Looking for an estimate of my average power
Bikes: Cannondale SuperSix & CAAD9, Singlespeed Seven
Quoted: 5 Post(s)
I'm looking for a rough estimate for what my average power is and hoping that somebody here with a powertap and a similar build can help me out. I'm 5'10", 146lbs and riding solo on my usual training routes I average 21mph over 30 miles and 450ft of climbing and low wind. Can anybody help?
Training
Bikes: 2015 Focus Mares CX, 2008 Cannondale Supersix
It is unlikely you will get a reasonably accurate power number that way. Too many variables.
Renewed cyclist in VT
Bikes: serotta, cervelo TT, felt cross
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
why?
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
pan y agua
Quoted: 1460 Post(s)
Liked 736 Times
I like this one better:
https://www.noping.net/english/
But again the question is why? Any calculation you make is just not going to be accurate enough to be useful for training purposes.
If you have a power meter, power is obviously a very useful matrix.
If you don't have a power meter, a heart rate monitor, or perceived exertion are going to better guides than an extrapolation from a on line calculator, or a buddy's power meter.
You could get lost and die.
You could hit a tree and die.
VFL For Life
Bikes: Velo Volmobile
Quoted: 28730 Post(s)
Liked 1,874 Times
I would suggest you try and crank up your wattage more. Your power to weight ratio makes cyclists look bad. My girlfriend on her beach cruiser cranks out more power (and I know b/c I put a powertap on it)
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
Quoted: 5 Post(s)
The reason that I ask is becasue I race mtb but do a fair amount of training on my road bike. People frequently mention typical average power to weight ratios of sport, elite & expert riders (using average power output). I usually finish in the top 20% of my races in the sport class, so I was just wondering roughly where I currently stood powerwise to determine if my technique or power is my current limiting factor so I know where to focus my efforts for this season (since I have limited training time).
Je pose, donc je suis.
Anyway, if you can't get hold of a powertap, drive out to the mountains, find the steepest, knarliest hill you can find, and do the math. If it's steep enough (over 10% maybe?), the wind/rolling resistance is fairly minimal.
Bikes: Lynskey R240, 2013 CAAD10
Quoted: 50 Post(s)
The right power means absolutely nothing in the wrong context.
For all intents and purposes, power can be substituted by ANY (repeatable and consistent) arbitrary numeric representation on effort that removes nearly all outside variables from the equation (i.e. just the rider and machine efficiencies). Even in that case, it's only a tool to measure performance, structure training and measure improvements.
In simpler terms, riding without power is like working out at the gym without knowing the weights... the only reason to tout the weights (like 300 lb bench) is just to flex nuts.
It has no real meaning without reference.
pan y agua
Liked 736 Times
To start to do what you want, you'd ned to do a field test, and even then there are too many variables to get an accurate result.
Read Training and Racing with Power https://www.amazon.com/Training-Racin.../dp/1931382794, and if you want the make the most of limited training time you really should consider getting a power meter.
gurk700
Road Cycling
39
08-18-17 03:20 PM
RacerMike
Training & Nutrition
4
12-06-09 07:11 PM
