.
csrpenfab is offline
Old 10-05-19, 08:23 AM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
Liked 145 Times in 78 Posts
I have schwalbe pro ones on a set of Roval CL50 wheels and they went on and aired up the first try, same with my G-ones on my C38 wheels. But when I replaced one of my pro ones recently it was a pain to get them seated. But that same tire when pulled off and patched went on like the others, very easy.
Maybe they changed their spec for bead size recently? The relationship between the tire rubber compound, bead size, and the wheels they are going on can create problems for sure.
As for wobbly tires my trick is to take a quick easy ride with low air pressure, and then air them up to normal riding pressure. That will usually get the bead to seat evenly for me.
Bryan C. is offline
Old 10-05-19, 09:39 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
Usually if the bead doesnt seat correctly in one spot you can carefully pull on the tire sidewall in the opposite direction and it will slip into place. But yea I usually air up to 60psi and most tires seat completely on my stans and dtswiss rims
redlude97 is offline
Old 10-05-19, 05:01 PM
gus6464
Quoted: 353 Post(s)
All of them were on the new addix compound.
gus6464 is offline
Old 10-07-19, 10:38 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
Soap on the tires is good for anything tubless with a tight fit. Figured that one out about 15 years ago mountain biking. Certainly, the Germans have a super, super tight fit - Conti is even tighter than Schwalbe for higher pressure tires.
chas58 is offline
Old 10-31-19, 07:53 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
Schwalbe actually recommends using their mounting fluid (AKA "soap') for mounting their tires for good reaason. It makes that satisfying tubeless 'pop' happen at much lower pressures and helps assure a good even seat.
dwmckee is offline
Old 02-07-20, 06:04 PM
DOS
DOS's Avatar
Quoted: 253 Post(s)
Liked 69 Times in 56 Posts
Came across this thread after posting a question over on mechanics forum https://www.bikeforums.net/bicycle-m...uirements.html.
After ordering new addix compound pro ones, I came across Schwalbe guidance to only use their sealant.
Have you had any issues using other sealants with schwalbe tires with addix? The Schwalbe site says:
Instructions for the first assembly: Schwalbe Pro One and Schwalbe Pro One TT Tubeless Easy tires must be used with Doc Blue tire sealant. At least 30 ml, preferably 60 ml per tire. The tire must be run for at least 25 km directly after the sealent is added. If the instructions for the first assembly are ignored, the sealing of the tire cannot be guaranteed.
DOS is offline
Old 02-08-20, 05:18 PM
ericzamora
junior
ericzamora's Avatar
Bikes: 2020 Surly ECR / 2018 Norco Search XR steel gravel bike with GRX / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's)
Quoted: 72 Post(s)
Liked 12 Times in 11 Posts
My LBS had a heck of a time mounting my new Thunder Burts with the Addix compound on my rims a couple of months ago. They said it took 2-3 days, the third shop staffer was finally successful. This is a bike shop well-versed in mounting tubeless tires for both gravel and MTB bikes.
eric/fresno, ca.
ericzamora is offline
Old 02-09-20, 02:11 AM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 90 Times in 74 Posts
eric/fresno, ca.
Do you mean 2-3 days to seal them?
I just mounted an addix Rocket Ron and Thunderburt on a different wheelset. Beeswax on the bead. Blasted with CO2 cylinder. Bead seated straightaway.
After adding sealant I always let the wheel sit on its side for a day, then flip.
tangerineowl is offline
Old 02-11-20, 09:50 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
I have never heard of Bees Wax on a tire bead. I'd be afraid wax on the rubber would prevent the latex sealant from bonding to the tire surface to seal leaks... The Scwhalbe tire fluid is supposed to evaporate completely and leave no residue...
dwmckee is offline
Old 02-14-20, 06:30 AM
ckindt
Bikes: Trek Domane 2020 SLR7, 2016 4.3 Disc, 2017 Raleigh Stuntman
Quoted: 127 Post(s)
Liked 36 Times in 21 Posts
I always use electrician's wire pull lube for bicycle and motorcycle tires.
It's cheap, readily available, water-based and works well.
ckindt is offline
Old 02-14-20, 06:46 AM
Trevtassie
Quoted: 1188 Post(s)
Liked 1,154 Times in 640 Posts
Hair conditioner is a good lube for seating beads.
Trevtassie is offline
Old 02-14-20, 06:27 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
To each his own, but I try to stick with what the manufacturer recommends so if I have a problem they do not give me a hassle about warranty. As a matter of fact I had just such an issue with two Schwalbe tires that blew off the rim at pressure well below max. I verified I had correctly mounted the tires according to their instructions and they sent me two new tires, I'd can just imagine the diagnostic call to Schwalbe... "Well, first applied Caresse conditioner to the bead then inflated..."
dwmckee is offline
