Dura Ace RD-7402 Refurbish
Bikes: 1984 & 1990 Marinoni Specials - 1990 Bianchi Sika - 1993 Cannondale M800 - 1996 GT Zaskar - 1993 Kona Kilauea - 1987 Ritchey Ascent - 1996 Rocky Mountain Vertex - 2008 Kona Dogma - 1976 Schwinn Suburban - 1994 Kuwahara Makai
Quoted: 36 Post(s)
Liked 203 Times
I been into polishing old badly scuffed up parts for a couple years now, typically I get the parts for a good deal & I really like the results. In the 80s I leaned more the campy when it came to road components (still do) but always liked Shimano as well. I purchased a tri-color (600) to use on my road bike when I got tired of C Record friction (way back in the early nineties) and have come across a second tr-color since then, I'm using them both on some 90s mountain bikes. I always like Dura Ace but not as much as C Record. I saw an RD-7402 on Craigslist for $20 including a matching FD (don't really have a use for it) and jumped at it. I have 93' Kona Kilauea which has a smaller block freehub (23 max?) which is very light (around 23lbs) and thought it would be a great way to show off a polished old school Dura Ace RD (7 speed thumbies).
I'm surprised I never heard about the uniqueness of 7400 series Dura Ace rear shifting until now...
Funny how Shimano kept it Dura Ace incompatible with all other Shimano shifting for so long. Guess I could try one of those microshift 9 speed thumbshifters, or maybe just go friction! No biggie, it'll get used somehow.
Though I would share some of my handy work:
Before:
After:
Before:
After:
Likes For retrodude:
Man you do know how to polish...should've sent some of my stuff to you. I have three sets of DA 7400, 7402 is 8 speed and you can easily use 9 speed downtube shifters such as these with it, just not having 9th gear. link HERE
If you are after a brifter set, they can be a tad expensive though, but sometimes they pop up in Europe for less than 100$
Good luck
Good luck
Quoted: 3464 Post(s)
Liked 2,831 Times
The reworked mechanism appears to have the black cartouche depressed and filled with paint around the text- the originals I have have that black area equal to a silk screened region...
how was that area controlled?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
Quoted: 36 Post(s)
Liked 203 Times
I wasn't sure how it would react so I applied a super sticky rubber tape over it during the chemical anodization removal process to ensure it was not in contact. For the sanding I simply used green painters tape cut precisely to cover it.
Definitely worth protecting!
Quoted: 36 Post(s)
Liked 203 Times
Quoted: 36 Post(s)
Liked 203 Times
Good luck
Good luck
Takes a lot of patience, thanks for the tips, still undecided where to make use if it, maybe just set it next the the wives silver (LOL)?
Quoted: 1608 Post(s)
Liked 2,216 Times
Likes For SJX426:
Quoted: 36 Post(s)
Liked 203 Times
Liked 2,216 Times
retrodude Thanks! I have a couple of old parts that are not anodized that I hit with Mothers every several years. All my bikes are kept in climate controlled environment when not in use. It works.
Quoted: 1163 Post(s)
Liked 442 Times
A lot of very ugly clear anodized silver, road rashed parts could be rescued if more folks would embark on some of your procedures!
señor miembro
Liked 6,488 Times
Interesting choice as a deanodizing agent that I haven't heard before. Looking at Zep's huge catalogue of products, I wonder if that's the best choice. Do you mix it with hot water?
SE Wis
Quoted: 2747 Post(s)
Liked 3,399 Times
I had to order the Simichrome on-line as I could not find it for sale in Canada. I have used this for derailleurs, cranks and seatposts with good results. There will be a concern that the aluminum is unprotected afterward which is valid. My bikes are kept indoors and kept very clean so it has not been an issue for me even a couple of years after the fact
A coat of auto wax helps keep the shine
Disraeli Gears
Impressive. The $64,000 question is: was the derailleur disassembled to do this (removing the pivot pins)? If so, how, and how was reassembly done? If not, then how to keep abrasives out of the works (the pivoting parts that wear against each other)?
Quoted: 36 Post(s)
Liked 203 Times
I just use it full concentrated form (no diluting), I had dabbled in removing anodization years ago with drano and always worried it was too corrosive, I feel this works just as well at full strength and appears to do no harm, I always try to remove all rubber or plastic parts
Quoted: 36 Post(s)
Liked 203 Times
The derailleur was disassembled to it's smallest parts excluding pivot pins (I would be scared to try). Basically the three parts to go into the Zep were inner & outer pulley cages and the main body with logo protected (just to be safe). I make sure to rinse everything thoroughly in hot water after a couple minutes in the Zep bath.
Quoted: 36 Post(s)
Liked 203 Times
Quoted: 1324 Post(s)
Liked 927 Times
Beautiful!
I have a pair of Shimano Exage clipless pedals that I was able to remove most of the grey anodizing from by carefully scraping it with a very sharp knife. I then use various files to remove the mold seam lines and to give the pedals a better contour. I then used various grits of wet/dry paper and polishing cloth by hand to give the pedals a high lustre polish.
This was the result.
Would the stuff you used to strip the anodizing harm the springs inside these pedals or the rsin or hard plastic end piece that pivots?
Thanks and cheers
Thanks and cheers
Quoted: 36 Post(s)
Liked 203 Times
Beautiful!
Thanks and cheers
Thanks and cheers
Dumb question: Why do you need to remove the anodized coating to polish it? The anodization is a protective coating, right? But I'm guessing it's hard and resists being rubbed smooth, I guess?
What is the drawback to removing that coating, it's more prone to scratching? I assume rust isn't an issue since it's aluminum.
Sorry I'm jumping in so late to this discussion, I'm just so impressed how you can bring an old part back to life like that.
Quoted: 36 Post(s)
Liked 203 Times
