Go Back  Bike Forums > The Lounge > Blogger's Forum
Personal log
Blogger's Forum Whether it's a cycling blog, or just your personal page, this is the place to share ideas and links.
Personal log
Reply
Old 10-22-18, 09:01 AM
  #201
rumrunn6
rumrunn6's Avatar
Quoted: 2809 Post(s)
cpl other highlights
was interesting to see how much fork compression I used on this trail
actually used the feedbag for it's intended purpose! 2 PB&J sandwiches cut into quarters
rumrunn6 is offline
Old 10-24-18, 03:55 AM
  #202
rumrunn6
rumrunn6's Avatar
was surprised but also interested to see the mud splashes on the rear trunk. don't think I'll rush to do another mudflap just yet tho
while squeezing thru one of the downed trees had a little issue with a big branch pushing up on the rear fender. easily bent my DIY brace, but then it also straightened out just as easily
rear deflector is working but I think it can be better. not much room to work tho
how hard would it be to invent a deflector for the bottom bracket & chain rings? wonder how strong that little screw that holds the BB cable guide is?
rumrunn6 is offline
Old 10-24-18, 04:33 AM
  #203
rumrunn6
rumrunn6's Avatar
1 more horse pic. didn't stop on my way north when the light was better. but this back lighting later in the day had some potential
rumrunn6 is offline
Old 10-27-18, 08:02 PM
  #204
rumrunn6
rumrunn6's Avatar
after a lot of hemming & hawing I got out for a ride in the nor'easter down at the river. only rain today
9.52 miles
22 max
8.9 avrg
1 hr 4 min in the saddle
since I knew I would be back before "dark" used just a cpl small lights. but did bring the big light in my trunk (just in case). got home in last light
rumrunn6 is offline
Old 10-29-18, 07:34 PM
  #205
rumrunn6
rumrunn6's Avatar
took a loop around the Assabet preserve after work. the rain cleared so it was only chilly. did my best to avoid the mud. tried a velcro mount on the new helmet & I guess it worked cuz I still have my camera
high 40s?
6:45 left house
7:45 back home
9.53 miles
19.4 max
9.3 avrg
1hr saddle time (hmmm unusual saddle times equals trip duration, guess I didn't stop much)
getting onto Summer St
crossing rte 117
riding around the mud
rumrunn6 is offline
Old 11-24-18, 07:28 PM
  #206
rumrunn6
rumrunn6's Avatar
mounted this year's studded tires
last year's winter bike vs this year's winter bike
I'll get it dirty soon
rumrunn6 is offline
Old 12-02-18, 04:24 AM
  #207
rumrunn6
rumrunn6's Avatar
finally got a window of opportunity & got out for a cpl hrs. temps in the high 30s. stayed upright & stayed dry. nice to see ppl out for walks on a sunny day. there were a handful of riders as well. since there was no ice I guess it was a good day to set the studs on the new 29x2.0 tires. at 50 psi the rear measured 49mm. the front was at 40psi. they are noticeably slower than the 29x2.25 Riddlers. when the mush & ice appear I'll try lower, maybe 30 front 40 rear. not exactly sure what wheel factor to use so I tried the middle number of these three
2273
2288
2289
11.20 miles
25.6 max
8.6 avrg
1hr 17min in the saddle but had a leisurely time exploring & was away from the house for a cpl hrs
hoping to get a ride in this week after work left the bike outside in the rain. covered the saddle & also clipped the barmitts closed to keep the rain out
rumrunn6 is offline
Old 12-06-18, 11:56 AM
  #208
rumrunn6
rumrunn6's Avatar
12/5/18 Concord, Bedford & Billerica using Reformatory Branch & Narrow Gauge Trails, at night in sub-freezing temps, approx. 26 - 32 degrees. didn't want to lug all my stuff to work so i prepped the night before so I could drive home, get my stuff then drive to Concord. don't count on Bedford Depot restrooms, they are closed for the season! too bad they were always a welcome sanctuary, especially at night!
7:10pm - 8:08pm 7.9 miles to Billerica
14 mph max
9.1 avrg
52 min saddle time
9:12pm back at car
Whole ride
15.9 miles
15.9 max that's a weird coincidence!
