Zeus Criterium Rear Derailleur, 13-36 teeth
Quoted: 243 Post(s)
Liked 172 Times
Selling from Cleveland, OH, 44111
Payment: PayPal or postal money order
Price: 60$ shipped
Now: 53$ shipped
Price: 60$ shipped
Now: 53$ shipped
1992 Torelli Nitro Express; 1972 Claud Butler.
Quoted: 5888 Post(s)
Liked 3,471 Times
Cool rear derailleur. Velobase has the capacity at a max cog size at 36 teeth but I'm skeptical of that claim given that this is an old school short cage rear derailleur:
https://velobase.com/ViewComponent.as...54548&Enum=108
But I could be wrong.
Likes For bikemig:
Quoted: 243 Post(s)
Liked 172 Times
Quoted: 237 Post(s)
Liked 83 Times
Campagnolo somehow went from 14-26 on the 1012 Gran Sport to 13-36 on the 1020 Record, which switched to an offset pulley cage, of which this derivative of. 36 seems like a stretch by all measures, but if there was any way for it to clear a 36, it was probably as a 1x so that the chain would pull the guide pulley away from the cogs in the highest gear. Back of the envelope calculation, if you add the length of the derailer hanger, the length of the derailer from pivot to pivot, and account for the cage with low chain wrap, that just barley puts you in the neighborhood of 36t. However, the 1020 Record increased knuckle to cage offset which would have helped it clear larger cogs because it would not have to swing in and up as much, a feature that seems to be missing on this.
my name is Jim
AFAIK the numbers on the back of this and other derailleurs don't mean what a lot of people think. I believe the '36' indicates the maximum "wrap" capacity of the derailleur. It is something like the max of this equation (chainring max + freewheel max) - (chainring min + freewheel min). No way this derailleur can handle a 36 tooth freewheel cog.
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
Quoted: 237 Post(s)
Liked 83 Times
"13 a 36 dientes" literally means "13 to 36 teeth" and I don't see why wrap capacity would be given as a range. There's no such thing as a minimum wrap capacity. I can't say for sure what it's referring to, but you find the similar stamping on Campy Rally and GTs except it's "13-36=36-54." They clearly have a higher wrap capacity, but I doubt it's 54, and it still leaves the 36 a mystery if it isn't what it appears to be. A ~45mm short cage is lucky to have ~25T of wrap. 36T wrap is more like what you could get from a ~75mm medium cage.
Quoted: 237 Post(s)
Liked 83 Times
NR was improved in pretty much every way. I think the knuckle to cage offset was even greater, and it had an offset pulley like Record. However, I think NR was always offered as a double unlike Record may have been offered as double or single, same as Gran Sport, which is why a 1x max cog rating might be relevant. It can't achieve that as a double because the cog clearance is gained only when there is minimal chain wrap (big-big).
In the high gear position, it cannot handle anything bigger than a 13 dientes.
In the low gear position, it cannot handle anything bigger than a 36 dientes. This is hard to believe but may be possible. My Nuovo Record works with 28T cogs, but 36,...? You'd have to try it or carefully measure at the geometry.
It might also imply 23 dientes chain wrap but that is not clear to me.
my name is Jim
In the low gear position, it cannot handle anything bigger than a 36 dientes. This is hard to believe but may be possible. My Nuovo Record works with 28T cogs, but 36,...? You'd gave to try it or carefully measure at the geometry.
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
Quoted: 1088 Post(s)
Liked 1,205 Times
The velobase entry that bikemig links to above has an exploded diagram, and it mentions that use of cogs from 13-36 teeth is possible. "Permite utilizar coronas desde 13 a 36 dientes."
[Image credit Velobase]
Randomhead
Liked 3,687 Times
I thought it was well established that derailleurs like that could only clear 28 teeth, but I would love for someone to try a 36 tooth cassette. I sold mine, so I can't do it
my name is Jim
Many have tried. In unmodified condition some can get a 28t and maybe a 30t it rare situations but a 36t just physically won't work (cog hits top jockey wheel).
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
Anyone tried the derailleur with a Road Link? Or any type of derailleur extension? My guess is the 13 -36 capacity is dependent on the length of the derailleur hanger.
Quoted: 556 Post(s)
Liked 132 Times
Blue Devil 63 is correct on this.
If I can find the documentation to support this, I will.
But life is short.
But life is short.
Quoted: 237 Post(s)
Liked 83 Times
If you can get it to clear a 36, then it will be on a 1x with the chain just the right length to maximize clearance in the biggest cog. How many of those people tried to set it up as a double? To get maximum clearance for the cog, it has to be in big-big, so it wouldn't produce maximum clearance in small-big on a double.
Quoted: 3464 Post(s)
Liked 2,827 Times
