Pressure inside a CO2 cartridge?
If it'll pump up a 23C to 130#, it's gotta be around 2000 psi. Just guessing, the tire looks about 15 times the size of the cartridge. Does anybody really know?
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
The pressure of CO2 is dependant on the ambient temperature. The powerlet holds 12 grams of liquid. IIRC, at around 70* the powerlet should be at around 700 or so PSI, less when colder, more when hotter.
Quoted: 12 Post(s)
If it were air, then yes. It's CO2, so no. Like Punkcat says, it's 700-800 PSI +or- depending on temperature, and mostly liquid. That's why your inflator will start spitting dry ice if you turn it upside down.
gmt
Quoted: 45 Post(s)
CO2 and Pressure
CO2 is a gas at temperatures above -69.9 degrees F and 60.4 psig (pounds per square inch gauge). It is a very complex compound with the ability to sublimate (change directly from a solid to a gas without becoming a liquid) as just one of its unique properties.
At 70 degrees F, CO2 obtains a gas pressure of 852.8 psi when confined in a vessel. If there is more CO2 in the vessel, it will be have to be in liquid form. So, the state of CO2 in a pressure vessel, such as a powerlet at room temperature, is a pressurized gas above a liquid. If the gas is released, such as through the operation of an airgun valve, some of the remaining liquid flashes to gas until the pressure is equalized for that temperature.
source
source
Certifiable Bike "Expert"
Bikes: Cervelo RS, Specialized Stumpy, Schwinn 974
I use a Road Morph. The pressures read in segments. I have Innovations inflator, I have no idea what the pressures are, you have no idea what their pressures are. If you use Innovations without guage, you are before Neanderthaal.
Quoted: 12 Post(s)
Liked 5 Times
More precisely, the expansion of the CO2 is effectively adiabatic (without transfer of heat because it happens fast enough), so the gas itself cools down as it expands on its way out of the cartridge. And it can get cold enough to freeze up.
Uber Goober
"When it expands enough heat is absorbed from the nozzle area to freeze the liquid as it flows out."
I think some of the liquid vaporizes which cools the remaining liquid off until it freezes, it doesn't need to have heat absorbed from outside.
Quoted: 4260 Post(s)
Liked 1,366 Times
Google is a quick (and better) source of an answer to this.
https://www.justanswer.com/questions/...-co2-cartridge
So why wouldn't this happen if you held the cartridge right-side-up?
We are confusing chemistry here now. If you hold the cartridge right side up, it will still freeze. The gas expanding from a high to a low pressure causes a temperature change (joule-thompson effect).
If you hold it upside down, that same effect occurs. But if it's upside down, the liquid CO2 comes through the valve (because it's more dense than gaseous CO2) and flows to the lowest point.
If I discharge an upside-down CO2 cartridge, will I make more solid CO2 than if I discharge an upright cartridge?
Burning Matches.
Quoted: 4077 Post(s)
Liked 1,002 Times
All things being theoretical, they will have the same amount of solid CO2 (assuming there's any solid CO2 at all). The one held upside down will spit more of it out.
All things being theoretical, of course.
ElJamoquio didn't hate the world, per se; he was just constantly disappointed by humanity.
So you're saying if I discharge a CO2 cartridge with it held upright, "it will still freeze" (solid CO2 will still be formed.) Does this solid CO2 stay inside the cartridge, or does it get blown out?
If you discharge a CO2 cartridge upright, the temperature will get lower...enough to get your hands cold and probably below water's freezing point...but not below CO2's freezing point.
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
Extra credit question: What about if it above 88 F?
OK, so Quel says the cartridge doesn't make solid CO2 (dry ice) if discharged upright (it will "get damn cold", though). What about if it's discharged upside-down?
achoo and ElJamoquio say that the CO2 cartridge will make a roughly equal amount of dry ice regardless of orientation, but the dry ice remains hidden inside an upright cartridge. (Although ElJ hedges that this is a theoretical answer.)
Is that the correct scorecard so far?
Me personally, I don't know what happens, but I have found the explanations, up to this point, to be unsatisfactory.
The CO2 inside the canister is liquid, so when upside-down, some of that will flow out (gravity) before it can turn into a gas. CO2 doesn't turn solid at room temperature until you get to very very extreme pressures, much much higher than you can get with these containers (much higher than large scale chemical reactors run for that matter).
Quoted: 12 Post(s)
Elite Fred
Quoted: 60 Post(s)
Liked 42 Times
I think that I will use this question as a lecture example next time I teach introductory thermo.