9.3 avrg
1hr 43min saddle time
Trip duration approx. 2hrs (not including driving the 15 miles (round trip) to home)
I slept well
even tho it's been real cold, the mud was not solid, a little crunchy at the edges & tops of the ruts, y folded right over & made riding a little tricky in spots. all good fun. I let a little air out of the front tire for the ride back, I think it's time, & steering thru the mud was a little easier. this is a nice little night ride. doesn't feel long but when I;'m done I'm over 15 miles & got a cpl hrs of outside exercise!
used the 2nd sportcam. so kept one on my helmet & one in my pocket. I like that instead of having to move one around to do everything. unfortunately these are not effective at night. I might take my wide angle diffuser off for a little more punch thru the darkness
this is at 62 heading back west down into what is some pretty soft mud. good thing I knew it was coming or I might have hit it to fast
always a good idea to wear a headlamp around my neck to help take leaves out of the fenders & derailers, or in this case, air down a smidge
on my last cold ride my phone turned off I guess due to the cold even tho it was in my jacket pocket, so this time I added a toe warmer! it worked!
finally got to use these PI winter gloves. they worked out very well, even inside the bar mitts. but at the 1/2 way point I swapped them for my lighter go-to wind stopper gloves
I also swapped out the balaclava at the 1/2 way but 3 miles later put it back on. the very thin beanie & cycling headband weren't quite cutting it. shud have brought a thin knit hat maybe. but it was no biggie the balaclava wasn't that wet & I just turned it inside out. I also unzipped the pitzips for a little while but soon zipped them back up. this temp range may be the limit for the Marmot jacket. I had a zip neck poly base & fleece shirt which was fine, but if I was gonna be out any longer I would need another layer or a different top layer. I was eager to find out how the Basecamp helmet & visor would work with a balaclava & I'm happy they pair up well.
sock liners, hand warmers & winter socks in the winter boots were good too
rumrunn6 is offline
Old 12-12-18, 09:45 AM
  #209
rumrunn6
rumrunn6's Avatar
Concord, Bedford & Billerica using Reformatory Branch & Narrow Gauge Trails, again with temps in the high 20s. lugged all my stuff to work so I could just go straight to the Concord parking lot. Wound up being away from my car for 2 hrs this time. Hmmm guess I had more stops … didn’t bring the computer cuz I was rushing to get to work w/o being too late. Plus I know it’s approx 16 miles
With a gym session at lunchtime & a nice night time bike ride, it’s easy to go to bed early
the mud is solid now, glad I let a little air out of the front tire last time, might be time to let a smidge out of the rear
used a new-to-me waterproof digital point-&-shoot cam I got off ebay for $40. It has very limited usefulness. Kept the polaroid sportcam on my helmet but experimented with FHD (full HD) but the file sizes are so much bigger & with poor lighting it was a waste
took my wide angle diffuser off for a little more punch thru the darkness, it was nice to have all that light back. But I couldn’t find the original clear lens so I used the lens from the cheap knock-off headlight. It fit but not perfectly so I had to listen to it rattle the whole time. Ordered the proper lens
after the way point I put the headlamp that I wear around my neck in my pocket, it’s too annoying around my neck & gets in the way when I want to zip up or down the various layers I had on
I added a toe warmer to my cell phone again, wish they came as singles
use the PI winter cycling gloves again. but again at the 1/2 way point I swapped them for my lighter go-to wind stopper gloves
again I also swapped out the balaclava at the 1/2 way & this time brought a thin knit hat to take it’s place. My headband was in my trunk so I didn’t add that but it would have been helpful because even tho the knit hat is long enough to cover my ears, I could have used more "sealing" from the cold wind
added a layer up top this time, a modest fleece vest. It was just the ticket. Kept the pit zips on the Marmot jacket closed except toward the end I opened them a cpl inches ea.
down below I wore the Headwind pants under the Showers Pass storm pants. Good cold weather combo. Trishorts under both of course
used the usual sock liners, hand warmers & winter socks in the winter boots
hot water with honey in the Corkcicle thermos! oh yeah!
