Another cable-related question
Old 04-19-05, 09:48 AM
shane45
Ouch!!!
What do you guys prefer for cables - plain stainless, or Teflon coated inner wires?
shane45 is offline
Old 04-19-05, 09:49 AM
powers2b
Listen to me
powers2b's Avatar
search the forum
powers2b is offline
Old 04-19-05, 11:14 AM
Rev.Chuck
The Red Lantern
Rev.Chuck's Avatar
plain stainless. cheaper, and they work fine.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Rev.Chuck is offline
Old 04-19-05, 10:34 PM
Raiyn
I drink your MILKSHAKE
Raiyn's Avatar
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Generic Teflon like Nervs or Alligator cables. No need for XTR as all you're paying for at that point is a name. I run tefon cables exclusivly on my bikes
Raiyn is offline
Old 04-20-05, 03:28 AM
Brian
Brian's Avatar
Bikes: 8 bikes - one for each day of the week!
Is tefon a brand? Never heard of it.
Brian is offline
Old 02-18-19, 07:30 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 597 Post(s)
Stainless, die-drawn inners, lined outers. The coefficient of friction of Teflon/Teflon and Teflon/steel are almost identical so I do not see the performance gain from coating the inner.
And the coated inners can sometimes be a bear to clamp securely; I generally end up scrapingwire-wheeling the coating off where I clamp them. PITA.
dsbrantjr is offline
Old 02-18-19, 08:10 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1111 Post(s)
Liked 3 Times in 3 Posts
+100. I stopped buying Teflon coated inner cables after problems with them slipping at the clamp bolts no matter how hard I tightened them. I had to scrape off the coating at the clamp to make them hold their adjustment. No benefit, more costly and a nuisance downside
HillRider is offline
Old 02-18-19, 08:38 AM
ljsense
ljsense's Avatar
Quoted: 110 Post(s)
That's a good question. I just went through a cable search and trial building up my dream bike, which has internal routing and some difficult bends.
Among stainless cables, there's a range of quality -- some are really smooth, others not as much. One thing to notice, among brake cables, is if it has both the road and mountain ends, leaving you to clip one. A cut cable doesn't route as easily as one with a soldered end. I think the SRAM cables are good examples of plain stainless. From what I can tell, they make one cable for all their upper end road sets, and it works.
Among the coated, I have tried the Shimano 9000 and Aican Bungarus. The Aican Bungarus cable housing is super difficult and very limited in where you'd want to use it (they have fragile joinery that uses a fragmented inner liner) but the cables seem really nice. The coating doesn't shred and fuzz up like Shimano 9000 and it's slick without slipping out of the binder bolt.
I've used the 9000/XTR cables, and they seem very slick, but as others mentioned, they can slip the bolt. On road levers, particularly SRAM, I have trouble installing them without shredding the coating into a full length fuzz. As for what happens on the derailleur side, I didn't find stripping off the coating to be difficult -- it was really too easy. Just take a stamp sized piece of any grit sandpaper, fold it over and run it down away from the mark once or twice.
Also, I got some Bontrager XXX cables, which I'd guess are really made by Jagwire. They're like a highly polished stainless, possibly with some coating, but it's hard to tell. I didn't see a big advantage over plain SRAM stainless. The XXX housing is so-so; it has a plastic inner sleeve surrounded by alloy beads. I didn't notice a huge drop in friction. It seemed like there was actually more drag than with a good lined housing and a SRAM stainless cable.
It seemed like a few or several years ago, there was a real competition for great cables and housing -- Nokon, Yokozuna, etc -- and now I had a harder time figuring out the best option. In the end, I went with Shimano 9000 housing and the Aican cables, because I had it in my quest for some ultimate system. If done again, I think the SRAM set would be a good buy. Or just get the 9000 housing and use any high quality stainless cable.
ljsense is offline
Old 02-18-19, 09:37 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 2357 Post(s)
Liked 35 Times in 25 Posts
I’ll add a -10 to your comments and add a “it depends”. There is a benefit if your bike is used in winter weather and/or stored outside. I’ve seen a lot of bikes with cables that are rusted inside the cable housing...even in plastic lined housing. Salt can get into the cable housing and corrode the inner cable. Even stainless doesn’t stand up to salt. Corroded inner cables cause drag and makes brake and shifter housing work poorly. Teflon coating helps keep the corrosion down.
Stuart Black
An Good Ol' Fashion Appalachian Butt Whoopin'.
cyccommute is offline
Old 02-18-19, 11:16 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6561 Post(s)
Liked 64 Times in 57 Posts
My Brompton came with coated cables , where the housing bends are , the wear-friction, rubbed off the coating ..
fietsbob is online now
Old 02-18-19, 11:42 AM
AnkleWork
Bikes: old clunker
Quoted: 507 Post(s)
Liked 9 Times in 6 Posts
Recent new threads so bad we need to dig through the old ones? I hope riding season returns soon for you.
AnkleWork is offline
