Axel conversion
Axel conversion
Old 02-19-19, 10:35 PM
jonelliotelliot
jonelliotelliot's Avatar
Quoted: 40 Post(s)
Axel conversion
Hi there.
I bought a set of wheels (Mavic crossmax)
the rear is 142 (12mm)
front is 100 (15mm)
I need to convert the rear to 135mm (9mm) and the front to 9mm to be used with a QR, so I bought some adapters that do just that.
I measured my rear hub and it is 142 from end to end. Each of the ends has this dark grey protruding end piece with a slot in it. If I were to remove these end-pieces, the hub would measure 135mm. Then I can slide the QR adapter inside, which will reduce the hollow axel to 9mm.
Any tips on how to remove these grey end pieces?
photos attached. I just donít want to botch things up.
Thanks.
jonelliotelliot is offline
Old 02-20-19, 05:54 AM
jimc101
Quoted: 281 Post(s)
Simple, sell them, and buy a set the that fits (your probably get a better price selling as a set rarther than individually).
For the rear, you can get converters to go the other way 135 to 142, but no 142 to 135,for the front Mavic 99694101
But for all of of it, why did you buy something which won't fit???
jimc101 is offline
Old 02-20-19, 07:33 AM
Kapusta
Cyclochondriac
Quoted: 864 Post(s)
Liked 16 Times in 15 Posts
Is this not it? https://www.jensonusa.com/Mavic-Cros...2-To-135QR-Kit
Kapusta is offline
Old 02-20-19, 07:40 AM
jonelliotelliot
Quoted: 40 Post(s)
Lol, Having a bad day? ... canít read good?
Yes you can convert 142 to 135... this is pretty common.
As I pointed out: what makes this hub 142mm, are the additional end-caps that protrude out.
These come off. Mavic sells axel conversion kits for both front and rear.
I was just asking if anyone had any tips on removing them.
Old 02-20-19, 07:44 AM
rhenning
Quoted: 248 Post(s)
When you get the conversion kits from Mavic I suspect they will have directions on how to install the new parts. Roger
rhenning is offline
Old 02-20-19, 07:52 AM
jimc101
Quoted: 281 Post(s)
Lol yourself, how hard is it to work out tht you need to pull them, 2 massive pictures obscure all that you wrote and fill the screen,
The term RTFM springs to mind for you
jimc101 is offline
Old 02-20-19, 08:01 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1109 Post(s)
As an aside, is the rear axle really 9 mm? Most rear qr axles are M10x1.0. Front qr axles are usually 9mm.
HillRider is offline
Old 02-20-19, 08:36 AM
Kapusta
Cyclochondriac
Quoted: 864 Post(s)
Welcome to BIke Forums, it is par for the course
Kapusta is offline