rumrunn6 is offline
Old 12-21-18, 01:45 PM
  #210
rumrunn6
rumrunn6's Avatar
got out of work early wondering if I should ride in high winds & heavy rain
rumrunn6 is offline
Old 12-22-18, 06:47 PM
  #211
rumrunn6
rumrunn6's Avatar
glad I didn't ride yesterday cuz today I saw some significant wind damage. Concord, Bedford & Billerica using Reformatory Branch & Narrow Gauge Trails, again. the mud was slow like glue
16.1 miles
19.1 mph max
7.9 avrg
2 hrs 3 min saddle time
started w light gloves but didn't need them with the barmitts at the 1/2 way turn
quilted shirt & Marmot jacket up top. running tights under the headwind pants
waterproof hikers, 1 pair smartwool socks & toe warmers
I think the front tire pressure is about as low as I want to go
rumrunn6 is offline
Old 12-24-18, 03:11 PM
  #212
rumrunn6
rumrunn6's Avatar
noticed a rattle where the fender vibrates close to the nut on the bottom of the rear rack. so I glued a square of foam door sweep to the top of the fender where they make contact
also cleaned the forks again & wiped a smidge of silicone on the shafts & seal. then covered them with Lizard Skins
rumrunn6 is offline
Old 12-29-18, 07:47 PM
  #213
rumrunn6
rumrunn6's Avatar
temps in the high 40s low 50s tops. ran out to Assabet while Wifey went to pick up her new car, all by herself. so proud.
10.06 miles
26.9 mph max
7.7 avrg
1hr 18min saddle time
1hr 30min away from house
rumrunn6 is offline
Old 12-29-18, 08:03 PM
  #214
rumrunn6
rumrunn6's Avatar
the water crossings were all passable!
rumrunn6 is offline
Old 01-05-19, 10:01 PM
  #215
rumrunn6
rumrunn6's Avatar
ran down to the Assabet again today in a nice steady rain. used the Basecamp helmet & face shield but with so much rain the shield got really messy. took the helmet cam off & tried the new helmet cover. love it!
by the end of the ride my toes were starting to get cold
on the way home
11.13 miles (did a little exploring on side foot trails not in the sanctuary)
23.7 mph max
8.3 avrg
1hr 20min saddle time
rumrunn6 is offline
Old 01-12-19, 09:49 PM
  #216
rumrunn6
rumrunn6's Avatar
got out for a cpl hrs. low 20s but sunny. ran down to the national wildlife refuge again. the Visitors' ctr was still closed due to the gvt shutdown, but the trails were open. lots of ppl out despite the cold. explored what I thought were some secluded trails but ppl were all over the place!
13.2 miles
24.9 mph max
8.2 avrg
1hr 36 min saddle time
2hrs away from the house
rumrunn6 is offline
Old 01-14-19, 05:37 AM
  #217
rumrunn6
rumrunn6's Avatar
before that last ride was looking at options for covering the helmet w/o interfering with the sport-cam velcro mount & I decided to try closing the helmet vents w/ common foam insulation I had laying around the house. seemed to work OK.
rumrunn6 is offline
Old 01-17-19, 05:03 AM
  #218
rumrunn6
rumrunn6's Avatar
Assabet 1-16-19 temps in the low 30s
9.86 miles
25.4 mph max
9.9 avrg
62 min saddle time
70 min away from house
spooky but fun. wild strange sounds echoing across the frozen ice like a giant drum reverberating with the slightest movement from animals or ice shifting
this area was too sketchy to ride thru & looked too broken to walk around. plus I was on a mission for a fast ride around the perimeter roads only
rumrunn6 is offline
Old 02-04-19, 02:50 PM
  #219
rumrunn6
rumrunn6's Avatar
Assabet 2-2-19 temps in the 20s
9.18 miles
23.5 max
6.9 avrg
1 hr 19 min saddle time
2 hours away from house
it's been an interesting few weeks of precipitation so the perimeter & interior trail conditions were not favorable for anything but a fat bike, skis, or feet. need a bit more melting of that snow pack. a nice layer of hard ice would be nice. u-turned twice before resorting to the dirt auto roads along the river
Velcro helmet mount has too much lateral wobble, so all that footage on the rough trails is torture to watch. on the smooth road, it's fine, but I think some mods are in order
had a good time anyway
I think I like the black full face balaclava w the Basecamp dark visor. 1st time riding with the snow camo jacket, kinda fun
rumrunn6 is offline
Old 02-05-19, 07:41 PM
  #220
rumrunn6
rumrunn6's Avatar
since I have three camera pivot ball quick release mounts I cut the ball & pivot off one & roughed up the bottom w a dremel & glued it to the Basecamp helmet. the hard plastic velcro patch wasn't coming off, so had to glue the mount to that. used a whole bottle of super glue gel. should be interesting. gonna try it out in 24 hrs
edit: 1st thing next day this feels strong. tried it a few times w cpl of the cams & it doesn't budge. not sure about riding tonight tho cuz my nose is bleeding & I'm sneezing like crazy w also a runny nose. feel like dirt
rumrunn6 is offline
Old 02-07-19, 05:14 AM
  #221
rumrunn6
rumrunn6's Avatar
2-6-19
Concord to Billerica & back taking almost 3 hrs! that's a record slow time! didn't even stop much. it was just sooo slow & hard riding the wet trails, Reformatory Branch & Narrow Gauge. it really is best to stay off these when the temp is so warm & the ground is so saturated
computer didn't function even tho I couldn't visually spot a problem with it. wonder if I damaged the wire on the car rack ... but I know the distances from previous rides
5:50 pm started
7:20 pm 1/2 way approx 8 miles
8:45 pm 16.1 miles back at car
(almost 3 hrs for the trip, a full hour longer than drier rides)
had several rides with the last charge on the Magicshine battery & then let it sit for a long time. shudda charged it cuz it cutout before the turnaround. used the Serfas True 255 backup light for most of the ride. glad I recently put fresh batteries in all my lights.
