Alfine 11 S7001 questions
Old 02-10-19, 10:38 PM
Banzai
Jet Jockey
Banzai's Avatar
Bikes: Cannondale CAAD9, Ritchey Breakaway Cross, Nashbar X-frame bike, Bike Friday Haul-a-Day, Surly Pugsley.
Quoted: 316 Post(s)
The cycling-interested corners of the internet are littered with stories about Alfine 11 problems, from extremely finicky setups, to outright malfunctioning and extremely poor reliability. The consensus seems to be that if you want a hub to function, get an Alfine 8.
Most of those discussions are getting kind of dated though, and I can't find much about the new S7001 version of the hub.
Is it better? Is it worth taking the risk on? At nearly $400, it's a pricey gamble.
Good night...and good luck
Banzai is offline
Old 02-11-19, 10:29 AM
motorapido
Bikes: 1976 Schwinn Super Le Tour, tricked out with modern components. Shimano Alfine 11 internal gear hub. Dynamo hub. Titanium racks and bottle cages. Mercier Kilo Wide Tire dropbar singlespeed
Quoted: 40 Post(s)
My SG S700 has been flawless for 6,000 miles
My Alfine 11 SG S700 is probably the older model. I have had no problems despite gearing it far lower than Shimano approved and riding 6000 miles including several fully loaded tours and mostly on gravel and heavy mud. Great hub.
motorapido is offline
Old 02-11-19, 02:48 PM
Banzai
Jet Jockey
Banzai's Avatar
Quoted: 316 Post(s)
Good to know. The UK cyclechat forum has a near 50 page thread full of people replacing the Alfine 11 multiple times before giving up. MTBR has very little positive either.
However, almost all of those discussions predate the 7001 model.
Wouldn’t be the first time Shimano used consumers for product testing...
Banzai is offline
Old 02-11-19, 02:52 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6579 Post(s)
Liked 69 Times in 62 Posts
Likely if you keep up on the oil changes , frequently enough.. you will be better off ..
fietsbob is offline
Old 02-12-19, 08:12 PM
sweeks
sweeks's Avatar
Bikes: Airborne "Carpe Diem", Trek 6000, Strida 2, Dahon "Helios XL", Dahon "Mu XL", Tern "Verge S11i"
Quoted: 499 Post(s)
Liked 6 Times in 6 Posts
I have an Alfine 11 on my folding commuter bike. 6,500 miles with nary a problem. I do oil changes about every 600-700 miles; it's easy. I use a synthetic gear oil (Royal Purple 75w-140) which is much cheaper than the OEM lubricant and has worked perfectly well.
sweeks is offline
Old 02-16-19, 12:47 PM
Buglady
Buglady's Avatar
Bikes: 2018 Ghost Square Trekking B2.8 e-bike; 2015 MEC Cote gravel/touring bike; 2012 MEC Silhouette hybrid; 1985 Boyes-Rosser tourer, now outfitted as Winter Trundle-bike
Quoted: 11 Post(s)
Mechanic here, have worked on Alfine 11s (as well as Alfine 8, and Nexus 3/5/7/8) for the last 6 years. Setup and maintenance are important, and can be fiddly, but whether the hubs are "good/bad" really depends on what one expects from them in the first place. If you expect the same gear range as a derailleur setup, or if you want to ride at minus forty (I've had that conversation six times this week), or if you want to shift while pedalling uphill at heavy torque - no, you aren't going to be happy with the Alfine 11, or really any IGH; they just are not designed to be used that way.
I do think there's a sampling bias in the preponderance of bad reviews; not only are people ten times more likely to talk about bad experiences than good ones, but people who post on cycling forums are also more likely to be sensitive to changes and noises than the general cycling public. The vast majority of the bikes I have worked on belong to commuters who don't put extraordinary demands on the hubs, and they are happy with them.
No system is perfect, but I have no hesitation recommending Alfine 11 hubs to people who are using their bikes for relatively light duty commuting and utility riding, or for recreation.
For long distance touring, carrying or towing heavy loads, or winter riding, I would recommend a different drivetrain - derailleur, Rohloff hub, or even pinion drive (I'm just starting to learn about those and they are fascinating), as these systems are better able to handle the demands of such uses.
Buglady is offline
Old 02-16-19, 01:19 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
It's like the news , crash landings get coverage, not routine safe ones ..
fietsbob is offline
Old 02-18-19, 01:38 PM
alias5000
Raised a new winter bike
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, 2007 Trek 6000, Circe Morpheus
Quoted: 139 Post(s)
@Buglady
What is the reason you are recommending against using it in (serious) winter?
alias5000 is offline
