Panaracer Gravel King, World's Most Sadistic Tire?
Old 02-08-19, 09:41 PM
Hondo Gravel
Voted For Pedro
Bikes: Motobecane Boris Fatbike, Motobecane Omni Strada Pro,Fantom Pro CX, Fantom X7 MTB, Gravity SS MTB.
Quoted: 431 Post(s)
Liked 27 Times in 24 Posts
Originally Posted by wheelsmcgee View Post
+1. This is the single biggest lesson I’ve learned about tire mounting problems, particularly on tubeless compatible rims (never had a major problem on non-tubeless tires/rims ).
Same here my tubeless rims are a SOB to mount tires on especially since I use tubes. I purchased another wheelset for my mountain bike that had regular old fashion clincher rims now changing tires is easy. So a flat in BFE will be a snap. Luckily in off road nowhere in Big Bend NP I never had a flat I would have manage but it would be a bloody finger endeavor. I know go tubeless but I don’t want to mess with it plus my MTB can sit for weeks as I mostly ride my gravel bike these days. When the MTB bug hits me, I hit some trails to mix it up and want rims that tires can easily be mounted to.
Hondo Gravel is offline
Old 02-09-19, 05:02 AM
kingston
Jedi Master
kingston's Avatar
Bikes: http://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1063 Post(s)
Liked 13 Times in 11 Posts
For motorcycle tires I use dish soap mixed with water applied with an old paint brush. Probably about the same thing as bubble juice. Can't recall using it for a bike tire, but I'm sure it would work the same.
kingston is offline
Old 02-09-19, 06:09 AM
Whit51
Whit51's Avatar
Quoted: 38 Post(s)
I tried to mount the 32 mm SKs on Sun CR 18s with tubes. I couldn’t do it - first time in my life to fail to get a tire on a wheel. I finally got them to fit on Mavic Open Sports using soapy water, Pedro’s steel reinforced levers, and every other technique I coulf find. Then had a flat, probably due too overly aggressive use of the tire levers. They went on easier the second time and have worked fine since.
Whit51 is offline
Old 02-10-19, 03:06 PM
CV-6
If I own it, I ride it
CV-6's Avatar
Bikes: Lejeune, Raleigh, Raysport, Jan De Reus, Gazelle, Masi, B. Carré, Springfield, Motobecane, John Howard, Greg Lemond
Quoted: 292 Post(s)
I am glad I am not the only one to have adventures mounting these tires. I ended up mounting them sans tubes and leaving them for a couple of weeks. Then came back and dismounted to install tubes. They were a bit easier but a tire jack was used. I thought they were only bears to mount on older 700c rims. So they are a PITA on newer rims? Seems all the new "hot tires" are a PITA to mount. I have recently mounted Vittorias and Specialized Turbo Cotton with similar efforts involved. I did try using tubeless tape on the Vittorias and cannot say it made much difference.
Lynn Travers
Photos
CV-6 is offline
Old 02-12-19, 08:42 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 669 Post(s)
Liked 19 Times in 16 Posts
I have the same experience and the same frustration. Your picture makes it clear – its the rim bed that is preventing you from mounting the tires.
Originally Posted by Lemond1985 View Post
I guess I will wait for the Kool Stop, but it seems like this tire is just too small. Nothing doing:
I’ve got the exact same problem with some schwalbe’s (35mm) There is just know way they are going on some of my older wheels without breaking something. Well, I’ve broken about 7 pedro levers. It depends a lot on the wheel. I think with newer style wheels with a deep gutter running in the center of the wheel they will mount fine. But on a wheel more than a couple of years old – with a shallow rim bed – it just isn’t going to happen for me.
Originally Posted by tiredhands View Post
They absolutely require a Kool-Stop tire jack to install, in any size. I've tried a couple 32s in both SK and file tread as well as 43.
I'm a huge fan of the tires. Been on a set of 32s in a file tread for a year for commuting, gravel, and fast club rides. Only flatted once with a snakebite because I was playing around with low tire pressure. Once that was dialed, it's been smooth sailing.
