For the love of English 3 speeds...
Quoted: 331 Post(s)
Liked 331 Times
Avoid curves
When mounting the shifter (especially 4 speed) don't fasten the shifter on a curved section of the handlebars, choose a straight section. A curved base buckles the receiver plates and the pawls inside trigger mech can jump off their cams.
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Nicely preserved 23" men's Sports on the Boston-area CL for a reasonable price:
https://boston.craigslist.org/nos/bi...104499339.html
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 428 Times
Flying Pigeon!
Here's a nice example for sale here in Toronto.
Seller is asking a reasonable $75.00.
Quoted: 453 Post(s)
Liked 441 Times
I don't think I've ever mounted the shifter on a straight portion of the bar, putting it a bit further away from the grip is a better location for ease of use. I generally tighten the screw down just enough so the shifter won't rotate and I've never had an issue with the shifter bending/failing. I've been riding/working on Sturmey equipped bikes since 1985 or so.
ambulatory senior
Quoted: 1949 Post(s)
Liked 3,605 Times
Liked 428 Times
Oddball
Here's a Raleigh Winkie....
An adult(?) trike with a lever front brake.
It has an odd pressed metal front fork as well.
Likes For gster:
Liked 428 Times
Liked 428 Times
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
Phyllo-buster
Quoted: 2286 Post(s)
Liked 2,024 Times
+1. A '64 TCW MKIII I'd wager.
Quoted: 778 Post(s)
Liked 1,704 Times
This was pretty common on 60's and 70's 3 speeds to have a rear coaster and a front hand brake. This was done to save cost and simplify things for causal riding all one needed to do was oil the rear hub through the port and chain occasionally and air up the tires and they were good for several thousand miles of riding which is more than most 3 speeds ever got.
Liked 428 Times
A Selection Of Current Toronto Kijiji Listings
CCM 3 Speed
A German 3 speed @ $250.00. I can't tell the brand.
A nice Ladies Raleigh 3 speed.
Men's Coffee 3 speed.
CCM 3 Speed
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 359 Post(s)
Liked 445 Times
So I'm going to eventually build up my '54 Armstrong 531 road frame with a Williams chainset/crankset to drive my FW hub, which is built into a 700c wheel. Does anyone know what spindle length the English Club style bikes use? Then I can find the correct cup-and-cone bottom bracket and spindle for the Williams crank and chainline with my hub gear. This will be a long-term project to collect some period parts for a late winter build.
1954ish Armstrong Consort straight-gauge 531 frame and fork
Quoted: 3780 Post(s)
Liked 6,528 Times
Quoted: 359 Post(s)
Liked 445 Times
Thanks Neal. Now, I'm in search of what to search for with this machine. Seems like GB Coureur brakes, handlebars, and stems go for $$ these days, but I'd like to outfit it with period brakes, bar, and stem. I may go '70s on brake levers because the small bits in '50s GB levers are very old and likely brittle now.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
Quoted: 925 Post(s)
Liked 2,809 Times
I've come to terms with the fact that the 1950 Superbe is too small for me. It is the 23" size, but I'm 6'2" or 6'3"ish and mostly legs. The seatpost is too short, and the handlebar stem is way too short. I can't ride it anymore unless I can find a longer post and a longer stem. I'd really like to enjoy this bike and put it in the regular ride and (one day...) commute rotation without sore knees. Anybody got the scoop on longer stem / seatposts that fit these bikes?
Thanks all.
Thanks all.
Likes For ascherer:
Quoted: 1299 Post(s)
Liked 103 Times
Likes For BigChief:
Quoted: 925 Post(s)
Liked 2,809 Times
Thanks, BigChief . It's a workhorse, my commuter and grocery runner for the last 5 years. Save for a few tweaks it's mostly stock. I'm about to give it to my son, as I've built my International as a townie with a Sturmey 8-speed and upright bars. Same spirit and brand, lighter and taller. I've thought of posting it here but I respect the focus of this thread, the best 3-speed resource on the planet!
Quoted: 453 Post(s)
Liked 441 Times
I also "summited" Manhattan on my folder, as someone that spent a lot of time BMXing I did I ride it to the top of the rock,
Likes For jackbombay:
Liked 2,445 Times
Stem: Nitto Technomic. These are legendarily the tall post of choice and are available in several reaches as well. Clamp diameter is slightly larger than that of the stock Raleigh bar so you might have to shim the bar or use a more modern bar to fit the clamp. Thing is, the stock stems are actually pretty tall and only a Technomic gives you much more height and only the Technomic will give a choice of reach.
You can also try an inexpensive stem riser to boost the stock stem higher but some folks consider these to be unsightly.
Stem riser
I have used the combo of a quill adapter with a riser threadless stem to get the rise and reach I wanted on a different bike. There are lots of possibilities but the traditional look might suffer. Good luck!
Likes For thumpism:
Quoted: 359 Post(s)
Liked 445 Times
Quoted: 925 Post(s)
Liked 2,809 Times
That's very cool ascherer . How do you find the angle of the saddle while reaching the grips comfortably? I think your bar stem is set a bit higher than mine. I might raise it a touch. I need to find some foam for my B66 to shore up the leather. It's caved in a bunch.
Likes For ascherer:
