Ask your small, random, track-related questions here
#4601
Quoted: 30 Post(s)
Speaking of data requests:
Does anyone know of, or have comparison data for bar width vs shape? Specifically, and I realize this is a specific use case, can you compare a 38cm round aluminum bar vs. a 40cm 3T Aeronova bar? I have the Fairwheel data set that compares stiffness measured by deflection, but nothing about actual savings in drag. Watching the Euros, and most of the high level track bunch races I see a mix of narrow bars and aero bars.
I've been told that in regards to track cycling, narrow is aero, but in this specific case, is it?
Better still, does anyone know of an aero-profile bar that's 38cm? I'm sure Scattos would be a better purchase, but: having a bit more versatility, and price are arguments against them. (See: No sphinx/alternate hand positions)
#4603
Quoted: 63 Post(s)
Example:
Ok. I have never introduced myself but... I am news photographer. I know what parallax is. In fact each picture you posted has this issue. I was actually aware of it but decided not to go with details as if you use bad samples I was sure you will not notice wrong angle on my picture(...)In fact, I used a spirit level for measurement but since I don't have more than 2 hands I took a picture without it cause it was easier to do it and I thought nobody will notice it ;-) Anyway, I just retried it with homemade "piece of proof". Again, the contact points are NOT behind the front axle.
I have a low tolerance for bull****. If my bull**** meter needs calibration, then somebody let me know.
Cheers.
#4604
Lapped 3x
This is true to a point, but what works for Rider A (more powerful) is not always a good choice for Rider B. Not trying to be nit picky, but there are difference between each rider. Now, if your looking for the strongest or most durable, then Rider A to B comparison will work. However, something that is better for Rider A, may be stronger, stiffer, etc and may work for Rider A as their weight gives it a different characteristic that may not be so good for Rider B. Think of shocks for vehicles. If I take the shocks off my 1 ton truck and put them on your passenger car, then they will not work well...they will be too stiff and not forgiving enough.
With bikes, with me weighing well over 200 lbs, my set up may be wary too harsh for a 150 lb rider and they may end up being slower as the bike is too twitchy and moves all over the track on them, which makes them slower in the end as "smoother is faster" and they can't be smooth on my bike. What is best for one track will not necessarily be best for another track due to track construction materials, radius of turns, bumps, etc.
As with all things cycling related, we invest a lot of time and money into our choices. It's good to have information, and more information helps us to make educated decisions. Information also needs to be looked at in it's proper context. Different parameters will apply to differing pieces of equipment, as well as how and who they are for. It's important to keep in mind what matters to whom and when. Some things can be true for everyone across the board. It's been mentioned before, just because something isn't the strongest, doesn't mean it's not strong enough. Then again, strongest is still strongest. How you use the information is up to you.
#4605
Quoted: 75 Post(s)
Liked 6 Times
As mentioned the Enve aero bars are quite narrow towards the front of the drops, Almost the same width as the considerably cheaper Zipp 36cm bars https://www.pushys.com.au/zipp-servi...hed-black.html
#4606
Quoted: 30 Post(s)
I think it was Zipp that came out with some data that suggested a 40cm round bar is more aerodynamic as package (with rider) than an wing shaped 44cm bar. Going from an aero 40cm bar to a round might be reasonably similar as you would possibly gain more from the positional change that what you're losing with the bar shape.
If your wallet is really weighing you down these days, you can get these ENVE aero road bars: https://enve.com/products/ses-aero-road-bar-v2/ They're 35 cm at the hoods and flare to 40 in the drops.
These Giant SLR aero bars are 38s: https://bobs-bikes.com/product/giant...r-244230-1.htm
And Bontrager offer 38s for both their alloy and carbon aero road bars: https://www.trekbikes.com/us/en_US/e...lebar/p/11292/ and https://www.trekbikes.com/us/en_US/e...lebar/p/11289/
#4609
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Just go to a local bike shop. They should have new and used options in stock as well as levers. You may need short or long reach brake calipers.
You'll want a non-shifting lever. A shifting lever from a road bike will work (if it's free). But don't pay extra $$ because you won't need to shift.
Have a look here for options. This is a common thing in the street fixed gear scene.
https://www.retro-gression.com/colle.../brakes-levers
#4610
Quoted: 63 Post(s)
I'm looking for an aero stem that can be mounted with positive angle. Something like 3T Integra or similar. Unfortunately it looks like they can are only negative angle compatible.
Seems like Look had C-STEM but they are not available anymore.
Anything in the market?
#4611
Quoted: 1851 Post(s)
Liked 678 Times
They came out with a study that it is more aero to have a -17 stem and their 25mm riser than to go with a stem that is angled up (anything less than -17) and flatter bars.
#4612
Quoted: 30 Post(s)
I was wondering how they were marketing that abomination of a bar. Riser road bars.
#4613
Elitist
Liked 92 Times
Imagine how many studies they have that say, "That old part that you can get from the corner bike shop is better than the new carbon doo-dad..." that they simply won't publish for obvious reasons.
That's why I took particular interest in the "Mavic IO vs Zipp 808" thread on Slowtwitch.
Most of us will never own most (or any) of the high-end gear we see at the highest levels of racing. So, we assume that the latest-greatest doodads are faster than normal doodads...with little or no proof. This is a reasonable assumption. But, the most reasonable assumption we should make is that the latest-greatest doodads are not slower than normal doodads.
...maybe it makes us faster because our wallets are lighter
#4614
Quoted: 63 Post(s)
https://www.bikeforums.net/track-cyc...be-height.html
Anyway, I was more interested in the esthetic overview than pros/cons ;-)
In fact, I read about the Look C-Stem and this is not an option for a regular steerer tube. It works only with specifically designed ones (provided by Look )
#4615
Lapped 3x
That's because on road/track bikes, the headtube angles are within 2-3 degrees of each other, (72-74/75). So you're not going to be far off from perfectly horizontal with a -17 degree stem. Perfectly horizontal is the most aerodynamic stem set up. Deviate from this and it gets worse the more you go. Obviously of you have a 72* head tube, then -18 is going to be perfect, and 74* would need -16. As 73 degrees is right down the middle, this is what works best.
#4616
Quoted: 48 Post(s)
Interval Training
During the offseason, those focused on points and scratch races, how much of your on the bike training is doing high intensity intervals (power zone 6, and Vo2 Max)?
#4617
None. I'll get some efforts in naturally during some of my rides, but no formal intervals. The break is psychological as much as it is physiological.
#4618
aka mattio
There's a traditional approach of taking a big chunk of time off and starting from a clean slate with a lot of endurance work and foundational miles, but I'm a proponent of a very flipped approach - that the offseason is a great time to build power, even if you're letting some endurance wither.
#4619
Quoted: 141 Post(s)
What do you mean by off-season? The reduced training after the racing season or the entire period between racing seasons? Many racers will take a break and then start building in a training season for the next racing season.
#4620
aka mattio
i got some weights goin' on now, too, and while i've heard of people who incorporate them in the season, i never tried too hard to make that work.
#4623
Bikes: Fuji Elite, 3Rensho track, Trek Madone 6.9, Specialized MTB, GT MTB, Cannondale Cad3 fixie
Quoted: 72 Post(s)
Elbows in for aero. While elbows out may make you a bigger obstacle to get around, my thoughts (with zero data to back it up) are that the cost to speed may cancel out the extra width you make your opponent travel around you
#4625
When doing a 200, I try to tuck elbows in after crossing the 100m line as it's basically hanging on from there.
