Recommend a punch?
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
Recommend a punch?
I've been trying my hand at servicing freewheels -- a couple of unused ones to begin with. I bought some small drift style punches, and with the 3/32" inch one I successfully got a Falcon fw apart and back together, but I bent it trying to loosen the plate on a Shimano one. I may buy a Park SPA-2 spanner also, but I believe the plate on that Shimano would be on too tight for a spanner. Anyone have a punch that works really well for this? Could you tell me the brand and model, or at least length and shape of the punch? 3/32" looks to be about the diameter of most of the holes.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Are you trying to move it in the right direction? It should be a left hand thread, so clockwise to loosen.
Quoted: 5788 Post(s)
Liked 2,581 Times
I opened and serviced my first and last freewheel sometime close to 1968. BITD - Freewheels had shims you could remove to correct for play as they wore. But when all is said and done, taking a freewheel apart for service is a waste of time and effort. You can achieve the same results by soaking and flushing with solvent, then draining, oiling and draining again.
You end up with a good as new freewheel, or at least good as it's going to get, with near zero effort, and no risk of damaged pr lost internal part.
FB
Chain-L site
FB
Chain-L site
You can try craftsman tools at Sears . If their punch bend or break their warranty will cover it .
Really Old Senior Member
Grind down a punch to suit.
Quoted: 50 Post(s)
Liked 18 Times
Thanks for the responses. I've been flushing and oiling freewheels, but I don't think they sound like they're holding on to the oil -- they still sound dry. The Falcon I took apart had been flushed and oiled, and oil would still drain out of it -- but when I got it apart, there was very little lube on the bearings. It's really not a hard job once the plate is off. Just mangled the puny punch I was using in the process. Probably grinding down a sturdier punch is the way I'll have to go.
Liked 2,581 Times
Thanks for the responses. I've been flushing and oiling freewheels, but I don't think they sound like they're holding on to the oil -- they still sound dry. The Falcon I took apart had been flushed and oiled, and oil would still drain out of it -- but when I got it apart, there was very little lube on the bearings......
As such, very little lubrication is needed, just a slight film to prevent galling and/or rust from water entry. If it seems that oil isn't being retained, it's possible that you're oiling before all the solvent has evaporated, or you're using too thin an oil.
Thicker oils, like auto gear oil or 40wt motor oil will soak in if you're patient. If you're not so patient, these thick oils can be thinned with some solvent, which will evaporate leaving the oil. Or you can thin a soluble grease, and that does a nice job of leaving a film of grease in place, which doesn't violate the "do not grease rule".
FWIW - I use Chain-L in freewheels, but that's mainly because I have a nearly infinite supply. Phil's Tenacious is similar, and both have a "glue" to help the film adhere.
FB
Chain-L site
FB
Chain-L site
Quoted: 50 Post(s)
Liked 18 Times
Possibly my problem is my solvent of choice -- kerosene -- because I have a bunch of it I need to use up. It evaporates pretty readily when in the open (spilled on the floor), but possibly stayed in the fw and diluted the 30wt oil I drizzled in there. Anyway, the only freewheels I was attempting this on are pretty much cast offs. I know it's pretty much a waste of time. But reading this forum it seems there are folks who service them quite a bit, and 5 speed with 34 tooth don't seem to be made any more, so I have one of those I thought I'd try if these others went okay --I do have a use for that one. So far, the one I have gotten apart seems okay.
I reccomend safety glasses when you start banging on a Punch.. and don't use a carpenters hammer..
Liked 2,581 Times
Kerosene is a bit of a problem as a solvent because as you point out, it takes eons to dry completely. You can rinse with OMS, naphtha or gasoline (outdoors please) all of which will dry. Or you can put the freewheel in a warm place, like sitting on a blacktop driveway on a sunny day. You can also tie a string through it and spin dry it to get all but the last bit, which will then dry much faster.
FB
Chain-L site
FB
Chain-L site
Old fart
Liked 3,400 Times
After oiling your freewheel, work a little heavy grease into the gap between the inner and outer bodies on both the inside and outside faces of the freewheel. This will help hold the oil in place.
After flushing with solvent of your choice, blow some air into it, that will help drive it out and dry things faster.
I working in a machine shop long ago, I used to soak my freewheels in a pot of tricloro-something-or-other. That removed any and all traces of grease and oil, off the part and my skin. Then I'd drip heavy oils into it, giving it a day or two to flow through and out the bottom. But that is really way too much work for too little benifit.
Quoted: 50 Post(s)
Liked 18 Times
Flushing out the solvent with air, and working grease in, both sound like ideas I will have to try. Thanks for more good suggestions.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
It takes more mental energy to describe that than I expend while flushing the thing.
Quoted: 1324 Post(s)
Liked 927 Times
PARK makes a lightweight pin-spanner specifically for the freewheel lockrings. It's fantastic andd saves deforming the recess you're hitting with a punch.
Cheers
Cheers
I have an old freewheel grease adapter. It threads into the freewheel and has a gasket/washer. Once tight, you connect to a grease gun zerk and pump it full. I use a very light grease. Works great.
My favorite solvent is a carburetor cleaner. Avoid any of the ones that start with methanol in the ingredients. They are only slightly better than kerosene.
Back in the old days parts were made for disassembly and service. Not any more. Feel free to mess with the old stuff, but just toss the new ones away and install a replacement.
-SP
MudPie
Bicycle Mechanics
8
12-29-11 07:31 PM
caintuck
Classic & Vintage
5
07-26-10 03:18 PM
