Garmin Edge 830 Help (mostly navigation/route related)
Quoted: 192 Post(s)
Liked 11 Times
So I switched to the Edge 830 this season after using the Wahoo Elemnt Bolt last year and hating it. Moving to the Garmin was supposed to make life (especially navigation) easier. I ran into a few issues today...
1) I intentionally went off course in an area I know well and for about 10 minutes the only re-routing the Garmin did to take me back to my destination was suggest constant U-turns, even when distance to destination was definitely shorter the route I was taking.
2) the bigger announce was when mid-ride which I was following a saved course (Strava route) and wanted to turn around and come home using the Garmin navigation. I could find out how to cancel the route while leaving my ride stats active, but it seemed there was no way to enter a new route within the same ride. I ended up with two seperate ride files as a result.
3) trying to get back to the home screen in the middle of the ride...to see if I could enter a new navigation point...the screen kept saying it was locked, but wouldn't let me unlock it (it seems) without ending my ride entirely.
Anyone have any fixes to these issues?
Quoted: 4284 Post(s)
Liked 1,377 Times
If you want follow the course (a requirement for certain events), a U turn is the best/shortest way to do that.
The 1030+ gives you options when you go off-course far enough.
Do you have "recalculation" enabled?
There's a tiny stop sign in the lower left of the map screen that will stop navigation.
You can also just select some other navigation and you'll be asked if you want to stop the current navigation.
Unlock the screen: press and hold the power button.
Likes For njkayaker:
Quoted: 3285 Post(s)
Liked 2,122 Times
Older Garmins suck at re-routing when off course. Best option is to view the map to determine a route back to the course line (in pink). Then figure it out yourself. The 1030 Plus as better off course options.
If you desire to return to start, you stop and cancel the existing navigation, then and while in the navigation section, do a “Return to Start”. It’ll give you 2 options, one is a route generated by the device and a hit/miss as to viability for cycling, the other is to follow the existing track that’s been recorded to date. That method works I’ve used it.
Lock/unlock screen is in the manual.
Likes For Doomrider74:
I had a hard decision to choose the Garmin 830 or the Roam. I went with the Garmin 830 because it did rerouting. It has saved me at least 5 times on group rides. My biggest complaint with the 830 is that it is very difficult to see the screen with sunglasses on when it's a sunny day. What good is a GPS unit if you can't see it.
Likes For Sojodave:
don't try this at home.
Quoted: 985 Post(s)
Liked 520 Times
Slightly off topic: Merging two separate recordings to make one longer ride:
I googled this for another rider that mistakenly stopped his recording mid-ride (by pressing buttons without reading the messages...)
There's some websites where you upload multiple recordings, and it returns a single longer ride. I've never tried it. It's easy to find with google search.
Recalc when off the route:
The route recalc was terrible on my old 705. So I turned it off on my 1030. It is funny how it still says "make a u-turn" when I can see that I'll get back on the route just a few hundred feet ahead.
I'll have to try out the off course recalc options and see if it's useful and effective.
New route with keeping the recording running:
Any of these options will keep the route recording going. You can switch or cancel routes, and your recording will continue.
I use the "Elevation Chart" screen a lot. It's set to show the next 1.5 miles elevations in a chart format, so I can see what kind of climbing and descending is coming. This data is imported with the route .fit file. So navigating "return to start--most direct route", or "navigate to a selected point" won't have upcoming elevations. Instead, it shows the most recent portion of your ride--not too helpful.
1. You can press the red "stop sign with an X" button on the map to stop following a route. Now you can "just ride" without a route. Perfect if the group switches plans mid-ride and someone else is deciding the route (for a bridge out, weather, etc.) You'll still see your mileage, etc, increasing as you ride, as expected.
It asks, "Stop current course?" X-don't stop, checkmark-stop navigating. I've pressed this accidentally a few times, so I just hit the X so I keep navigating.
This red button isn't too obvious. I tried finding the "stop course" function in the Navigation menu, but it's not there, of course.
2. you can get back to the home screen, click Navigate, and load a route the same as you do when you start a ride. For instance, changing from a 100 mile to a 65 mile route during an event ride. (It even asks if you want to navigate to the start -- no.)
Tap the data screen or tap the map away from the control buttons on the map. You should see the "House icon" for the home page. From there, click Navigation or click your bike symbol at the top to get back to the riding screens.
3. Return to start, via the outbound route. I'm guessing this would take you all the way back around a loop route that was 3/4 finished. Probably not what you want in that case. It would be useful if that outbound route is reasonably direct from where you are.
4. Return to start, most direct route. I've tested this a few times, and it usually picks a reasonable route, avoiding highways, for instance. If you get far off this calculated route, it won't recalc the route. But you can go to Navigate again, and pick it again, for a new recalculation from your current location. It's useful. I get turn by turn messages, and distance to the destination. Nice.
You can start riding before it gets to "loading...100%", but that slows down the load. It'll reach 100% much faster if you stop the bike to let it calculate and load the route.
5. Navigate to a selected point. This is slow to set up, but should work. You can pick a town, pick a neighborhood in a larger city, or pull up a list of businesses in a category, sorted by distance (convenience store, restaurant, etc). Even put in a street address--but that's very tedious.
It can navigate to a "Saved Location", but I don't have any.
Locked screen
While locked, it's interesting that you can (sometimes? always?) swipe to see the other screens, but can't change any of them, or press to get back to home, either.
Just a quick press of the power button locks or unlocks. I never use this, unless I do it accidentally.
Powering off
A 3-second press of the power button won't actually turn it off while it's recording. It shows a "Activity in progress" message, tells you to stop the timer before sleep or power off, and only allows the "return to previous screen" arrow press. Good.
Pausing and resuming a ride recording
This isn't too obvious. I expected to use the top left power button -- but that's not it.
Press the start/stop button at the bottom, same as starting or finishing a ride. You'll see the usual "Save ride" checkmark button -- but don't press any screen button, either X-cancel or checkmark-save ride. There's a reminder at the top of the screen: "To resume ride, press the bottom start/stop button" The physical button, not a screen icon.
This works pretty well, since the screen isn't the usual riding screens, so it's harder to forget to start it going when you are done with your break.
Locked screen
Powering off
Likes For rm -rf:
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
Riding a route while training?
I have been searching the net and haven't found a solution, but it appears this thread is along a similar track. I am trying to see if there is a way on the 830 to do a training ride while using navigation. I ride on farming roads and want to be sure I take all the correct turns. I tried selecting route from the review training screen before setting off, but that just started navigation and my training didn't count towards my Garmin plan. Hopefully there is a simple way of doing this that I have just overlooked. Thanks for any help.
Neil
Neil
Liked 2,122 Times
Neil
Neil
Steve, thanks for the reply though I fear I didn't describe my question properly. I do import routes that I have made using Ride with GPS and have no problems doing that and loading them. The question I'm trying to answer is about loading a Garmin workout and then using a route for navigation at the same time.
Depending on which workout I'm doing I might just have a simple timer, or for intervals it might show a slider depicting what power I should be aiming for. I would like to be able to load a workout so I get those sliders and such, but then also load a route to get guidance as I rocket down Illinois farm roads. This also allows Garmin to list the workout as complete instead of just an additional ride. Hopefully this clarifies things.
I won't make a snarky comment about how well Google works.
No snarky comment needed as in my first post I mentioned that I had been searching. Apparently I just hadn't found the right combination of words to get that result. What I did find was a link to this forum and guess what? I found the result. I took a look at the link and will try it on my next ride.
