Doubler brake lever, opinions?
Bikes: Lemond Zurich, Felt Brougham, Surly Cross Check
A newbie, in fact I think this is my first post.
I recently bought a used Felt Brougham that I've been riding the heck out of, but want to make a few changes.
I want to change my riser bars to Nitto RB001 bullhorns and bar end brake levers seem very cool. The web site that has the Nitto bars sells Tempra Doubler brake levers, so one lever controls both brake calipers. Seems like a cool concept, but I'm wondering if anyone has tried them and how well they work.
I tried the forum search function but it doesn't seem to work.
Also, does anybody have experience purchasing from Track Supermarket?
Thanks!
Thanks!
Calamari Marionette Ph.D
Having the ability to operate the front and rear brakes individually is a vastly superior option. VASTLY.
Quoted: 4806 Post(s)
Liked 3,932 Times
Operating front and rear brakes from the same control that doesn't have an anti-lock feedback system like a car has major problems for bikes. Say the set-up brakes the font 60% and rear 40%. Fine for a gradual stop. But a pedestrian steps n front of you, you hit the brake hard and your weight is thrown forward on to the front wheel and lifted off the rear wheel. With any rear braking at all, never mind 40% of the total, the rear wheel will lock up since there is little weight on it.
I believe most of the dual control levers are used for tandems where it may operate both a rim brake and a drum brake. With two rim brakes and a drum brake, you are starting to run out of hands.
Ben
Ben
Bikes: Are awesome!
Bikes: Nashbar SSCX
Unless you only have one arm/hand, I'd suggest running both brake levers. I know a lot of people here run no brakes at all or only a front brake, but if you're planning on putting a brake on each wheel, run a lever to each.
I've actually done this with a single speed conversion and it worked surprisingly well. I was able to use barrel adjusters to modify when the brakes engaged, so a 1/4 pull would brake light on the rear wheel and not touch the front, a 1/2 pull would brake firm on the rear and light on the front, a 3/4 pull would brake hard on the rear and firm on the front, etc... it was actually quite nice. I used the Paul Comp. one, however.
Fresh Garbage
Sounds like it will take no effort to lock up the rear wheel in a quick stop situation. No bueno
Also, how do you not fall off that saddle when you ride?
I never had an issue locking up - although I only had this bike for a few months. This photo was taken when it was ~ 30 degrees out and not riding.
Bikes: ones with two wheels
Quoted: 5 Post(s)
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
One of the new Fuji Crossturds (Towns) has one lever for both brakes and at the shop we install special power modulator noodles to make the front brake almost not work just so nobody kills themselves on it.
Doubler type brake levers are a bad idea unless you are disabled in some way and have issues operating two different levers but it doesn't sound like that is you. If you can operate two levers you should get two levers it will vastly improve your braking. People who put one lever on TT bars are silly as it looks very odd. I have two different levers for two different brakes and it looks much cleaner and sensible. If you are super concerned about looks the S500 levers from SRAM are pretty skinny, look clean and aero and work quite nicely.
spesseh
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
4
04-28-15 05:06 PM
