If I want to be more upright on a hybrid, Is buying the size down an ok idea?
Bikes: Trek Emonda S6
Quoted: 73 Post(s)
Looking at a Cannondale Quick 1, I am 511 and the M sizing recommendation is 55 to 510. So I am really close to the end range of the M and about in the middle of the L size 59 to 62.
another factor is I can get the M right now as it is in stock at the LBS and the L I would have to wait for a minimum July.
https://www.cannondale.com/en-us/bik.../quick/quick-1
here is geometry comparison
https://geometrygeeks.bike/compare/c...quick-2020-lg/
Quoted: 4461 Post(s)
Liked 4,928 Times
For sitting more upright you would be better off with the L (24 mm higher stack).
Likes For PeteHski:
Quoted: 6241 Post(s)
Liked 4,840 Times
What the geometry doesn't show you is the saddle height. Go with the larger frame if the reach doesn't get too much for you. Better yet find a bike in your size with a higher stack if you can.
Your saddle will be pretty much the same height from the BB on either bike.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
The wrong idea as to what defines "a more upright position" paired with impatience to buy whatever is available?
Go on pinkbike and find yourself a size L
Quoted: 1084 Post(s)
Liked 688 Times
I'm not looking at specs on that specific bike, but a larger size will usually have a longer top tube as well, meaning a longer reach so it could be more difficult to get an upright position. Chances are you can get the riding position you want on either size, with the right choice of stem and handlebars.
Quoted: 73 Post(s)
Thanks for the replies. I am going to get to take it for a ride on the trainer at the LBS (middle of winter here) and Ill make a decision as to whether I want to wait or not to try the Large.
Quoted: 73 Post(s)
Liked 4,928 Times
The problem I can foresee here is that if you need the higher stack for a more upright position and end up fitting an extra 25 mm of stem spacers on the smaller frame, then that will make the effective frame reach even shorter (by another 8 mm or so) due to the head angle. Given that the larger frame is more matched to your height, the smaller frame might feel very cramped with the front raised. You could compensate with a longer stem on the smaller frame or a shorter one on the larger frame if it feels too long for you. But since you are in the middle of the recommended height range for the larger frame, chances are it will be more in the ballpark to start off with. Also if you increase the stack height on the large frame with stem spacers, then you also shorten the reach. IME if you are looking for a more upright riding position, then a larger frame size is easier to achieve this. Conversely, if looking for a more aggressive position people tend to size down and fit a longer stem.
Liked 4,840 Times
Best not to get so attached to a particular model of bike that you ignore other bikes that might give you the position you want without having to change up stuff. Road bikes look the epitome of cycling style and are aesthetically pleasing for many of us. But they aren't the only style of bike made to ride on the road.
If you truly want an upright sitting position then get a cruiser. Trek and a few others make bikes that are more the true cruiser geometry that I remember from the previous century. Cruisers will allow you a comfortable upright position for a leisurely ride.
OM boy
Bikes: a bunch
Quoted: 532 Post(s)
Liked 653 Times
you obviously already have a 'bike'. which you think is creating discomfort.
unless you have a wider tire bike and are extremely comfortable in winter conditions; why are you focused on another bike right now?
nothing good will come from it.
now's a good time to focus on self-improvement.
you have months ahead to create improvement.
you have ice skating and XC skiing in your area, if those are things of interest, they're highly compatible. They'll also highlight things which are body focused.
Bike size? is an internet guess from any of us.
Ride On
Yuri
Ride On
Yuri
Likes For cyclezen:
I have undersized bike. At first I tried to make up for it by buying a longer stem. To my surprise, the longer stem made it less comfortable.
Then I bought shorter stem and ironically, the shorter stem is more comfortable on the already undersized bike.
I'm not recommending you do the same but shorter reach does make you sit more upright, at least from the lower back region.
The only bad of short reach is that the ride feels a bit unstable. You'll get used to it but if you're riding with a longer reach, it could feel dangerously unstable.
Liked 4,840 Times
First and most important thing on any bike is saddle height for the rider. That will be virtually the same on all bikes of that geometry. But saddle height is not something that is typically given in geometry data for a bike. What will also change when taking the bike with shorter reach is stack height which also determines your handlebar height.
