Shimano 3 speed hub
Shimano 3 speed hub
I am refurbishing my 38 year old Moosburg 3 speed internal hub touring bike. It has not been ridden in 25 + years.
I have cleaned, lubed and polished the front hub and fork, front calipers, replaced pads. I am now to the back hub. The markings are chicken scratch and a Patent #, which leads to Shimano, likely a model 333 based on age and one article. I am familiar with the old Sturmy Archer AW hub, which I could rebuild blindfolded - 50 years ago! What I found on the 333 hub is not serviceable..
1. How do I service this hub? Are the bearings removable? Do I just add oil and clean the exterior?
2. The chain is in great need of a good cleaning. Somewhere I read to never reuse the master link. Is this true?
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
If your 3.3.3 hub has an oil port, add a little light oil. Likely it's gotten gummy inside from age and disuse. Use it and see how it works- likely it doesn't need anything.
Back in the day I would overhaul Shimano and Sturmey-Archer 3-speeds just for fun.
Many new master links for derailleur chains aren't reusable. On your chain it's OK to reuse as long as you like.
Jeff Wills
Jeff Wills
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
