Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 02-16-18, 04:50 PM
  #4876
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 321 Post(s)
Liked 16 Times in 10 Posts
Thanks! Agreed. For fun and experience.
I think I remember the Danish race is where there is a bunch sprint every few laps and if you win youíre out and thatís your place starting from first place until top 5 is set. Dutch or Belgian is opposite, you win an early sprint you get a worse finish. But if you wait till end you may not plce at all.
burnthesheep is offline
Old 02-16-18, 06:19 PM
  #4877
700wheel
Quoted: 117 Post(s)
Originally Posted by burnthesheep View Post
I think I remember the Danish race is where there is a bunch sprint every few laps and if you win youíre out and thatís your place starting from first place until top 5 is set. ......................
Thanks - sounds like the "Win and Out" races we have at my local track.
700wheel is offline
Old 02-16-18, 06:53 PM
  #4878
carleton
Elitist
carleton's Avatar
Quoted: 1189 Post(s)
Yup. The first one sounds like a "Win and Out" where after a set number of laps, there are 3 sprints in a row for 1st, then 2nd, then 3rd places (where the winner of each lap wins that position then safely exits the track), then one more final lap for the final placements.
The race is a big gamble. You don't want to burn a match and lose the sprint because that could effectively takes you out of the subsequent sprints.
Many newbies simply burn all matches on the first bell, lose, and are a wreck afterwards for the rest of the race.
carleton is offline
Old 02-16-18, 07:38 PM
  #4879
krispenhartung
krispenhartung's Avatar
Bikes: S-Works Venge Dura-Ace DI2, KTM Strada 4000, Fuji Norcom Straight 1.3 (TT), Fuji Track Elite, BMC Trackmachine TR02
Quoted: 96 Post(s)
Originally Posted by Morelock View Post
Carleton is (mostly) right, although you CAN convert them if you really wanted to, hunting down/buying the parts is probably more expensive than just selling them and buying some brezza's/aura's
3T made the Mistrals to be a low stack bar (due to an "outcry" at the time that all their other bars had very high stack) and while parts of them (the pad position) are very adjustable, pretty much everything else is not adjustable, particularly stack.
What you have is this
[top]
pad bolts
pads
hardware mounting bolts (for extensions below basebar)
basebar
mounting hardware / extensions
[bottom]
First a caution... DO NOT add spacers BELOW the base bar. The Mistrals are not designed for that.
So your choices with what you have right now are limited to basically adding spacers between the pads and the base bar (I've done this for athletes in the past on this bar so it will work) OR buying additional hardware. THIS specifically is what you need. (conveniently out of stock) but you could also use any of the mounting brackets cannibalized off of a Brezza/Aura bar. With those brackets, the extensions AND the pads mount above the bar (like the picture I posted above) - if you do this you do lose the adjustability of moving the pads as far out as you'd (possibly) like.
If you look at the 3T AURA bar, it is exactly the same as the Mistral with the exception that it already has this mounting hardware. (and it doesn't have the little holes in the basebar for wider mounting of the pads)
Well, it's probably all irrelevant for me now, as of a few hours ago. I had my stem dropped all the way down, all spacers removed. The reason why I wanted to be able to stack the pads or pursuit bars higher was I thought maybe the drop would be too aggressive, but it turns out it is perfect. I have very flexible hamstrings and hip flexors so I'm very comfortable with an aggressive aero position on the bike, with no loss of power.
My only reason for getting some new bars now is to get a better set of pads that are not so flat, but are more curved and arm hugging....not a major deal for me now.
krispenhartung is offline
Old 02-16-18, 09:29 PM
  #4880
Nate2453
Quoted: 5 Post(s)
Carleton, I will share my experience. In my first races on the track back in the early 90s I got to watch several riders flat clinchers and immediately roll the tires off causing major incidents. Seeing that will make you swear them off. A couple of years ago I built a set of clincher training wheels and had some unsettling experiences with them. When I would turn hard on the track it would feel like the tire was rolling off the rim. I switched back to tubulars and haven't looked back.
The above said I am larger than the normal track racer, and I tend to be hard on equipment. I have seen plenty of people ride/race on clinchers with no issues, but my initial experiences of having to dodge riders who crashed due to tires rolling off of clincher rims I won't ride them on the track.
Nate
Nate2453 is offline
Old 02-16-18, 10:54 PM
  #4881
carleton
Elitist
carleton's Avatar
Nate
Could it be that tire and/or rim manufacturing techniques and tolerances are better? I recall being able to mount a new Conti tire with only hands in the 90s and early 2000s. But in the past 10 years or more, I have to fight to get them on even using shop quality tire levers. Cursing. Once I got so pissed I took it to a local bike shop and had absolutely no shame at all paying another man to mount a tire for me.