magic shine does a nice job off-road
this was the worst of it. it wasn't all this bad. there was still some ice so that was easier & faster. but for the most part is was a slow, arduous, slog. had to keep reminding myself not to worry about speed or length of ride, cuz I like this
new helmet mount for the cam worked great, but had to switch to the rain hat for most of the ride
funny thing about rain & bar mitts. the rain flows down my sleeves into the mitts & pools inside them but above my hands. so I had to periodically tilt them down to poor the water out!
drive-train got covered in mud & gravel. cold hear it grinding away & got consistent chain-suck when in the lowest gear front & rear. had to stop & use some water bottle water to rinse it off. when I got home I did some more of that & left it out overnight in the cold rain, then again this morning hit it with with soapy water & a brush. sounds mush better. might be time to have my local mech check the disc pads & maybe replace them soon
the plan was to wear this up top:
zip base long sleeve
fleece shirt long sleeve
thin fleece vest
rain jacket
but it seemed chilly so substituted the vest for a thin long sleeve fleece full zip top. at first it seemed right, then too warm & wound up unzipping all that I could. but that last hour, when the cold rain started, I zipped everything back up & it was just right
for legs the Novara Headwind pants under the Showers pass Transit pants was just right
started the ride with thin windstopper gloves but rode w/o gloves for the last hour. just didn't need them even tho my hands were wet from taking them out to adjust helmet or use camera. bar mitts were great
sock liner, taped hand warmer, winter sock, winter bot took care of the feet, as per usual
rumrunn6 is offline
Old 02-10-19, 05:22 PM
  #222
rumrunn6
rumrunn6's Avatar
found out what was stopping the computer from working
always crummy when something stands in the way when I'm getting ready. even worse is when wires are so tiny!
this should hold it
good to get out tho
Saturday 2/20/19 temps in the 20s but rose to 32-34 for my ride. over dressed & had to removed the cycling vest & thin fleece vest. 3 layers were fine
zip neck base under fleece shirt under Marmott jacket
fleece pants under Headwind pants
usual footwear
swapped the black, full face balaclava for the tan open faced unit
the snow covering was gone, the ground was hard, some ice in spots, flooded water crossing was shallow & one was dry as a bone! they must have cleared the culvert so the estuary could drain as designed. we had another wind storm & it showed
had dinner plans so despite it being a gorgeous sunny day I kept the ride to a modest tour around the perimeter roads & a little of the river road
12:30 left house
2:30 pm back home
12 miles
26.7 mph max (musta tucked on the hills)
8.5 avrg
1 hr 24 min saddle time
hot honey water in addition to my usual bottle of lemon water
rumrunn6 is offline
Old 02-15-19, 05:15 AM
  #223
rumrunn6
rumrunn6's Avatar
checked the GT brake pads & they are fine for now. only took the fronts out
old vs new
one side
other side
front
back
rumrunn6 is offline
Old 02-18-19, 10:49 AM
  #224
rumrunn6
rumrunn6's Avatar
a break from winter cycling for a Cape Day, w S & I
rumrunn6 is offline
Old 02-27-19, 03:33 PM
  #225
rumrunn6
rumrunn6's Avatar
took another break from winter cycling for a visit up North
gotta love Air BnB's!
wore my thin thermal layer for the head (smart wool beanie) & cycling gloves & pants
rumrunn6 is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
