Loud click from crank area after new parts install
Old 09-01-20, 11:03 PM
speedyspaghetti
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 67 Post(s)
Liked 19 Times in 13 Posts
Hey everyone -
So today I finally got around to throwing on some upgraded parts on my bike. I installed the following:
FSA Aluminum Clinchers (forgot the exact model)
Ultegra 6600 FD
Ultegra FC-6750 Double Crankset
Ultegra 6600 2x10 Shifters
Ultegra BBR60 Bottom Bracket
I had the bike shop torque down (well he didn't use a torque wrench but its definitely tight) the bottom bracket for me as I don't have the stupid 41mm tool and all the bike shops around here don't sell it, but other than that I did the install myself. Everything when on smoothly, but when I took it out for a test ride I noticed a real annoying, loud click that comes from the crank/bb area when pedaling moderately hard. It seems to consistently happen when I'm past the top of the pedal stroke and I start pushing down (if that makes sense). It almost feels like the chain skips a tooth or something but I don't think it is actually skipping. I can feel the "click" through my feet. It does it on both the big and little chainring.
The rear derailleur (Ultegra 6600) was already on the bike (I had a triple crankset with the same cassette). I've tried the following to no avail:
- Tried my old rear wheel
- Tried a different cassette
- Tried different pedals
- Uninstalled and re-installed the crankset
- Removed and re-installed chainring bolts
- Tried to apply lateral force to crankset with the chain off to look for play - nothing obvious
I'm kind of at a loss here and very frustrated as I spent multiple hours today trying to figure this out and now I can't ride until I get it fixed. I also can't take the BB off since I don't have the tool (I have ordered it but will take a few days)
All of the parts I installed today were bought used but seemed to be in good condition. Chainrings have a few worn down teeth but nothing horrible. BB was also used but looked like-new when I got it.
Any help is greatly appreciated.
Crappy photos - but in case anyone wants a visual: Album
speedyspaghetti is offline
Old 09-02-20, 01:16 PM
shoota
shoota's Avatar
Quoted: 1871 Post(s)
Liked 689 Times in 467 Posts
Originally Posted by speedyspaghetti
Hey
Check the inside of the crank arms for cracking. I had something similar happen when a crack started forming along the inside crankarm.
2019 Salsa Warbird
shoota is online now
Old 09-02-20, 01:27 PM
sfrider
Asleep at the bars
sfrider's Avatar
Quoted: 234 Post(s)
Liked 203 Times in 135 Posts
You don't mention it so I will: check the chain for wear.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
sfrider is offline
Likes For sfrider:
Old 09-02-20, 04:19 PM
BoraxKid
Quoted: 325 Post(s)
Liked 109 Times in 72 Posts
It almost sounds like the bottom bracket bearings were not installed correctly. Maybe that "mechanic" at the local shop cross-threaded the bottom bracket and it's slightly mis-aligned now?
BoraxKid is offline
Old 09-02-20, 04:58 PM
Pizzaiolo Americano
Pizzaiolo Americano
Bikes: 2021 Trek Domane, Bianchi Intenso, Specialized Epic Evo, Surly Ice Cream Truck, Some other stuff
Quoted: 287 Post(s)
Liked 140 Times in 69 Posts
Front derailleur cage hitting the inside of the crank? It can happen if it is toed out too much or the limit screw is not set right. Sounds ridiculous but I got a brand new bike from the shop with the front limit screw that badly adjusted...
Pizzaiolo Americano is offline
Likes For Pizzaiolo Americano:
Old 09-02-20, 08:39 PM
speedyspaghetti
Quoted: 67 Post(s)
BINGO - not sure why or how, but a new chain fixed it. Maybe I damaged the old quick link when I took it off? Or maybe the old chain had worn to the original crankset? Either way - fixed now. Thanks everyone.
Old 09-03-20, 07:49 AM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
the clicking occurs on both chainrings. The FD isn’t going to snag the crank on the small ring
Litespud is offline
Old 09-03-20, 09:28 AM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 359 Post(s)
Liked 179 Times in 111 Posts
That can't happen.
popeye is offline
Old 09-03-20, 09:29 AM
popeye
Quoted: 359 Post(s)
Get a chain checker or a ruler or you will be skipping on a new chain.
popeye is offline
Old 09-03-20, 10:53 AM
BoraxKid
Quoted: 325 Post(s)
Glad you found the issue. It's always best to replace the chain if you are changing to new cogs/cassette.
BoraxKid is offline
Old 09-03-20, 10:55 AM
BoraxKid
Quoted: 325 Post(s)
Originally Posted by popeye
That can't happen.
You don't think it's possible for a threaded part to be cross-threaded?
BoraxKid is offline
Old 09-03-20, 11:32 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times in 560 Posts
Hope that was actually your issue. As a bike mechanic my first thought was the crank was hitting the tail of the front derailleur cable. Most newer mechanics don't bend it far enough out of the way and then it seems to always become a mystery sound.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Likes For Psimet2001:
Old 09-03-20, 05:25 PM
popeye
Quoted: 359 Post(s)
I think that no matter how ham fisted you are a BB would be hopelesly jammed in 2 revolutions.
popeye is offline
Old 09-03-20, 05:28 PM
BoraxKid
Quoted: 325 Post(s)
IME, I've seen people cross-thread lots of parts and just say "dang, why are these threads so tight?" while they reach for a longer cheater bar. Stupid people will find a way to screw up anything; never underestimate them.
BoraxKid is offline
Old 09-03-20, 05:30 PM
popeye
Quoted: 359 Post(s)
The fact that it was just one repeatable click no mater what gear made it sound like something other than the chain.
popeye is offline
Old 09-03-20, 05:31 PM
popeye
Quoted: 359 Post(s)
Could you humor us and measure the old chain? Skipping is usually caused by a new chain on a worn cassette not the other way around.
popeye is offline
Old 09-03-20, 08:15 PM
speedyspaghetti
Quoted: 67 Post(s)
Yeah - I'll need to buy a chain checker but I can do that.
