Is a spare bike necessary?
Old 06-15-20, 12:12 PM
  #101
altondavis2
Quoted: 15 Post(s)
Liked 11 Times in 10 Posts
Don't skimp on the spare bike. In Michigan the 'good' biking weather is only 5 months long.
A spare bike makes sense if you have a breakdown. Repair time could take a day to a week.
The again, sometimes its just fun to change bikes.
altondavis2 is offline
Old 06-15-20, 12:13 PM
  #102
mrMike88
Bikes: Spalding Blade Vintage 12-speed
Interesting timing for this question: I just messed up my front wheel and had to take it to the LBS for replacement and tuneup. I don't know what sort of time frame they could do it in "normal" times but it'll be a long while before I get it back - they're slammed. So I just have one other one - a three-speed old thing that I hadn't touched in over a year. I filled the tires and replaced the brake shoes and I've ridden it near-daily since then. (I'm not a "serious" biker in that I only ride 6-16 miles per trip, but I'm pretty consistent - it's my main form of exercise and recreation). I had actually been planning to sell it.
So - the answer to the question is, of course, "no", in that you don't "need" a spare bike unless it's your only vehicle. But, yeah, I'm glad I hung on to this one; it's amazing how few bikes are available, used or new, and this works fine for now.
mrMike88 is offline
Old 06-15-20, 12:18 PM
  #103
sacr
Quoted: 7 Post(s)
Messed up
Originally Posted by DreamRider85 View Post
I have a road bike and mountain bike. I think I’m good. But what if you were to go on a bike trip and the day before your bike gets messed up. Would it be good to have a spare or is it not necessary?
High possibility this is just a windup? Messed up, so you’ve crashed your bike and it needs major work? Could you hire a bike for that essential trip you need to go on? It’s just a flat tire? Surely there are threads here on how to fix a flat?
thing I love about being a commuter cyclist is a bicycle is a very basic mechanical piece of kit, its not randomly going to not work, like an electrical gremlin in a car. In 35 years of commuting the worst I’ve had is a snapped rear derailleur cable where I “Limped” home in fixie mode. Even this was avoidable as I felt the cable was need of replacement for months, but knew it wasn’t going to be lights out if it broke.
a spare bike? If you have the money or space, we’ll go for it, me_ have neither so will “survive” with just one bike
sacr is offline
Old 06-15-20, 12:26 PM
  #104
lonnieji
I don't sell my old bikes and use them as either a backup or put them on the trainer so I don't have to put bikes on then take them off.
lonnieji is offline
Old 06-15-20, 12:31 PM
  #105
tg16
tg16's Avatar
Bikes: Bianchi Impulso, Raleigh Record Ace, Kestrel 200SCI, Jamis Xenith T2
Quoted: 11 Post(s)
If you’re looking for an enabler, I’m you’re source. Go buy the bike and as you’re leaving the store, get some new kit, pedals, saddle, other varied and sundry gear and top it off with the chain lube of your choice.
If you’re wife has a problem, call me and I’ll help you formulate some pretty good arguments in support of how you did it for her.
tg16 is offline
Old 06-15-20, 12:48 PM
  #106
run50
Bikes: Seven Elium SLX, Spot Mountain bike, Surly LHT touring bike, Co-Motion Pangea touring bike,Trek 5500, Argon gravel bike, 1955 Schwinn
Liked 3 Times in 2 Posts
Some of us don't even have to lube chains because we ride Gates belt drive (my touring bike).
Just spray it with water to clean.
run50 is offline
Old 06-15-20, 02:08 PM
  #107
glennwegner
Originally Posted by Camilo View Post
I'll just speak of road bikes, but I do have one mountain bike.
For road bikes, the minimum is one of each of the four major materials, steel, aluminum, carbon fiber and titanium. I would consider this basic, and none are really "spares" because, for example, if the titanium bike has a flat tire, you don't have another titanium bike to grab and go. And, at least as far as steel goes, you'd probably need to have a contemporary steel with modern parts, and a vintage steel with - at the very least - period correct parts, if not as-built. And a back up for both of those too. So 12.
You forgot bamboo - apparently it's been a while since you visited the handbuilt bicycle show. So 14.
glennwegner is offline
Old 06-15-20, 03:19 PM
  #108
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 489 Post(s)
Liked 222 Times in 166 Posts
I can fix anything in apart from repairing a frame before a ride tomorrow, although having to build a wheel would be annoying.
I have spare wheels to avoid that.
