Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Saddle height conundrum
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 12-21-18, 04:23 PM
wgscott
Atrophied Member
wgscott's Avatar
Bikes: Steel
Quoted: 2366 Post(s)
Liked 69 Times in 37 Posts
I think my saddle is too low.
It is about 1.5 cm lower than the suggested height from my frame-builder, who did a very thorough set of measurements. I also have that sort of weak feeling when climbing hills seated, so I tend to stand up more often than I should have to.
However, if I raise it, it hurts on the left side. (According to the same frame builder's measurements, my right leg is slightly longer than the left, and he had taken this into account already for the recommended height). I never noticed it until I was measured, so it isn't extreme. But I think this asymmetry is part of the problem.
Anyway, I have kept it "too low" so that it doesn't hurt. It is more like my whole leg hurts, not just where I sit.
I've been using an otherwise very comfortable Brooks B17 for several years.
Is there anything else I should try? Are there any saddles more forgiving of leg asymmetry? I've also heard some people suggest rotating the saddle slightly, so the nose points a degree or two off center (which way would be better?)
Oh, I should mention I tried a shoe cleat shim, but it was such a disaster I had to take it out mid-ride.
wgscott is offline
Old 12-21-18, 06:02 PM
redlude97
Quoted: 1594 Post(s)
Liked 12 Times in 9 Posts
have you tried a cleat shim? The problem is that shim addresses the bottom of the pedal stroke but makes the problem worse at the top. Depending on length discrepancy different crank arm lengths could possible be a solution. What hurts when you raise it?
redlude97 is offline
Old 12-22-18, 11:16 AM
phughes
Quoted: 221 Post(s)
Liked 12 Times in 7 Posts
If it doesn't hurt with the seat positioned "low," then it isn't too low. Go with what your body tells you, not what a number based on an average tells you. You are not everyone. My B17 is "low" too, and I have no pain, and actually can spin better. When mine was the "correct" height, I dropped to one side and had hip pain, back pain, and was less efficient.
Try Steve Hogg's method of positioning your seat height and you will most likely end up where you are now, "low." https://www.stevehoggbikefitting.com...ard-can-it-be/
https://www.stevehoggbikefitting.com/bikefit/2011/02/seat-height-how-hard-can-it-be/
phughes is offline
Old 12-22-18, 12:59 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6563 Post(s)
Liked 65 Times in 58 Posts
I'd start with the old heel of foot on pedal, leg straight , ( Low or Heelless Cycling shoes ) and fine tune from around that..
you need tech links instead? fine .. suit yourself.. ..
fietsbob is offline
Old 12-22-18, 06:50 PM
woodcraft
woodcraft's Avatar
Quoted: 988 Post(s)
Liked 12 Times in 6 Posts
What hurts?
Front of knee? Back of knee? IT band area? Quads? Butt?
Calf? Ankle? Foot? (this is fun-should I go on?)
woodcraft is offline
Old 12-23-18, 09:27 AM
phughes
Quoted: 221 Post(s)
The links I gave does just that, fine tunes the initial height based on how efficiently you can pedal. Not complex, and no formula.
phughes is offline
Old 12-23-18, 07:52 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1723 Post(s)
Liked 14 Times in 12 Posts
I also have leg asymmetry. I use a shim, but that's not nearly enough. I use a saddle that's the exact shape and width of the bones of my pubic ramus, because that's what I perch on in my road position. My legs don't touch the saddle at all. Probably more help can be found by stretching, especially the hams. Look around for good cycling stretches or use these: https://www.bikeforums.net/road-cycl...l#post15372967
Results matter
Carbonfiberboy is offline
Old 12-23-18, 08:15 PM
wgscott
Atrophied Member
wgscott's Avatar
Bikes: Steel
Originally Posted by woodcraft View Post
What hurts?
Yes. Pretty much the whole left leg. "Hurt" is really an over-statement, but the sensation I think it suggests over-extension. Left glutius medius specifically hurts if I go what is likely too high.
wgscott is offline
Old 12-23-18, 08:17 PM
wgscott
Atrophied Member
wgscott's Avatar
Bikes: Steel
I should do this. I seldom stretch, and am less flexible than a two-hour cold cadaver.
wgscott is offline
Old 12-23-18, 08:59 PM
wgscott
Atrophied Member
wgscott's Avatar
Bikes: Steel
Thanks for posting those links. I have to admit I was skeptical because of his reputation for crazy stuff like iPhone polarity interfering with bike fit, and I couldn't tolerate the mid-foot cleat position, but the stuff about compensating and asymmetry I think is spot on.
I think I still sub-consciously favor my right leg (where my ankle break was), and there is a good chance there is some real asymmetry. (One weird consequence of being on crutches for 4 months is that my right arch no longer collapses like my left one.)
wgscott is offline
Old 12-23-18, 10:31 PM
phughes
Quoted: 221 Post(s)
LOL Yeah, the iPhone polarity interference is right up there with tinfoil hats. I ignore all that. He has a lot of good ideas, but tht one is way out there.
phughes is offline
Old 12-24-18, 01:27 AM
Carbonfiberboy
15 minutes every morning before breakfast. It's the every morning thing that does it and the small time commitment is good.. Every stretch for 20 seconds, to the point of discomfort, never pain.
Results matter
Old 01-04-19, 03:54 AM
Road Fan
Road Fan's Avatar
Quoted: 742 Post(s)
Pain and stress near where the tendons attach to bone is a warning sign, perhaps of over extending or over exerting the muscle. Tendons take an awful long time to heal.
It's not that rare among us older folks.
I recently fitted a Brooks Swallow to one of my bikes, and it hurt on my left sitbone due to the new hard leather. I could also be sitting on the cantle plate, I'll have to check that. Rather than just HTFU, I rotated the saddle a little bit at a time, moving the nose toward the side that hurt. That equalized the pressure on the two sitbone contact points.
Road Fan is offline
Old 01-04-19, 03:56 AM
Road Fan
Road Fan's Avatar
Quoted: 742 Post(s)
Yeah, we just have to use our heads and experience, and take the parts of what these guys offer that actually make sense.
Road Fan is offline
Old 01-04-19, 08:27 PM
Dampin
Quoted: 11 Post(s)
How important is frame size if the saddle height is correctly fit ?
Dampin is offline
Old 01-05-19, 09:12 PM
pakossa
Quoted: 24 Post(s)
If saddle height is correct, then the important thing is the LENGTH (top tube) of the frame. This will vary due to preference, flexibility, body proportions, etc. (For instance, if you have a short torso, then you'd want a frame with a shorter top tube.)
pakossa is offline