On the comparison the OP gave, the smaller frame will give only a 1/4" (8 mm) less reach, but almost a full inch lower handlebars (24 mm) .
Of course you can always raise the handlebars, but many times that get quickly to the point that it looks odd or even is unsafe. Since the OP is buying a bike, they shouldn't get stuck on a bike that doesn't give them the fit they prefer in any size. They should find the one that does.
Too many people looking for a bike I think get distracted by the appeal of a certain look and then get the wrong geometry for them and try to make it work with extenders and risers and such.
Drip, Drip.
Liked 193 Times
Iride01
First would be foot placement, second would be saddle height.
Foot placement affects saddle height, which can consequently throw off your entire fit.
Liked 4,840 Times
Foot placement isn't going to be a factor IMO for two bikes a size or two apart.
If we are going to get into that, then we need to be building a custom fit bike for the OP.
You have a point. Ofc, if the reach have very little change, then it would be better to have the right size. He can still get shorter stem if he wants anyway.
Liked 4,928 Times
Iride01
Drip, Drip.
Liked 193 Times
Both of these are going to be the same, regardless of M or L frame. The L might have 2.5 mm longer cranks, which might affect saddle height by a fraction not really worth mentioning. The smaller frame will have considerably lower bars relative to the saddle and a bit less reach. Not really what you would want for a more upright position.
Generally speaking, foot placement SHOULD involve the balls of each of your feet being centered over the pedal spindle, with your feet being placed close inwards (for better q factor.) This is something which is to be considered regardless of what type of bike you are riding, or what size it is. That doesn't mean that you will achieve the correct foot placement with every bike you ride. it doesn't mean there is anything wrong with adapting your fit as well as riding style to slightly different foot placement... so long as you are not pedaling with your heel or toes.
Ill say it again, a radically different foot placement from what would be considered the norm will throw off your saddle positioning and consequently, the rest of your fit.
Liked 4,928 Times
Looking between different sizes of a bike which fails to offer the sort of riding position which the OP is looking for, in the first place, would be a more realistic starting point (regarding what you wouldn't want for a more upright riding position)
Edit: Also your "fixed" ideas about foot placement are mostly useless.
I may get hardtail MTB eventually for better comfort in washboarded gravel roads but will promptly convert it to dropbar. Will definitely go for the size with small enough reach to take into account using dropbar.
Drip, Drip.
Liked 193 Times
As I get older, I'm finding myself looking for more upright riding position. But can't seem to find any comfort in anything but a dropbar.
The Kona Libre looks to be biased toward drop bar comfort with the higher stack and relatively short overall reach.
Likes For Moisture:
Quoted: 557 Post(s)
Liked 419 Times
A solution is to buy the M right now, and buy the L again later. Your LBS will love it.
Go to a shop and sit on the bikes they have in those sizes and see for yourself. The stem length can often be changed to alter the seat to handlebar distance to have it closer or further away. It is the seat tube top to the top of the head tube, the effective top tube length, that is important and it can vary by more than in inch.
If I feel that I am bunched up on a frame when sitting on the seat and having my hands on the brake handles then the frame is too small for me. I know that in seconds when on the bike with the height of the seat adjusted for my leg length.
Quoted: 427 Post(s)
Liked 703 Times
I've found the sizing on various sites are generalized recommendations. They may or may not work for you. I was considering a hybrid a while back and was interested in a Trek FX 3. The site said a medium would fit me. At that time (pre-covid), the LBS had them in stock. Went to the store to try them out. The medium was too small (felt like a toy under me), while the large was a very good fit. If you're lucky enough to ride both sizes, please do. It's why I prefer to ride a bike I might buy. Less trouble than ordering one and finding the size recommendation was not for me. Unfortunately, it may not be an option in today's market.
Quoted: 2501 Post(s)
Liked 745 Times
The M to L thing is a zero sum. The L has a higher stack, it also has a longer reach! If you want to sit up more you MUST get a stem extender and call it good. They are cheap, easily installed and I'm sorry, I had to skip a whole bunch of posts that were confusing the issue to a very high degree (swidt?).
https://www.flickr.com/photos/430814.../shares/x79caQ