Most recently, it took me over 30 minutes to mount the two Vittoria tires on my training wheels a couple of months ago. Hands were sore afterwards.
carleton is offline
Old 02-16-18, 11:07 PM
  #4882
krispenhartung
Quoted: 96 Post(s)
I feel you there. I've driven begrudgingly to the repair shop before to have this done, and to my embarrassment had to watch a young kid mount the tire in 30 seconds. :-) Must be an art form. I had to start wearing leather gloves for this same reason. I was tearing the crap out of my hands trying to get the last 6 inches of the tire over the rim. Have you tried using a blow dryer to heat the tire up so it stretches easier? I've heard of guys setting their tires on those old fashioned radiators for a while before mounting.
Old 02-16-18, 11:29 PM
  #4883
jsk
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Don't tell my wife, but I put new Vittoria Corsa Speed TLR clinchers in the clothes dryer for several minutes to warm them up before mounting. These tires are tubeless ready (but I run latex tubes) and are particularly tough to get on. Even warmed up, I need one of these to get them on.
jsk is offline
Old 02-17-18, 04:09 AM
  #4884
Monkeyfudger
Quoted: 17 Post(s)
Don’t even talk to me about tubeless Vittoria Speed’s, I’ve been racing on the road on them for a year now.
Absolutely awesome tyres, stupidly fast and they feel amazing but damn, getting them mounted on my wheels was a complete nightmare.
Using Tyre levers on a full carbon rim had my bum hole puckering, I was sweating like I’d just come out of the sauna!! I recently had to remove the rear Tyre to replace the sealant as I’d let it go flat over the winter, didn’t have a syringe to remove the old sealant and popping the bead to pour it out like I do on the MTB is impossible....
I’m still a full noob on the track but running the new Vittoria Pista clinchers, they feel good. Weirdly I did have an inner tube blow for no apaparent reason in the car which popped the bead off the first time I used ‘em. Unnerved me a good bit but haven’t had a problem since, the tube had been sat for a long time wrapped in an old coffee bag strapped to my training bike though!
If I eventually buy something nice and aero for the front of the bike it’ll probably just be a Clincher as dealing with tubs is crap, I’d never run tubeless on the track though.
I’ve got a rear disc that I’ll eventually use on the track that’s a tub, meh......
Monkeyfudger is offline
Old 02-17-18, 11:21 AM
  #4885
krispenhartung
Quoted: 96 Post(s)
Originally Posted by Monkeyfudger View Post
Donít even talk to me about tubeless Vittoria Speedís, Iíve been racing on the road on them for a year now.
Using Tyre levers on a full carbon rim had my bum hole puckering, I was sweating like Iíd just come out of the sauna!! I recently had to remove the rear Tyre to replace the sealant as Iíd let it go flat over the winter, didnít have a syringe to remove the old sealant and popping the bead to pour it out like I do on the MTB is impossible....
Iím still a full noob on the track but running the new Vittoria Pista clinchers, they feel good. Weirdly I did have an inner tube blow for no apaparent reason in the car which popped the bead off the first time I used Ďem. Unnerved me a good bit but havenít had a problem since, the tube had been sat for a long time wrapped in an old coffee bag strapped to my training bike though!
If I eventually buy something nice and aero for the front of the bike itíll probably just be a Clincher as dealing with tubs is crap, Iíd never run tubeless on the track though.
Iíve got a rear disc that Iíll eventually use on the track thatís a tub, meh......
Noobie here as well, coming from the Time Trial and Road world. It's weird how some wheels/tire combination are such a ***** and it doesn't appear to be correlated to wheel/tire width. I have the 60mm Rovals on my Venge and use Conti Grand Prix II 23mms, and I can put those things on in my sleep with no tools. However, the original DT Swiss on my KTM road bike with the same tires were horrendous to put on, and these are all just clinchers! I noticed the DT Swiss on my BMC trackmachine were hard to mount as well, as well as my HED Tri-spoke track clincher....no rhyme or reason to it.
Regarding the gear, all I can say is that I thought it would be fairly straight forward to get into track --- 2 bikes later, aerobars, front and back disks, front and back tri spokes, power meters, upgraded seats, and minus enough cash to practically buy a new car, I'm finally ready! Good thing I'm not married. I'd be in the doghouse for AT LEAST a year after this madness. ;-)
Old 02-17-18, 12:16 PM
  #4886
ruudlaff
Quoted: 73 Post(s)
Rear wheel skipping
Iíve got an issue with standing starts where my rear wheel is bouncing up and skipping as I drive over the first half lap. Looking for ideas for reasons why. I know without video itís hard to give exacts so looking for general ideas.
One suggestion was tyre pressure as Iím running at the maximum of the tubs (215psi) which is probably excessive.
Anything else obvious?
ruudlaff is offline
Old 02-17-18, 02:36 PM
  #4887
700wheel
Quoted: 117 Post(s)
I had difficulty fitting Conti 4000 II tires on my Shimano Ultegra wheels (they are now tubed/tubeless capable) and installing tires on a fleet of track bikes.. My LBS owner showed me how to install tires, using a technique similar to how tubulars are installed, and I've never had a problem since. Also I use Vittoria ultralite inner tubes on my own bikes because when slightly inflated it has a small diameter.
