Do padded shorts have a break in period?
Quoted: 198 Post(s)
Liked 52 Times
well, do they?
louis garneau optimum 2 shorts are the first padded crotchal area shorts I have ever left the pad. 5'6" - 175 - purchased XL. wore them first time:
#1 . feels like a king double firm mattress jammed between my legs.
#B . moved around on the brooks b-17 less/ pedal power seemed more directed.
#3 . didn't have to stop & pee 3x in 25 miles
#4 . walking felt odd
#5 . no soreness at the end of the ride.
the sales lady on the phone indicated this was the thinnest pad shorts.
Q: does the crotch pad flatten & conform after a few rides? or is there a way to encourage it to do so?
Q: any suggestions for summer weight shorts?
thanks
thanks
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
well, do they?
thanks
thanks
well, do they?
thanks
thanks
https://www.boure.com/1100.html
Quoted: 3450 Post(s)
Liked 420 Times
If they are comfortable when your cycling then they did their job. You will always feel them when your off the bike though.
With use you will notice them less.
Likes For AnthonyG:
Quoted: 198 Post(s)
Liked 52 Times
thanx for the encouragement. while I never thought of going "full Grant" aka jeans & flip flops, I never, ever, figured i'd be leaning towards the "Fred".
I do use a black sharpie to go over logos, though. night riding won't ever be in my 68 year old deck of cards!
thanks again.
thanks again.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
XL, for 5’6” and 175lb? Wrong size, probably, no matter who sewed them.
Likes For AdkMtnMonster:
Pennylane Splitter
Bikes: Yes
Quoted: 1789 Post(s)
Liked 1,438 Times
I'm one of those folks who can't stand the shorts with thick pads. If you want something with a thinner pad look into Aerotech Designs. Some of their models have a thin one (look at their 'Wild Print' shorts line-up as an example). Not too bad to walk around in either.
Sizing: I've found I need to go up on sizing when buying bike shorts, regardless of the brand. I regularly wear XL street clothes, needed to get XXL bike shorts so they'd fit correctly (and comfortably).
Likes For skidder:
It often takes different lengths of time of for the shorts to break in different people's anatomy. Just keep riding, you'll adjust
Likes For Pratt:
This was my thought, too. I like my bike shorts to fit pretty tight in the crotch to hold everything in place. Too much room will lead to rubbing. Trust me, you don't want rubbing in that area!
Likes For tntyz:
Quoted: 4802 Post(s)
Liked 3,922 Times
Yeah. For some, years (I like chamoises that are just that. Very little padding. There are other, more critical fit issues for me so I don't always have the choice there.
Oh, that thick padding - it's to get us elders prepared for the day when we start needing diapers again.
Ben
Ben
Quoted: 822 Post(s)
Liked 1,960 Times
Chamois Pad break-in period? No
Derriere break-in period? Resounding yes!
Likes For CAT7RDR:
Another confirmation ...
I have long used lined bike shorts with a synthetic, but no padding per se & a leather Brooks saddle..
Might be the part you are sitting on that needs breaking in not the bike parts..
I have a pair of louis garneau liner shorts. While they are fine as far as wearing under bike shorts for comfort, the pads are horrible. These pads get pretty soaked even in mild weather let alone hot. My way cheaper padded shorts with 3d and 4d padding are cooler and dryer but the pads are pretty thick for walking around in. I like the 4d coolmax the best. I ride on a B17 Imperial and do not wear any padded shorts unless its very hot or the ride is over 15 - 20 miles.
Quoted: 1324 Post(s)
Liked 927 Times
I've worn a number of different makes of bicycling shorts. Without any doubt, Louis Garneau shorts had the thickest amount of padding it has ever been my displeasure to try and use. I'll never buy Louis Garneau shorts again. That ultra-thick padding caused way too much squirming as I rode the bicycle. It was like sitting on, or trying to sit on a mound of jelly. I got sore from those shorts in a very brief period of time.
Cheers
Cheers
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Bike pads by Dolomiti
https://dolomiti-pads.com/?lang=en
Elastic Interface
https://www.elasticinterface.com/cycling-pad/
Elastic Interface
Cheers
Cheers
IMHO if chamois is loose enough to develop folds, your shorts are too big. Or at least chamois is too big. Shorts with better fit are required either way. "Feels like a king double firm mattress jammed between my legs" - same thing.
Likes For Oso Polar:
Quoted: 198 Post(s)
Liked 52 Times
update: after about 100 miles (4 or 5 rides total), and three washings/ air dry, something is making them more comfortable. the pad has bent over the saddle rather than staying flat. my scranus is getting daily applications of working hands cream in two spots where the pad tends to, yes, fold my flab & pinch it a bit. this is not in the long direction, but where the front of the pad is separate from the cheeks part, and there's almost a hinge across the pad with no padding about 4 mm wide.
and yes, I do need to wriggle a bit on the saddle to make the pad jamb into place.
I still contend my pedaling has improved. I don't whiz as often after riding and my muscle aches are from better (stronger) pedaling and go away after an hour's rest. so i'm gonna stick it out and soon invest in another pair/ brand (summer weight for now) to have some comparison. if anyone wants to make a suggestion, I will be more than glad to entertain their brand (would like to keep under 100$ if possible).
thanks for the advices & validations.
Quoted: 6950 Post(s)
Liked 10,958 Times
No, they don’t.
Liked 3,922 Times
Edit: these are shorts,not bibs, correct? If so, the cheap way to improve fit a lot is to by $19 clip-on suspenders. Does wonders to prevent chamois folds. Also speeds up sitting back down and getting things right down there a lot. (They will outlast several pairs of shorts and make them all radically better fitting, The bib crowd will look at you funny, but its been working for me the past 45 years. Also bathroom stops and mid-ride clothing changes are far easier.
Ben
