Lend me your eyes...
Need an assist from some eagle-eyed N+1 enthusiasts. There's Centurion Pro Tour nearby (but not that nearby) that's caught my attention. The listing doesn't mention a size, what would you guess based on the head tube size?
Any sizing help would be appreciated. (And not mentioning this to the person to whom I'm related by marriage would be greatly appreciated.)
Likes For d2702:
Likes For Piff:
Quoted: 1303 Post(s)
Liked 1,912 Times
+1 on Piff's assessment. Smiles, MH
Quoted: 469 Post(s)
Liked 2,443 Times
53-54cm
Edit: take a look at the Pro Tour in the attached thread below
https://www.bikeforums.net/classic-v...onversion.html
Likes For Roger M:
Likes For Reynolds:
I’ve seen that listing. For what it’s worth the seller states in the ad that it’s a 48cm small/medium frame.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
53-54cm
I have a couple pro-tours with head-tubes that size, and they’re both 53.5
Likes For panzerwagon:
Quoted: 394 Post(s)
Liked 346 Times
53, maybe 54, center to top. I have an '83 Pro Tour that measures 55 ctt and the space between the top and down tube looks about 1 or 2cm more than this one. (this one being the one we're talking about in post number one)
Likes For Hobbiano:
Quoted: 3464 Post(s)
Liked 2,831 Times
‘this shows centerpull brakes and near midpoint pad adjustment, why I think a bigger frame. If the bike had short reach brakes, then 52 ctc would be I think a decent guess.
‘Japanese bikes also tended to have higher bottom brackets until the top tier models, that could argue a smaller frame, but often those bikes had longer top tubes to make the dimensions work better for no toe overlap.
this image is marginal to nail the size.
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
53 - 54 cm, based on Centurion sizing methods.
I'm going to say 56. That's way off what others are saying ... but just looking at it in cold blood, that's what I see. On a 56x54 frame, a head tube can vary as much as a centimeter.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Does the listing identify the wheel size? I've been fooled by 650c wheelsets before.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
47!
Likes For SurferRosa:
Passista
Quoted: 868 Post(s)
Liked 721 Times
52 c-c was my guess, but forgot some use c-t, in that case it should be 53/53.5.
Likes For Reynolds:
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
Mmmmm, why would you not ask the seller? You even indicated you know who the seller is. Go look at it with a tape measure perhaps.
You’ve had experienced cyclist guess from 47-56, clearly a picture of the headset exclusively makes it difficult determine. One responder even says hey saw the ad and claims the ad says it’s a 48.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
SurferRosa
FWIW I'd say 53is Ask them to measure the standover height for you and send a pic of how to do it. It's much simpler to explain to a novice then the whole center to center seattube bit.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 999 Times
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I was wondering when someone would bring up the crucial question of c-t vs c-c dimensioning.
Likes For John E:
Bianchi Goddess
Liked 2,928 Times
That's why I usually ask a seller just to measure the standover height, it standard measure and much simpler to explain
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1226 Post(s)
Liked 3,555 Times
53 c-t-c
There were 135 Confentes, but only one...Huffente!
