Marking puncture on tube
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I carry spare tubes and use them too, but isn't this thread about marking the location of the hole so you can find it when you get home? Is carrying a sharpie on the road really necissary for that and if you are going to patch then why not just locate the hole by pumping the tire?
-Tim-
-Tim-
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Liked 2,981 Times
old fashion orange, yellow, or white crayola crayon.
-Oh Hey!
-Oh Hey!
Sharpie or a pen. I put a line about an 1 or so inch away on both sides of the hole. The glue and patch get applied centered in between the lines. Being about an inch away still allows me to scuff and glue and the lines are usually still visible. When I am done, if the patch is close to centered between the lines, it was a success. I don't carry a pen with me on the road but my on road patch kit is skabs and they are easier to finger over the hole and just slap on.
Other things.. I place a X on the left sidewall of my directional tires with a gold or silver sharpie. This helps to quickly identify the right mount direction. Seems obvious but sometimes on the fly, when it's dark etc.. It is just quick and easy. I also mount the tire with that X centered on the valve stem. It allows for easier correlation of the hole in the tube to the relative position of the tire for finding the source or cause. I refresh the X occasionally but it seems to last 6+ months easily.
Quoted: 4420 Post(s)
Liked 1,568 Times
I don't understand why you can't see the hole after you've put some air in the tube. But ball point does work great.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Silver Sharpie (gold sharpies are useless, quite dark, not very visible on just about any surface.)
Four lines pointing to the hole, far enough out that the scuffed tube or the patch won't cover them. It's often not easy for me to see the hole after the rubber cement has been applied. The marks make it simple to center the patch.
I also mark new tubes with an arrow near the valve, and install them with the arrow in the direction of travel. The tire is mounted with the label next to the valve hole. Now I can quickly line up the flat tube with the tire after I find the hole, and don't need to look that far from the valve in each direction. I only need to examine a few inches of the tire for embedded slivers.
Silver sharpies are great for marking dark painted bike components -- like the bars near the stem clamp, or the seatpost, when doing setup adjustments. The marks easily wipe off with drugstore rubbing alcohol.
I have a lot of uses for these markers, other than just bikes.
Like the above comments, I keep punctured tubes until I have 3 or 4. Then patch all at once, with a fresh tube of glue. So the marker works for me. My flats are many months apart, so an opened tube of glue never lasts long enough between times.
vintage Bianchiist
Bikes: Bianchis, 84 Superleggera, 86 Giro, 87 SportSx, 87 Campd'Italia, 87 Limited, 88 Proto, 95 TSXChorus, 94 TSX105/DAax, 94 Super Grizzley RC, 94 Genius Record, 06 Pinella Boron, 18 Volpe Avanti, 00 Megapro ST Veloce00 EM Strada OS
Quoted: 35 Post(s)
Liked 13 Times
So, I always patch my flats. A lot of the group riders just buy new tubes! Never had a problem with a patched tube. HOWEVER, I do have a problem with after I find the hole, marking the spot so I can patch it!....I've tried pens, felt tipped markers, pencils, you name it, can't find anything that marks the tube so when I take it to the kitchen table to prep the hole I know where it is........What do you guys use? Went to Walmart and a car parts store, nope, they don't have anything.....
Thanks
Lloyd
Thanks
Lloyd
White electrical tape. Just put a small piece over the hole, when you find it.
Location: Was born and raised in Philadelphia, PA. For the past 30 years we have been living in Fort Smith, AR
Bikes: Two road bikes, Zanes and Specialized.
Quoted: 31 Post(s)
I carry a spare tube and a tiny repair kit, all the puncture repair kits here in the uk (all the ones i've bought anyway!) include a small cube of chalk, a few different sized patches and a small tube of glue, i add a postage stamp size bit of sandpaper and it's good to go if i'm unlucky enough to have used the spare tube and get another puncture.
The kits cost about £1 so if you've used the glue once throwing it away for another kit is simple enough.
Quoted: 31 Post(s)
Quoted: 31 Post(s)
Bikes: 2012 Soma Saga, 2020 Black Mountain Cycles MCD, 1992 Univega Alpina Sport
Quoted: 7 Post(s)
i use a ballpoint pen which shows up decently under a good light regardless of the passage of time. One thing i'd like to pass along is that instead of circling the puncture, i draw a big and wide "+" through the hole. That helps me center the patch in case i didn't make a big enough circle.
Black sharpie. I wonder why tubeless is so popular?
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Sidebar, but for me the big plus of tubeless is really the fact that sealant means I don't have to worry about goatheads on the trail anymore. For my road/commuter, I just squirt some sealant into my tubes.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
It's almost as de rigueur as disc brakes in the MTB world
Quoted: 811 Post(s)
Liked 1,024 Times
I am surprised to find that someone else uses toothpicks too. If I don't have toothpicks handy, a ball point pen or my thumb.
Not fringe. Most every mt bike sold can be set up tubeless. Fat bike too. Need tubeless ready rims and tires. Seem perfect application for those cross bike types. 1 flat in 4 years for the mt bike and fat bike. No pinch flats, no flats from thorns either. No tubes. Works really well for me. YRMV.
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Never had 3 flats yet, but 2-3 rides with 2 flats. 2 tubes, 2 C02s, and small pump (water bottle cage mounted), and 2 self-adhesive patches in my wallet. The self-adhesive patches and pump are for the mythical 3rd flat. The pump has also been useful for the newbie group riders who only brought 1 C02 and didn't know to check/clean their tire for what caused the original flat.
-Tim-
-Tim-
Quoted: 505 Post(s)
Liked 639 Times
Thanks
Lloyd
Thanks
Lloyd
It's MY mountain
Liked 2,982 Times
Originally Posted by neverquit
P.S. Some people previously mentioned using silver-colored markers, but ordinary red or green marker works perfectly fine as well.
