fixed/fixed -> fixed/single?
Bikes: Bianchi Pista
Let me start off by saying that I am relatively new to the whole cycling world. I am currently in the process of putting together a new wheel set for my Bianchi Pista (Japanese spec) and have a question regarding hubs. I have been looking at some second-hand Dura-Ace track hubs that were used for racing. They are noted as being fixed/fixed hubs. Am I correct in assuming that if the the rear hub is threaded on both sides that I could replace one side with a freewheel to convert it to a flip-flop hub? Thanks for your help.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 45 Post(s)
Liked 42 Times
Yup. Not a problem at all. jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Quoted: 1572 Post(s)
Liked 642 Times
I'm too lazy to go downstairs to check for sure, but doesn't a fixed hub have 2 stage threading? Clockwise for the cog and counter clockwise for the lockring?
I'm thinking a fixed/fixed hub would have 2 stage threading on both sides and a fixed/freewheel has only clockwise threading on one side.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
Quoted: 5703 Post(s)
Liked 2,432 Times
+1, no problem with a freewheel on a fixed hub. The reverse thread is smaller and doesn't present a problem.
The reverse isn't true, you shouldn't expect locktite or anything else to properly secure a fixed sprocket onto a hub without the reverse threaded lockring.
FB
Chain-L site
FB
Chain-L site
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
Liked 2,432 Times
That's the problem with bonding the sprockets on. You get the worst of two worlds.
You can't rely on to stay on when you need them to, and you can't count on to come off when you want them to.
Try using heat to weaken the bond. If you have a propane torch slowly heat the sprocket while keeping steady torque on it with a chain whip. Be carefull the melting temp of aluminum is fairly low and unlike steel, it goes very suddenly from solid to liquid.
If you expect to do work with heat a lot you might consider using temperature sticks to help you manage the process.
FB
Chain-L site
FB
Chain-L site
cab horn
Quoted: 42 Post(s)
Liked 25 Times
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