Update: I searched YouTube and found this video - the first hint is basically the technique I described above.
700wheel is offline
Old 02-17-18, 03:20 PM
  #4888
carleton
Elitist
carleton's Avatar
Without seeing you, the first thing that comes to mind is that you are leaning too far forward up to or over the front wheel.
I had this issue when I was riding a 57cm frame. I now ride a 61cm. I'm not suggesting that you need a new frame. Just saying that my problem started with a too-small frame.
carleton is offline
Old 02-17-18, 06:12 PM
  #4889
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 232 Post(s)
I also immediately wondered if your bars might be too low. This has happened to me in the past as well.
Baby Puke is offline
Old 02-17-18, 06:27 PM
  #4890
ruudlaff
Quoted: 73 Post(s)
This could be a fair point actually. I have recently just went up to a 56-57 TT frame (only 5í8Ē) but it is much lower stack than my previous frame so you may be on to something there
ruudlaff is offline
Old 02-17-18, 06:51 PM
  #4891
taras0000
taras0000's Avatar
Quoted: 301 Post(s)
Are you straight arming your starts and staying over the seat for the first few strokes?
taras0000 is offline
Old 02-18-18, 05:20 AM
  #4892
ruudlaff
Quoted: 73 Post(s)
A very good question. Will see f I can find any pictures to check
ruudlaff is offline
Old 02-18-18, 05:23 PM
  #4893
taras0000
taras0000's Avatar
Quoted: 301 Post(s)
Check this page out. Same problem with a good breakdown/explanarion. https://www.lfgss.com/conversations/198624/
Old 02-18-18, 08:36 PM
  #4894
Nate2453
Quoted: 5 Post(s)
Carleton,
I think specifications for tubeless might be different than older tires, but I don't think tires have changed much from the ETRTO standards of years ago. the tight tires you may have experienced may have drifted toward the tight end of the spectrum as the wheel is at the high end of the spectrum as well, leading to a tight fitting pair.
That said after 12 years in a bike shop I rarely meet a tire I can't get on a wheel by hand.
Nate
Nate2453 is offline
Old 02-18-18, 08:41 PM
  #4895
carleton
Elitist
carleton's Avatar
Carleton,
Nate
Thanks, Nate! I've never heard of ETRTO until this post. I searched and found a bit of information.
So, how do you deal with, say, new Conti GP4000 or a Conti Trainer Tire? Any special tricks? or just brute force with super thumbs?
carleton is offline
Old 02-18-18, 09:48 PM
  #4896
JimiMimni
Quoted: 30 Post(s)
Contis and WTBs are almost always tight. The more of the bead you can get in to the rim channel the better they'll go over the rim. It won't be easy, though. Gluing Conti tubs are the WORST.
JimiMimni is offline
Old 02-19-18, 09:10 AM
  #4897
Nate2453
Quoted: 5 Post(s)
Carleton,
Don't use your thumbs, use the ridge of the pads of your knuckles to roll the tire on. For me it is like rolling my fingers into a fist around the tire. i use that ridge to grip the tire and roll the tire on.
All of the above only works if you get one bead on, and make sure the tube (slightly inflated) is centered over the rim, not half in half out. When you go to put the second bead on you have to start at the valve and work away from the valve. The valve area is the tightest area on the wheel.
Nate2453 is offline
Old 02-20-18, 09:26 AM
  #4898
theblackbullet
theblackbullet's Avatar
Bikes: I don't even
Quoted: 37 Post(s)
Nate
I'm also a larger cyclist, and I used to deal with the same issue even when using really high pressures in the tires. The solution is a wider rim. I've been using these as training wheels for my track bike and road bike and it really has been a game changer. I can run a 23 or 25 mm tire at 100psi (home track is bumpy abd lower pressure really smooths it out a bit) and they feel absolutely rock solid. No flex whatsoever. Kinlin XR31T Tubeless Ready Rim - $74.95
theblackbullet is offline
Old 02-20-18, 09:54 AM
  #4899
carleton
Elitist
carleton's Avatar
Carleton,
Thanks!
I've only felt that feeling when using a set of tubulars that had been in used for a lot of miles. I could push the tires over and see the base tape staying down on the rim but the tire would move some. It was a an almost-fishtail type feeling when diving into a turn.
The setup that I felt it on was:
- Velocity Deep-V tubular rim.
- Conti Sprinter tires that were on their 2nd season.
- 140PSI.
- 32/36 spoke front/rear Dura Ace hubs
carleton is offline
Old 02-20-18, 11:06 AM
  #4900
theblackbullet
Bikes: I don't even
Quoted: 37 Post(s)
Thanks!
- 140PSI.
Same feeling! I had an issue with the base tape coming off of a conti sprinter on my rear disc at the last pro race of the year at DLV. Felt weird taking 3,4 at 35ish mph so I inspected it. Noticed the problem and removed from the bike immediately.
