Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs Have a need for adaptive equipment to ride to compensate for a disability or loss of limb or function? This area is for discussion among those of us in the cycling world that are coming back from traumatic circumstances and tell the world, "No, you are not going to beat me down!"
Brake cable doubler and hydraulic brakes
Old 10-04-18, 12:40 PM
McStumpy
Hi, Im thinking of buying an adventure / gravel type bike to compliment my road bike. If its a model with hydraulic disk brakes..... will the brakes still work if I go with same solution as calliper braked road bike for one handed use. Ie using a problem solver cable doubler to allow one lever to pull both brakes at once? Im not sure how the hydraulic brake system works and I just want to double check before I buy .
thanks
McStumpy is offline
Old 10-04-18, 01:10 PM
McStumpy
Ok, have established that the Problem Solver cable doubler is no good for hydraulic brake cables (understandably). Has anyone managed to set up for one handed use with hydraulic road brakes / brifters? Thanks
McStumpy is offline
Old 10-26-18, 03:37 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
Cool you seem confused
hydraulic cables? hoses are for fluids.. housing, for cables, are dry inside..
I have adopted TRP Hy Rd calipers , which are hydraulic within themselves,
the cable pulls lever attached to 1 master cylinder, that pushes mineral oil
that oil pressure goes to 2 slave cylinders that pushes the pads to the disc.
its cable all the way to the caliper.. you could just as well use mechanical disc brakes instead
only the calipers differ..
I don't understand why you have decided it wont work
without actually trying it,,
A year ago my friends at the LBS, used one of those cable doublers 1 brake lever
to pull the actuating levers on 2 S-A Drum Brake Hubs,
in order to have braking power on a wide cargo trailer
used by a Hunter to haul an Elk Carcass out of the woods,
game shot, during Hunting Season.
fietsbob is offline
samit
For Sale
0
04-10-19 10:26 PM
cydisc
General Cycling Discussion
4
02-24-07 10:10 AM
Leland
Bicycle Mechanics
0
04-19-05 08:32 PM
