Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
DIY Bike Fitting for Track
Old 12-08-18, 08:44 PM
  #126
carleton
Elitist
carleton's Avatar
Quoted: 1189 Post(s)
Originally Posted by krispenhartung View Post
Here's the new 130mm stem....it doesn't look at extreme as I thought it would, and still well within the 50mm UCI regulation for endurance. The distance between the forward most tip of my bars and the vertical axle plane is approx. 45mm. Later today I will be shooting new video and taking measurements based on this change and the saddle height change. Should be interesting!
So far, so good!
carleton is offline
Old 12-08-18, 09:51 PM
  #127
taras0000
taras0000's Avatar
Quoted: 301 Post(s)
Judging from the looks of it, the heels of your hands will be right over your front hub. This places your forward weight right over the front axle giving you a more neutral steering feel. If your hands were further back before, it will actually slow your steering down a bit, so be prepared for that, but things will be more stable for you at speed because of it.
taras0000 is offline
Old 12-09-18, 01:26 PM
  #128
krispenhartung
krispenhartung's Avatar
Bikes: S-Works Venge Dura-Ace DI2, KTM Strada 4000, Fuji Norcom Straight 1.3 (TT), Fuji Track Elite, BMC Trackmachine TR02
Quoted: 96 Post(s)
Originally Posted by carleton View Post
For the test where you use the 130mm stem, please use the bars used in the photo above.
When testing, it's easier to just change 1 thing at a time to see how things are working out.
Ok, here are the results. This feels really good! Carleton, you are a genius! :-) I don't even think I want to swap the bars out now. This is also with the saddle raised approx. 1.5cm. i don't think I can get any higher without my hips starting to rock a bit and put too much pressure on my soft parts.
Slow-Mo video here showing the full pedal stroke: https://drive.google.com/open?id=1LN...kweyQEChXiZ3_L
krispenhartung is offline
Old 12-09-18, 07:47 PM
  #129
carleton
Elitist
carleton's Avatar
Thatís awesome!
It looks much better to the eye and Iím sure that the numbers say so as well.
Iím glad to have helped!
carleton is offline
Old 12-09-18, 07:51 PM
  #130
krispenhartung
Quoted: 96 Post(s)
Thatís awesome!
Yup! Thank you! I will be making similar changes to my back up track bike, which I use mainly for training, but using some 40cm Easton drop bars instead of the Scattos --- mainly because I am using this bike on my trainer most of the time and I'd like a more comfortable bar for 60-90 min rides. The Scattos get draining after an hour.
Old 12-09-18, 08:17 PM
  #131
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 232 Post(s)
Probably could still go a bit longer...
Baby Puke is offline
Old 12-09-18, 08:57 PM
  #132
carleton
Elitist
carleton's Avatar
Yeah. I agree. I think his fit is now on the shorter side of OK. Roadies and enduros like that compact setup. Maybe itís comfortable.
Maybe turn the stem down to get another almost-centimeter of reach or get a 140mm stem.
For the next frame, I would definitely pick one with at least 2-3cm more reach.
But, itís much better than before right now.
carleton is offline
Old 12-09-18, 09:03 PM
  #133
carleton
Elitist
carleton's Avatar
I think roadie fits are basically, ďNear 100% of weight on the butt. Little to no weight on the hands.Ē This definitely allows for very long rides/races.
Track racing is closer to time trialing than road racing. Weight can go forward. Youíll have to strengthen the arms, neck, and back some...but youíll need those to be stronger anyway to lift up those trophies, wear those medals, and rock those jerseys
carleton is offline
Old 12-09-18, 09:13 PM
  #134
krispenhartung
Quoted: 96 Post(s)
I need strong arms for all the crap that I attempt to carry in a single load to the infield (without a wagon, mind you!) -- bike, extra wheels, rollers, gear bag. I look like a vagabond.
Seriously though, being used to the road, I'm going to sit on this new setup for a while and let it burn in. Right now, I don't do any matched sprints, flying 200, etc -- just the endurance events, Keirin, and 500m on my drops. I do the 2K with a whole different setup.
Old 12-09-18, 10:41 PM
  #135
pierrej
Quoted: 58 Post(s)
Its definitely more weight on the butt than the hands, effectively should be able to take your hands off the bars and not lurch forward, and track only has to be comfortable for a minute or so if we're talking sprint
pierrej is offline
Old 12-09-18, 10:42 PM
  #136
carleton
Elitist
carleton's Avatar
The standing start is key to the 500m. You cannot nail the standing start if your bars are too close. Youíll be constricted, like changing clothes in an airplane bathroom.
Both the Keirin and 500m are less 1 minute each (if you donít count the paced windup of the Keirin). Donít look for comfort on the bike in those events. Look for aero gains and power production, at the expense of comfort.
