Front Fork External Springs/No Maintenance?
Reply
Old 02-17-19, 11:30 AM
Snikerdoodlz
I have a 2013 Trek 820 that I use around town. Over the years, the front suspension fork has seized up and it's completely stiff. I looked up videos about re-greasing forks, and it looks rather complicated. Plus one application does not last and my fork will probably seize up once again. I'm now looking for a zero-maintenance fork that keeps on working with very little risk of locking up. Is there such a design or any fork with external springs, or something without a traditional large sliding tube housing that will trap moisture and dirt?
Snikerdoodlz is offline
Old 02-17-19, 12:02 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 554 Post(s)
http://bike-manual.com/brands/fisher...tm_engdefo.pdf
dedhed is offline
Old 02-17-19, 12:47 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6158 Post(s)
External spring forks look like this :
fietsbob is offline
Old 02-17-19, 12:55 PM
jimc101
Quoted: 261 Post(s)
Trek 820 will probably have a Suntour fork, these are disposable, you can't get many/any spares, and even if you can source them, it will be cheaper to replace the complete fork.
The possibly only maintenance forks currently available like the Lauf fork (and linkage designs like it), which cost 2-3 times the original cost of the Trek, the cheapest option would be to replace with a rigid fork.
jimc101 is offline
Old 02-17-19, 08:52 PM
Snikerdoodlz
Would it be a good idea to buy a used RockShox fork on eBay?
Old 02-17-19, 08:58 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1624 Post(s)
As far as fork "travel" goes the only maintenance free design also has no travel. As in a rigid one. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 02-19-19, 07:10 AM
jimc101
Quoted: 261 Post(s)
Buying any used fork, no matter where it is from is taking a risk, you don't know how it has been used/abused, for a lot of lower end forks, the cost of repair/service is similar to just buying a new fork, so you may just be buying a fork which will need service straight away, another issue will be corrosion/stanchion damage, both can effectively scrap a fork.
Unless you know exactly what you are looking for, would consider buying new the best option for forks, even just replacing with a new set of Suntours will get you back on the road.
jimc101 is offline
Old 02-19-19, 08:38 AM
2cam16
2cam16's Avatar
Bikes: TOO MANY
Quoted: 510 Post(s)
AFAIK, there's no such thing as a zero maintenance suspension fork . You'd be better off going to rigid. If you do, keep in mind that a suspension forked bike has different geometry than one that came with a rigid so make sure you get your measurements right for a rigid fork. Same goes with buying a replacement suspension fork, make sure you get the correct size.
2cam16 is offline
Old 02-19-19, 11:31 AM
AnkleWork
Bikes: old clunker
Quoted: 480 Post(s)
Riding a big tire mountain bike "around town", the last thing I'd want to lug is a suspension fork. A rigid fork will be a true upgrade.
AnkleWork is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