I'm sure they won't handle goat heads, not much can I hear. It's probably worthwhile to run a tube with a removable core and add some Stan's sealant. Then you can have your supple ride with no headaches.
How do you get a snake bite on a tubeless tire? Or are you running tubes?
FYI, sealant doesn’t protect against snake bites. I’ve learned the hard way. But the centrifugal force of when riding keeps the sealant away from the snake bite area.
chas58 is offline
Old 02-12-19, 09:04 AM
bikemig
bikemig's Avatar
Quoted: 3501 Post(s)
Liked 17 Times in 15 Posts
Originally Posted by Spoonrobot View Post
Velox is the issue 100%. I say this as someone who struggled with Velox wrapped rims and modern tires for years until I finally learned what was going on. Get some tubeless tape or even a cheap plastic rim strip and it'll be much easier.
Velox is at least 5x the thickness of Stan's tape and can make it extremely difficult to mount modern tire/rim combinations.
Yeah I love Velox but I think Stans may be the answer. I've also seen a few threads suggesting that there are industrial tape alternatives that will do the job at a lower price. No experience with this but some say it does the job,
https://www.amazon.com/dp/B00C0Z21PK...rum-convert-20
bikemig is offline
Old 02-12-19, 11:58 AM
Mmassey338
Quoted: 5 Post(s)
I recently mounted two Gravel King 700x38 tires on Vision Team 30 wheels with no tools or lube. They went on very easily, and I’m not an expert. The rim tape is whatever came on the wheels.
ETA the wheels are “tubeless ready”, but I’m running tubes
Mmassey338 is offline
Old 03-06-19, 09:05 PM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 685 Post(s)
Liked 72 Times in 60 Posts
Update: I got some of the Panaracer Paselas, also in 700 x 28. Similar mounting issues but I was ready this time with soapy water, and a Kool Stop Tire Jack.
I was peeved initially, when the tires appeared a couple mm too narrow. But since then, I've put the both sets of tires on various bikes, and was happy to see the the Panaracers in 28 mm fit all of my older road bikes that otherwise won't take tires that really are 28 mm.
So the under-sizing of these tires was genius on Panaracer's part, a 28 mm tire for road bikes that normally can't clear 28's.
Lemond1985 is offline
Old 03-07-19, 07:47 AM
fishboat
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '02 Poprad, '79 AcerMex Windsor Carrera Professional(purchased new), '06 Bianchi Volpe, '88 GT Tequesta(purchased new), '01 Bianchi Grizzly
Quoted: 188 Post(s)
Liked 11 Times in 7 Posts
...I've put the both sets of tires on various bikes, and was happy to see the the Panaracers in 28 mm fit all of my older road bikes that otherwise won't take tires that really are 28 mm.
I run a bunch of these tires(Gravel King slicks in 700cx28) on a number of vintage-early 2000's bikes. The 28s typcally run 26.5-27mm, Nice tire.
fishboat is online now
Old 03-07-19, 08:05 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 685 Post(s)
+1
The 28 mm Gravel Kings even fit on my '88 Cannondale Criterium Series. And that bike has terrible tire clearance too, being designed as a crit frame and all. They admittedly max-out the frame though, I'm never gonna be able to fit anything wider on this bike.
Old 03-07-19, 10:42 AM
5teve
Quoted: 46 Post(s)
I was able to fit 650bX47 GK's on Easton rims without too much trouble. Had to preset one bead with a tube to get them set up tubeless but that happens with about half the tires I install.
5teve is offline
Old 03-08-19, 12:11 PM
Explosive
Quoted: 49 Post(s)
This thread makes me feel better about myself lol. Last year i was having a hell of a time getting 700x28 gravel kings mounted up and it was mt first time messing with road tires and found myself wondering how the hell people make it look so effortless in the middle of a ride or race.