Learn from my mistake. I spent SEVEN seasons riding 56-58cm bike...when I should have been on a 61cm.
I have a lot of real regrets about that. When I trained my hardest, I was on the worst fitting bikes...and vice-versa. And the times and speeds were similar. Imagine if I had the right fit early on?
Do not get hung up on numbers.
Read that sentence again.
Just add more when you need more and remove when you need less. Declaring what sizes you are and are not can be a huge problem. It was certainly in my case.
carleton is offline
Old 12-09-18, 10:53 PM
  #137
pierrej
Quoted: 58 Post(s)
Watching the video I reckon you can probably come forward a bit with your saddle, as everyone finds out you can probably go for a fair bit bigger bike than you think.
Bad comparison aside, your torso angle isn't drastically different than my resting in the drops roadie position, a bit longer/higher but not as extreme as you will be able to hold for pure track work
pierrej is offline
Old 12-16-18, 07:33 AM
  #138
Kaben
Kaben's Avatar
Quoted: 57 Post(s)
Fitting opinions from experienced sprinters would be appreciated. What do you think of this fit position? ( for sprint). Itís long but actually surprisingly comfortable and keeps my head below my shoulders. It also leaves room for how I pull myself forward on the saddle when I push on really hard. Have a tendency to try and open my hip angle as I fatigue which scrunches me up. This position should keep me more aero when this happens.
Any problems from going for arms extended this far forward that I should be aware of? On a Dolan DF4 this will likely have my hands about 3 cm ahead of the axle( also I think the camera angle not being perfectly side on may make this look slightly longer than it is).
Kaben is offline
Old 12-16-18, 05:32 PM
  #139
queerpunk
aka mattio
queerpunk's Avatar
Quoted: 304 Post(s)
Personally, I don't see the Sphinx as being a faster position than drops. I think the more aggressive Sphinx position with the hands on the "tops" as opposed to where the hoods would be, is more of a relaxing position, taking stress off of the arms, shoulders, and neck and lowering the heart rate a bit.
Heh, yup, that's me.
Faster? It depends. I've done a bit of rough testing for me, personally, and it tests faster than riding in the drops. This is not the case for everybody. Not everybody needs or wants this, or is good at it, or has the physiology, riding style, or flexibility for it. That's okay. I've seen some terrible sphinx positions out there that make me cringe, but hey, there are plenty of drops positions out there that make me cringe too.
I find the sphinx to be a way to combine high cadence and output pedaling with a relaxed upper body. It's a wide-elbow pursuit position. Unlike sprinters, our enduro races aren't just the length of a half decent yawn. In 40km, we pedal in a lot of different ways - and there are a lot of dynamic needs on the bike. Setting up handlebars is all about balancing different needs; the drops need to be an a position that optimize a sprint, and cruising, and we also need a position to accommodate moments in races when we are essentially pursuiting.
I could set up drop bars that mimic my sphinx position but then I'd miss out on the lower, torquier position and the greater stability that comes with where I put the bottoms of my drops. I have daydreamt and sketched the perfect enduro handlebar - nobody makes it. Nobody comes close.
queerpunk is offline
Old 12-16-18, 06:41 PM
  #140
carleton
Elitist
carleton's Avatar
Originally Posted by Kaben View Post
Fitting opinions from experienced sprinters would be appreciated. What do you think of this fit position? ( for sprint). It’s long but actually surprisingly comfortable and keeps my head below my shoulders. It also leaves room for how I pull myself forward on the saddle when I push on really hard. Have a tendency to try and open my hip angle as I fatigue which scrunches me up. This position should keep me more aero when this happens.
That position looks fast as hell...especially if you train yourself to (safely) drop your head* on the straights for extra significant aero gains.
*This is an advanced technique that I'd only advise using on a track that with which you are completely familiar and with the best of judgement. You can see top riders doing it all the time when you look for it.
(this is not a bike throw):
Be very careful trying this...turns 1 and 3 can come up very fast on you at high speeds and you can run up track and maybe wreck and take others out. It requires lots of practice. I never got good at it such that it became habit. My head was in the wind like a dog out of the passenger-side window...floppy tongue and all
Great insights there.
carleton is offline
Old 12-16-18, 06:52 PM
  #141
carleton
Elitist
carleton's Avatar
I recall Gleatzer riding one of his sub-1min kilos almost 100% with his head down. He swerved like a drunk man in the turns, but it was obvious that keeping the head down as soon as possible through the end was the plan. He didn't look up, only at the boards in front of his wheel.
I would guess that he counted pedal strokes or looked at some marker to know when to expect the turns. Not sure.
carleton is offline
