Unsure what parts needed to attach saddle
I got a Specialized Allez Elite for free but it doesn't have a saddle or the clamps. I believe it is a 2006 model. What clamp will I need to purchase? Thanks ahead of time.
I'm not able to attach images yet so the pictures are located at the following (add the two lines together and visit the link):
photos.app.goo.gl/
UBMkJp2vA4wma4pF6
Randy
photos.app.goo.gl/
UBMkJp2vA4wma4pF6
Randy
Quoted: 1818 Post(s)
Liked 1,693 Times
You first have to determine the brand of the seatpost, Specialized didn't make it. Parts for it may no longer be available. You might well have to buy a complete new seatpost
Ugh, let's hope not. That would make this free bike an expensive one (relatively). Thanks for the response.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Pic assist:
Can you remove the post from the frame? Take it in to a bike co-op or shop and see if they have some used hardware that would match the post.
Yes, I just did that awhile ago and posted more pics to the album. Thanks for adding the pics. I found that it is a specialized post but can't read the model/type.
Quoted: 1814 Post(s)
Liked 923 Times
Unlikely that you can find those parts, but a new seatpost is easy to come by- under $20 on Amazon.
Try bike co-op, bike shop, or Craigslist. Should be 27.2 mm diameter, printed on the post near the bottom- the only critical dimension.
You need a saddle too, right?
I found one that looks very similar. It is at aroundthecycle DOT com/products/used-specialized-fact-carbon-fiber-seatpost-27-2x380mm-road-cx-gravel-bike-zertz
Now I just need to see about that clamp or if there is a universal one. I guess I could buy a carbon fiber one from Amazon, seems those are more like $30 or so. I'd really like to keep the original if possible though.
Quoted: 663 Post(s)
Liked 496 Times
Yep, new seat post and saddle and you're on your way. The remains of the existing seat post appears to have a setback of, by eye, of about 25mm. They come with various set back so you would want one that provides the best overall fit when installed. If the bike size is marginal, then the right setback may be relatively important. It may be 25 or 30 mm or no setback at all.
Quoted: 1324 Post(s)
Liked 927 Times
Is there any reason why the OP can't just use the upper clamp part and bolt/washer from another seatpost on the seatpost he has?
Cheers
Cheers
BTW, I am totally new to these type of bikes. I'm used to the old school BMX and simple 10 speeds. They all had the same clamp on style seats like from Walmart. Thanks!
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
According to Bicycle Blue book
Seatpost Specialized Pave II FACT carbon seatpost with Zertz insert, 27.2mm diameter
Liked 927 Times
Liked 923 Times
Seatposts are very interchangeable, but the clamps mechanisms are not.
Just Specialized has made at least three "fact carbon seatposts", all with different clamp set ups.
Even if the parts were found, they would probably cost more than a new post complete, not to mention the time spent looking.
Similar ones are on Ebay, but for ~ $50
Likes For woodcraft:
SE Wis
Liked 3,390 Times
Likes For Rajflyboy:
My thought, too. The seat post is not complete, and you don't normally buy separate pieces of a seat post. Just get a generic, inexpensive seatpost of the same style (not the bmx/department store style.) The diameter should be stamped somewhere on the bottom of the assembly.
Thanks for all of the responses and help on this.