Being partial to 2001-2006 Campagnolo Record apart from 2010 Ultrashift levers, I also have enough spares to build up frameset except for the cockpit parts
Drew Eckhardt is offline
Old 06-15-20, 03:52 PM
  #109
BadGrandma
Bikes: Surly Cross, Franklin tandem, Culprit Jr., BMX racer
Quoted: 24 Post(s)
Liked 25 Times in 13 Posts
Originally Posted by bblair View Post
N+1=S-1
Solve for that number where marital bliss equals bicycling nirvana. But I am not sure which side of the equation a tandem belongs. Depends on the day, I guess.
If you sell the tandem, you have to get a divorce.
BadGrandma is offline
Old 06-15-20, 04:42 PM
  #110
alikitch
Bikes: Colnago Master, Tommasini Techno, De Rosa Primato, XB3 Kvant, Cinelli Vigorello track, Merida team Superlight
Quoted: 8 Post(s)
Liked 4 Times in 3 Posts
Originally Posted by caloso View Post
At a minimum, you should have a road bike, MTB, CX/gravel bike, TT bike, and utility/beater bike.
The utility/beater bike is a conundrum. I got my first utility/beater bike so I could save my good bike for appropriate occasions. But as a bike to use every day the beater has to be fun to ride and at least as good as the ‘good’ bike or it wouldn’t get used. However I then realised I needed a utility/beater so my utility/beater could be saved for good, but again the beater had to be fun to ride, but again I realised I needed another beater/utility bike. Anyway heading towards 10 utility/beater bikes now with no end in sight, not sure how to deal with this problem?
alikitch is offline
Likes For alikitch:
Old 06-16-20, 08:09 AM
  #111
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 61 Post(s)
Liked 39 Times in 27 Posts
My old Trek has new wheels, a whole new drivetrain, new seatpost and seat. Stem too. Only thing remaining is the frame, which was repainted after a repair. So, is it the same bike, or a new bike?
Discuss.
bblair is offline
Old 06-16-20, 08:56 AM
  #112
PdalPowr
PdalPowr's Avatar
Bikes: Norco hybrid
Quoted: 287 Post(s)
Liked 26 Times in 19 Posts
I will answer that with a question.
Is more than one spare bike necessary? 😀
PdalPowr is offline
Old 06-16-20, 08:13 PM
  #113
bikejrff
bikejrff's Avatar
Bikes: Lynskey R260, Salsa Colossal Ti, Litespeed T5, Lynskey Peloton, Bianchi Vigorelli, C'Dale SuperSix, CAAD 10, Giant FastRoad CoMax 1, C-Dale Quick 1
Quoted: 45 Post(s)
Liked 5 Times in 5 Posts
I don't have any "spare" bikes, just bikes.
bikejrff is offline
Old 06-16-20, 09:38 PM
  #114
PdalPowr
PdalPowr's Avatar
Bikes: Norco hybrid
Quoted: 287 Post(s)
But wouldn't you spare one if your buddy needed a ride?😀
Ergo you have a spare bike.😉
PdalPowr is offline
Old 06-17-20, 02:51 AM
  #115
Ironfish653
Bikes: 1997 Cannondale, 1976 Bridgestone, 1998 Softride
Quoted: 438 Post(s)
Liked 149 Times in 101 Posts
Without some sort of limit, doesn't the value of n essentially become...infinity?
Yes, because you always need another bike.
Ironfish653 is offline
Old 06-17-20, 05:02 AM
  #116
SFC Rod
Hand-cyclist
Bikes: Invacare Top End Force 2 Hand-Cycle, Invacare Top End Eliminator Racing Chair
If you can...why not?
A spare bike is nice...if you already got all the classifications of bikes you need. Some of us have no options but to be happy with what we got, especially when you ride a hand-cycle. Your basic Top End Force (the Schwinn of hand-cycles) is $6K, and I couldn't even afford that. Mine was donated by Project Hero, otherwise I'd have no bike at all.
Since I live in SE Arizona, I'd like a MTB, but the mountain bike version of a hand-cycle starts at $12K.
SFC Rod is offline
Old 06-20-20, 12:11 AM
  #117
Camilo
Quoted: 309 Post(s)
Liked 92 Times in 58 Posts
I said "minimum" not "optimum" ;-)
Camilo is offline
Old 06-20-20, 12:43 AM
  #118
phtomita
Bikes: '86 Nishiki Tri-A, '84 Centurion PT15, '87 Centurion IM Master
Quoted: 196 Post(s)
Liked 60 Times in 47 Posts
Two road bikes works great for me. One commuter and another for weekend. Commuter with fenders is very good for a ride on the wet too
Then, got an e-bike so my wife could keep a good speed when riding together. She also has one hybrid Trek.
And another hybrid Trek.
And, ended up getting another road bike that I borrowed to a friend on the new normal (spare ?).
phtomita is online now
