Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Scott addict fitting
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Reply
Old 11-17-18, 05:30 AM
hythamfekry
Quoted: 76 Post(s)
Hi ,
i'm looking to buy a scott addict frame "team issue 2016" , i'm 163.5 cm with 72 cm inseam , currently i'm riding a scott contessa speedster 2015 XS frame "48" with replaced 100cm stem , geometry details below :
https://www.southforkracing.co.uk/10...road-bike.aspx
i'm hesitated weather to buy a XS or XXS in addict series , below is the geometry specs
both XS and XXS sizes in addict have lower stack "more aggressive , which is normal as it's racing bike rather than endurance" , both sizes have longer reach , and lower standover height than the frame i currently own .
N.B : i'm buying online, we don't have small sizes in LBS for high end carbon frames where i currently live
pls advise
hythamfekry is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
