Simplex Retrofriction shifters play
Quoted: 157 Post(s)
Liked 113 Times
I have zero experience with using retrofriciton shifters but I've heard that they are (one of) the best downtube friction shifters ever made.
So I've got a set of them in braze-on version. I cleaned and re-lubed them and mounted on a Simplex clamp I had. It needed retapping, of course.
Well, what I've noticed once the shifters were mounted on the clamp is considerable lateral play of the levers. It seems that the bushing inside of each shifter is not seated fully on the housing with the stop (is that how it's called?) so there is a gap between the housing and the lever. The clamp has nothing to do with the play, it fits perfectly.
Is that just supposed to be like that? Is that due to wear? The shifters are used but visually don't have much wear. No missing parts either...
I did not remove the bushing with the spring prior to cleaning. I am wondering if the bushings were not installed properly to begin with which does not allow the lever to be seated porperly which creates this annoying play.
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,274 Times
I am recalling that there is some difference between the clamp-on and braze-on versions of the retrofriction levers.
Might be a case of the bolt head or bolt tip bottoming too soon, before the lever assembly has been clamped fully onto the clamp bosses.
Perhaps then the clamp bosses need to be shortened slightly, or the bolts shortened slightly, to increase the clamping effect and get rid of the free-play?
Is the bolt securing the inside bushing from rotating(?), i.e. does the friction hold as it should?
Quoted: 157 Post(s)
Liked 113 Times
Using shorter bolts doesn't make a difference, I've already tried that. I haven't tried the shifters on the bike they are meant for yet but the bolts seem tight enough.
Quoted: 237 Post(s)
Liked 83 Times
I think it's part of the design of all these one-way friction shifters. The screw creates friction on the inner bushing, but does not meaningfully compress it, it just sets the friction in the friction direction. The lever is merely trapped between the screw and the base so without the clutch, it could move completely freely, which is why is moves easily the other direction. For some reason I remember seeing what looked like factory shims in some of these kinds of shifters, but they don't seem to show up in parts diagrams. You can play with soda can shims if don't have a place to buy various shim washers from, or you can hope it's less noticeable under cable tension.
Quoted: 157 Post(s)
Liked 113 Times
I still have to check the shifters under tension and see how they feel.
As I mentioned before, I have no experience with Retrofriction shifters, and no extra set to compare with.
Quoted: 1629 Post(s)
Liked 814 Times
I'm trying to remember, but I think there is a thin brass washer under the silver outside cap that acts as a shim to minimize lateral play. If that's missing.you might end up with the looseness you are describing.
The mounting bolt on those shifters look like replacements. The originals were slotted chrome screws.
one thing I do remember with my Retros was a replacement mounting bolt that is too long would bottom out and the levers would end up too loose on the pivots. I still remember cutting one of my replacement bolts because of this, to make them work right.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
Booyah Hubba-Hubba!!!
Quoted: 157 Post(s)
Liked 113 Times
I did replace the bolts because the original ones are a bit too short in my opinion to use with the clamp. So I am using M5 20mm replacement bolts.
Changing back to the original slotted bolts doesn't make a difference.
Quoted: 51 Post(s)
Liked 35 Times
I have two bikes with those shifters..one has a little play, and the other doesn't. While the play doesn't affect performance...I have also wondered why. Just thought they had alot wear!
Quoted: 157 Post(s)
Liked 113 Times
Thanks for your reply! At least, now I know that it's a common problem. The play is a bit annoying but I think I could live with that.
Liked 814 Times
One thing to watch out for is the thread pitch for the mounting bolts are different between the Retros sold with a clamp and ones that were sold as direct bolt ons to brazed on shifter bosses. The pivot barrels on the clamped on sets are also larger diameter, but strangely, you can actually still remove the levers from a clamped on sets on to brazed on bosses and they will still work as the mounting bolts will adequately do the job to center and retain them on to brazed on pivot bosses. I actually have this going on with one of my bikes.
I currently have Retros on 5 of my 9 rolling bikes and have 2 spare sets in my stash and they do have a slight bit of differences between them in terms of feel and fit tolerance, but they all work great otherwise.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
