Headshok Hack- Convert to Rigid
Reply
Old 02-19-19, 02:59 PM
BMWK75s
Hi,
I have an ancient cannondale F500 with a super fatty from another bike. The damper is leaking and needs to be replaced.
But, the bike is just going to be used as a campus beater. I am wondering if anyone has converted a headshok to a rigid fork just by removing the damper, and putting in a wooden dowel or metal rod that would replace the internals? Basically, changing the fork so that there is no air chamber/damper inside the fork.
Otherwise, the bike goes in the dumpster.
No, I don't want to spend $30 on a reducer cups and $50 on a cheap replacement fork, but thanks for thinking about it.
Cheers,
Rob
BMWK75s is offline
Old 02-20-19, 11:39 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6197 Post(s)
give your idea a try yet?
fietsbob is offline
Old 02-20-19, 12:29 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1074 Post(s)
You are going to need a really solid top cap to keep impacts from shoving the reenforcing rod up through the top of the steerer.
That $80 retrofit you mentioned doesn't sound like a bad investment
HillRider is offline
Old 02-20-19, 03:37 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 483 Post(s)
Yeah, but he ruled that out right off the top. I have a 20 year old F model Cannondale that I did exactly that with. Tossed the Headshok and put in a rigid fork with reducers.
Dan Burkhart is offline
Old 02-20-19, 03:59 PM
hokiefyd
Bikes: 2018 Redline Zander, 2018 Giant Roam 2, 2015 Trek Verve 3, 1997 Trek 750, 1969 Peugeot PO-18
Quoted: 664 Post(s)
Rob, that bike probably has a lot of otherwise high quality parts on it. At the very least, if your conversion project doesn't work out, please donate it to a co-op or post your location here and someone would gladly come pick that bike up from you. If you're in northwestern VA, I certainly would!
hokiefyd is offline
Old 02-20-19, 04:24 PM
wesmamyke
Quoted: 134 Post(s)
I would just mention that you will probably be destroying the fork if you ride it like that. Even just riding around all the time with the lockout engaged will destroy most forks in short order. The bushing, or needle bearings in the case of a headshock won't get lubricated from moving up and down. Eventually it just eats through the sliding surfaces and the whole fork is trash.
wesmamyke is offline
Old 02-20-19, 08:39 PM
HillRider
Yeah, he ruled it out perhaps thinking there was a much cheaper kludge that would work. I don't think it will and suggested the retrofit is the next best thing.
Old 02-24-19, 09:45 PM
BMWK75s
Actually, all the parts are pretty well junk, it was built from a frame and thrashed.
I guess I could go to the local bicycle junkyard and find a scrap 1 1/8" rigid fork somewhere.
BMWK75s is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
