Thoughts on two winter bikes - one studded / one "winter" tire
Quoted: 286 Post(s)
Liked 262 Times
Riding in the winter I usually use my cross bike with disk brakes, and I run it with 37mm continental winter tires (no studs). I tend to ride only when the roads are somewhat clear, though I often ride over small patches of ice and long sections of well packed snow. So long as I'm careful, I'm confident and have been able to stay upright. I have a touring bike and was thinking of using it more frequently in the winter, with these conti winter tires, and then getting studded tires for the cross bike. Compared to the winter riding I'm already doing (mentioned above), will the studs allow me to ride when there is more snow, or when there is more likely icy sections, or that slippery snow after it has been packed down and crusted a bit? I'm wondering if it's worth my time/money going the two-bike route (fwiw - I live outside Toronto).
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Studs don't help unless there is enough ice, or hard packed snow to allow the studs to dig into something hard. Then they rock. In other words soft snow or slush is about the same as knobbies. I do use two bikes, one spiked, one with knobbies. Been doing it for at least 10 years. It sure beast changing tires. But, when in doubt, use the studs.
If there is hard, cold, flat ice that is big enough, you will fall without studs eventually. That kind of ice makes stud traction about the same as riding on hard dirt. Really great.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Studded tires help on a completely iced-up surface and hardened snow. They also facilitate grabbing solid surface through crudded up snow. Once there is a thicker layer of softer snow, studs don't do much but a pronounced thread helps quite a bit. If you have Conti Winters, I would skip lightweight studded tires and go for aggressive with a pronounced thread. Myself, I swap tires on one bike which is tedious. Being resigned to swapping gives you though more options, such as front studded and rear Conti Winter.
Without studs there WILL come a time when you'll go down, guaranteed; there will be a small patch of ice hidden under the snow, etc.
Personally, I'm more than happy to go to the extra expense of studded tires because it's a heck of a lot cheaper and easier than dealing with broken bones.
Knows the weight of my bike to the nearest 10 pounds.
Quoted: 286 Post(s)
Liked 262 Times
I live right across the lake in Rochester.
Thanks
This thread has convinced me that I am going to buy studded tires. Right now I'm liking the Schwalbe Marathon Winter tires (700x40). I like them over some similar options because there are also studs on the outer part of the tire, that should help with cornering. They are pricey, but more of an issue (maybe because it's mid-summer) is they're hard to find...
Thanks
Thanks
Quoted: 5224 Post(s)
Liked 3,585 Times
just put studs in 1 bike
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I've decided to go the two-bike route this winter. Last winter I managed okay with a fixed gear beater with cross tires, but I also stuck to main streets that had been plowed.
If my previous experience with studs holds true, the second bike will allow me to better navigate the side streets and trails, which don't get plowed and end up with hard packed snow. I figure the non-studded bike will serve its function in sloppy, gross, wet wintery conditions, while the studs will be better for packed snow and the crazy sheet of ice that appears early in the spring.
Quoted: 4227 Post(s)
Liked 2,488 Times
Liked 2,488 Times
10 wheel tractor trailer rigs and 2 wheel bikes are different Genus & Species.
seemed when even colder there truck was less needing Chain-ups.. on flattish highways ..
got my Nokian studded tire bike waiting in the basement for the potential week, only.. of ice out here ..
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
I'm in Ottawa: I've used studs for years, and switched to Conti winters last year: they worked alright for most days, and certainly have a smoother ride. But then we got into the freezing rain, followed by a cold snap and I went back to my studs. Loose snow covering ice is too hard to see coming! later in the year I went with a spiked front and conti on the back, and that seemed like a fair compromise.
Urban winter biking is fairly hard on the equipment, so I kind of think the trouble of switching wheels is a fair trade-off for not having to de-gunk, de-salt and re-chain 2 bikes.
I have a dedicated "ice bike" with studs and a "rain bike" with winter tires and ride them both during the winter.
For me it is more of a hassle to switch wheels and I just clean/lube both bikes once a week (vinegar and water mix works well for getting the salt off).
OP if you choose the 2 bike route be mindful that black ice can be anywhere and if you hit it you can go down quick riding a bike without studs.
I have four sets of studded Schwalbe tires and two sets of the Conti "studless" winter tires for three bikes I tend to ride in the winter. When things are really icy, my 29 x 2" studs on my longtail utility bike are by far the most stable choice (that bike with studs is a tank in the snow).