Explosive is offline
Old 03-08-19, 06:18 PM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 685 Post(s)
Hopefully mine will stretch out some before I get my first flat. I've used wire bead tires most of my life, these folding tires seem much more difficult to mount. I'm not convinced they're worth the trouble.
I do think part of the trouble was the tackiness of a new tire, and its tendency to not want to slide easily over an aluminum rim, especially when it's been folded up in a freakin box for the last year. Folding tires definitely take some getting used to.
Old 03-09-19, 08:03 PM
fishboat
Quoted: 188 Post(s)
After they've been mounted and have some miles on them they're MUCH easier to mount the second time.
Old 03-13-19, 05:34 PM
sail
sail's Avatar
Bikes: Yep
Quoted: 43 Post(s)
A bit of soapy water works wonders.
sail is offline
Old 03-26-19, 06:29 PM
rosefarts
Quoted: 242 Post(s)
Liked 17 Times in 7 Posts
Just mounted mine today on DT Swiss 460's. I also mounted them with Skinny Strippers. I was worried because of this thread but with some soapy water and one tire lever, they went on fine, even with the Skinny Strippers.
I used a compressor to fill them up and both held air the first time. I deflated them and added 60ml orange sealant. Today they measured almost exactly 38mm. I'll check again after tomorrow's ride.
rosefarts is offline
Old 03-27-19, 07:13 PM
rosefarts
Quoted: 242 Post(s)
They didn't lose a single psi overnight (maybe 1). Are currently sitting at 39.5mm. I'm glad I didn't get the 43's.
I put 60 miles on them today. Gravel, hardpack, washboard, and a little paved. They perform great and feel surprisingly unrestricted at 21-27 mph (I got a nice section of pack with no wind and a slight downhill, for once).
They also happen to be the same blue as my bike. Looks sharp on Blackwall.
I'll keep them.
Old 03-27-19, 07:43 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1547 Post(s)
Liked 11 Times in 10 Posts
I do a little gravel riding. I just use Panasonic Paselas. They seem to work just fine and mount without difficulty on Open Pro or Velocity Aero rims. Is there a reason I should jump ship and graduate to the Gravel King headaches?
Ben
79pmooney is offline
Old 04-29-19, 01:55 PM
tofudog415
I recently mounted the 43mm SK model on 21mm internal UST rims. It was really challenging, but this thread ironically gave me the motivation to keep trying. I used two Pedros levers and quite a bit of force (though not enough to think anything was gonna break) to get them to cooperate. This was all to get the to the point of dry mounting the tires in preparation for going tubeless. I was not able to get the beads to seat using a floor pump and soapy water. It took a few tries with an Airshot and soapy water to get them to pop on. Then I had to break the bead (not difficult) and take it off one side to pour in the sealant. The second time remounting the tire post-sealant was considerably easier, but I still needed levers and some force. Tire/rim/sealant combo holds air really well. Experience was identical on both tires and rims. I'm gonna keep the two levers in my saddle bag from now on, just in case, knowing it's impossible (for me) to do anything with this tire/rim combo by hand.
tofudog415 is offline
Old 05-04-19, 08:10 AM
Hondo Gravel
Voted For Pedro
Quoted: 431 Post(s)
I put Velox tape on tubeless ready rims and that was a mistake. I couldn’t get the tires to bead evenly and the tape wouldn’t stay in place. And I cleaned the rims with alcohol not beer lol. Later I mounted another tubeless rim with tubeless rim tape and no problems. As everyone has mentioned modern bike tires are getting harder to mount. The old school wheels and tires were a snap.
Old 05-05-19, 10:40 AM
spircix
Quoted: 13 Post(s)
You all have some really interesting experience with GKs. I just bought 700x32 GK SK and mounted them with no problems whatsoever. Yes, they were a bit tighter than usual (a bit tighter than other folding bead tyres), but still I managed to mount them without using tyre levers. After reading this thread I was prepared for a struggle, but compared to Soviet-made tyres I have mounted in the past mounting GKs was a walk in the park.
spircix is offline
