Show us your NON Brooks LEATHER saddles
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
The one I ride the most. Ideale 90 frame sporting RHM's #10 skin.
The second most used non-Brooks. A Wrights W3N.
An early '60s Schwinn Approved known as a Sprint, which I laced and is quite comfortable.
An Ideale 45 and a Middlemore.
Bob
Bob
Like Scottryder, my '75 Fuji S-10S still has it's original Fujita Belt saddle (sorry, no close-up pic)
Pasorbobnlnh, I want that yellow seat bag on the maroon bike in the background. Cannondale 'Toot'. I've been looking for over three years for another to replace mine that got sold at my parent's garage sale...
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Regarding leather saddle frames, I noticed that there are generally two types of the spring-less frames out there, one with the frame rails raised up at the nose so you don't see much of it, and one with frame rails staying low till almost the tension adjuster assembly. First I thought that the ones with the lowered frame rails at the nose allowed for more adjustment to push the saddle back. but I noticed that on my Brooks Imperial (and I suspect other similar non-Brooks saddles), that it doesn't really do that as the rails curve inwards almost immediately after the center of the saddle, so not much rearward adjustment if any is gained with the dropped rails, I think. I suspect that the other saddles that have this type of rails might do the same(?).......so why even have the rails low at the nose then?? Is it just to accommodate a bit more of sag at the nose for the leather cover as I suspect might be the case if the saddle is used in a more upright position on a bike (sort of more of a "hammock" effect) ????
Chombi
Chombi
Quoted: 150 Post(s)
Liked 34 Times
Quoted: 556 Post(s)
Liked 132 Times
That's pretty cool. And strange! Is it really as thin as it looks, Scott? Can we see a shot of the rails? Or ....rail?
Photographer
Quoted: 105 Post(s)
Liked 98 Times
Scott
ClassicFuji.posthaven.com.archive
IG @scottryder.surf.cycle
IG @scottryder.fine.art
Photographer
Quoted: 105 Post(s)
Liked 98 Times
Don't need no stinkin' padded shorts! oh wait, yes, good idea! I'll do a shot tomorrow with the other Fujita for width comparison ...
Scott
Scott
I would not say that this is the world's most perfect saddle, but if I could obtain two or three more I'd rush to get them. Lepper Voyager — built on Reynolds 531 tubing. It is light for a leather saddle — 265 grams!. Adjustment is not easy and I popped a rivet through the frame and replaced it with a screw and washer. And yes ... I'd still like another two copies.
EDIT: I should add that there was, and may still be, a newer version of this Dutch saddle. In my opinion, it should have been given another name as it does not resemble this model (above) in any way except the shape. The new model has an extra layer of leather that is bonded on the underside and an entirely different frame.
The original Voyager from the late 90's - early 2000's was flawed and was altered while in production. The altered series is reported to have a frame that was redesigned by Alex Moulten whereby the hollow rails were given a torsional aspect that was missing in the original. I have one of the later specimens. Despite it's apparent imperfections, I like it. I do not think that I would be interested in the newer version unless I could examine one in person.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
Quoted: 821 Post(s)
Liked 255 Times
They were talking about this one on our ride yesterday.
A Rivet "Independence" that looks interesting.
https://rivetcycleworks.com/
Photographer
Quoted: 105 Post(s)
Liked 98 Times
Width comparison between the Fujita Professional Super track and the Fujita Professional Super road.
And yes, it has hurt written all over it.
Scott
Scott
Quoted: 556 Post(s)
Liked 132 Times
multimodal commuter
Liked 574 Times
It appears to have flaps underneath, presumably riveted together as on a Brooks Swallow, so it won't need to be laced.
Quoted: 821 Post(s)
Liked 255 Times
So does this one, although I am not a fan of the "plastic" either.
Maybe I'll branch out on a planned build for next year and try one of these.
They aren't that much more than the Swifts I use.
Photographer
Quoted: 105 Post(s)
Liked 98 Times
Unfortunately, yes. Which means I have to ride and experience the pleasure of it's narrow width.
Scott
Scott
multimodal commuter
Liked 574 Times
The original Voyager from the late 90's - early 2000's was flawed and was altered while in production....
The interesting thing about non-Brooks saddles is the different frames. Brooks hasn't changed their design in over fifty years, which is nice if you appreciate continuity, but frankly it is not a great design. Others are better. I particularly liked the Selle anatomica saddle I worked on. It had a much better nose design.
multimodal commuter
Liked 574 Times