With patchy ice and bare pavement, my favourite combo has been a studded tire up front for solid cornering and a studless tire in the rear to reduce rolling resistance. It is less likely that your rear tire will slip out from underneath you, especially with the extra weight over it, but if it does, it is a lot easier to recover than if you lose a front tire. So I think it is a great compromise. Been riding that way the last three winters here in Calgary, and it has worked out great.
By the way, it is pretty easy to replace studs in the Marathons -- I have lost a few, but found a nifty tool to replace the studs (unfortunately, it has no brand name on it) but I think Nokian makes one too.
Fahrradfahrer
Bikes: n+1
Nokian studs, front and rear. 140 bucks in tires is way cheeper than medical bills or going down in traffic on a dark winter road surrounded by grumpy sleepy drivers. The studs don't help at all in snow as far as I can tell. We don't usually get warm enough up here (Anchorage, Alaska) to need a rain bike in the winter. Even if it does rain, the streets are still frozen, and it immediately turns to ice. Be careful when you put your foot down.
I've so far resisted getting a fat bike for snow days, but think I might put one together for this year as it can be a !@#@ to get in when it snows, and I'm tired of carrying my bike through deeper sections, and can't find a good route to ski in from where I am living now (whine, whine, whine).
Quoted: 48 Post(s)
Liked 31 Times
Syracuse NY. I also have an ice bike and a normal bike. I'm done with the icebike though. The days that I need the studs and lower gr are so few that I'd rather just ride the bus than have a second bike sitting ready by the door. For how much I spent on just tye tires I could have paid for all of those days and four more winter's worth of bus rides. Kenda Klondikes going onto craigslist soon.
Jedi Master
Only have 26-1.9" tires..
Nokian Mount and Ground W 160 stud tires are fine where there is a Mix of dry frozen and refrozen rutted Ice ..
there is enough rubber for the bare spots & studs for traction on Ice.. (mine bought in 1990 are still serviceable.. not lost a Stud yet )
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Winters where I live are mild, so this winter, for smoother ride, I'm considering puting studded tyre up front only, with rear tyre just some standard knobie tyre. Then get a cheap spare fron wheel, with regular tyre on it and swap every morning according to road conditions, keeping the rear knobie until the spring.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
When winter hits, I just suck it up and commit to studs until spring. I run into enough mysterious icy patches in the road (or trail) where I live that I can't count on roads to be dry and clear, even if it hasn't precipitated in a while.
IOW, quit being weenies! Studs will make you stronger for the spring.
Bikes: Salsa Beargrease Carbon, Sette Razzo Carbon 29er
Quoted: 15 Post(s)
Liked 5 Times
This is an interesting thread. I've been giving a lot of thought to riding in the Winter - mostly Park trails but some roads also. I was under the impression that a fat tire bike was the safest and most reliable option particularly riding on fresh snow, but from what's been said above, studded tires are a viable option too. That's sure as heck a lot cheaper than a Fat Bike.
As a point of interest, my LBS let me ride a Trek Farley 4" around the block today, just on the road....but I was mightily impressed with the way it picked up and handled and glided over the potholes. That's one heck of a nice bike!
Bicycle Repair Man !!!
I ride 3 bikes in the winter... two are studded front and rear and the other rolls on 2.1 knobbies for periods when ice is not a concern.
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
Alot depends on the conditions of your commute. Usually the roads in the GTA are salted so much that the roads are dry most of the winter. For those days I ride my cross bike with 32mm tires. When it is slushy/light snow cover I ride fixed gear with 25mm tires. When ice is a concern I have 35 mm marathon winter tires on my 29er. If I had only one bike and one set of wheels i would use the studded tires through winter. I did swap wheels one year but the rims were different sizes and it was a PITA to adjust the brakes every time I swapped. In theory a second set of disc wheels should not be an issue to swap out as long as the rotors line up the same in the calipers.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
Bikes: 2014 Genesis GS29 (Yellow Fork)
Incorrect. As ice gets colder, it gets grippier. You'll hear olympic downhill skiers complain about cold ice because they can't go as fast. Skating rinks keep their ice surface just over freezing because wet ice is just about the most slippery thing around and slippery is fast (for skates). But what is good for skates is awful for wheels. Barring the change in scenery and chill factor, you wouldn't notice any difference between riding on pavement and -40* ice.
