Safe degreaser for Sram Red cassette
Old 12-01-15, 08:22 AM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,434 Times in 1,187 Posts
With the colder weather here, I decided to switch from the road bike to the MTB. I gave the road bike a complete cleaning and in the process I removed the cassette. The Sram Red cassette is one piece so getting to the backside it pretty difficult. I'd submerge it in a cleaner but am concerned about the elastic bands between the cogs being damaged.
Any suggestions for a safe degreaser?
GlennR is offline
Old 12-01-15, 08:34 AM
TheRef
TheRef's Avatar
Quoted: 122 Post(s)
Liked 13 Times in 8 Posts
Dump in a bucket with Dawn dish soap and warm water.
TheRef is offline
Old 12-01-15, 08:39 AM
rpenmanparker
rpenmanparker's Avatar
Quoted: 6556 Post(s)
Liked 58 Times in 36 Posts
Elastic bands? WUT?
Cleaning the backside of that cassette is unnecessary. No grease can get in there.
Robert
Originally Posted by LAJ
No matter where I go, here I am...
rpenmanparker is offline
Old 12-01-15, 08:58 AM
GlennR
On Your Left
GlennR's Avatar
Originally Posted by rpenmanparker
Elastic bands? WUT?
Actually it does, there are small holes where it can get in on the larger cogs.
GlennR is offline
Old 12-01-15, 09:16 AM
rpenmanparker
Sorry, my older model ones are solid front and back.
Robert
Old 12-01-15, 09:18 AM
cale
cale's Avatar
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Liked 4 Times in 4 Posts
I'm with warm soapy water and a flossing rag. When I find myself trying to blow out trapped grit, I know I'm done.
cale is offline
Old 12-01-15, 09:21 AM
rpenmanparker
Trouble is, even with an excellent degreaser like mineral spirits, you need some agitation to get everything off. Without the ability to get inside there, it will be hard. I recommend degreaser of your choice in an ultrasonic bath. That should do the trick.
Robert
Old 12-01-15, 09:23 AM
cale
cale's Avatar
Is it safe to put volatile solvents in a ultrasonic cleaner?
cale is offline
Old 12-01-15, 09:33 AM
series1811
Bikes: 2015 Cannondale SuperSix EVO 105, 2012 Fuji Roubaix, 1988 Basso Gap
Why bother cleaning? That cassette looks pretty clean to me.
Seriously though, Berryman Chem Dip.
series1811 is offline
Old 12-01-15, 09:35 AM
WalksOn2Wheels
Vain, But Lacking Talent
WalksOn2Wheels's Avatar
Bikes: Trek Domane 5.9 DA 9000, Trek Crockett Pink Frosting w/105 5700
Quoted: 1525 Post(s)
Liked 81 Times in 42 Posts
I would see if you can get a hold of the "aerospace" simple green which is just simple green without the stuff that can corrode metals. I just use the regular stuff and properly rinse my parts, but for an extended clean, it would be fine and certainly wouldn't harm any plastics or rubber.
For regular on the bike cassette cleaning, I prefer White Lightning Clean Streak, but I honestly don't know what it may or may not do to plastics and rubber. I know it is safe on paint, so it could be fine, but the simple green would probably be a safer bet if your're worried about it.
WalksOn2Wheels is offline
Old 12-01-15, 09:43 AM
GlennR
On Your Left
GlennR's Avatar
I'm more concerned about the rubber isolator (bands) between the cogs.
Dawn and warm water sounds the safest.
An ultrasonic cleaner would do the trick, but not sure i want to send the $$$ to have one.
GlennR is offline
Old 12-01-15, 10:06 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 679 Times in 430 Posts
I use Simple Green. Spray it on, let it sit, then hose it off with some pressure. Works fine for me.
topflightpro is offline
Old 12-01-15, 10:20 AM
corrado33
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Oh a SRAM Red? You're in trouble. They're made of a new high Thallium alloy. You can only use water on those things, everything else will make it melt.
corrado33 is offline
Old 12-01-15, 10:28 AM
jtaylor996
INSERT_TITLE_HERE
jtaylor996's Avatar
Bikes: 2016 Cannondale Synapse 105, 2016 Salsa Pony Rustler X01
Quoted: 3053 Post(s)
Liked 66 Times in 38 Posts
How dirty does a RED cassette have to get to weigh as much as Shimano?
jtaylor996 is offline
Old 12-01-15, 10:45 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Using Simple Green in an ultrasonic bath is the way to go.
$78 at Harbor Freight.
Ultrasonic Cleaner - 2.5 Liter
TimothyH is offline
Old 12-01-15, 10:51 AM
GlennR
On Your Left
GlennR's Avatar
Yes... I realized that and purchased a 3 liter for $70 (shipped) on ebay.
I do vintage Volkswagen restoration and I can use if cleaning small/medium parts.
GlennR is offline
Old 12-01-15, 11:04 AM
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1242 Post(s)
Liked 94 Times in 65 Posts
Elastic bands? WUT?
SRAM claims they reduce noise and vibration
joejack951 is offline
Old 12-01-15, 11:16 AM
WalksOn2Wheels
You mean that stuff you use to clean carb parts that specifically says not to put plastic or rubber in there? Did you read his entire post?
Old 12-01-15, 11:43 AM
Midwest Ullrich
Midwest Ullrich
Quoted: 5 Post(s)
My work place has the Harbour Freight ultrasonic cleaner. I am not impressed by the cleaning results. Could be the lack of wattages...just can't shake out the tough grease.
Midwest Ullrich is offline
Old 12-01-15, 11:48 AM
BoSoxYacht
BoSoxYacht's Avatar
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
They do work well for reducing noise, but are totally unnecessary for Campagnolo and Shimano.
BoSoxYacht is offline
Old 12-01-15, 03:18 PM
rpenmanparker
Depends on the flash point I guess. But I had no idea there was really rubber in that cassette until just now. What is the world coming to? I don't guess I would use an organic solvent with rubber bands like that. Of course I would probably just remove them and throw them away as soon as I got the cassette. I have never had a problem with Red cassette noise since switching to KMC chains.
Robert
Old 12-01-15, 03:40 PM
WalksOn2Wheels
True irony is that there are probably lots of these ultra quiet SRAM Red cassettes on Chris King freehubs.
Old 12-01-15, 03:53 PM
series1811
Can't remove the rubber parts before cleaning?
Old 12-01-15, 04:03 PM
WalksOn2Wheels
You know, I never thought about that. Not sure if it's possible, though. I can't remember the last time I had one of those cassettes in front of me. But presumably, they had to be stretched onto the cassette, I don't see why they couldn't come off.
But to be honest, we're all massively overthinking this. @TheRef was right with the first reply. Warm water and Blue Dawn. Add in a stiff brush for scrubbing. Done.
Old 12-01-15, 04:10 PM
TheRef
TheRef's Avatar
Quoted: 122 Post(s)
To ne fair I never said Blue. Any oclor will do!
TheRef is offline
