1986 Trek 770 restoration or run?
Quoted: 189 Post(s)
Liked 475 Times
I picked up this 1986 Trek 770 recently and later discovered that the seat lug is cracked. It appears that a previous owner jammed in a too-large seat post. The paint is roughed up about everywhere and the components are an incredible mish-mash.
So...is it restoration worthy, or do I run away?
Actually, the options are 1) attempt a restore myself or 2) send to someone else to restore.
SE Wis
Quoted: 2751 Post(s)
Liked 3,408 Times
I might have a seat lug for it.
From a 1987 400 531 frame, 21"? frame
You can look in the Trek Brochures and see if the frame angles are the same or close.
https://www.vintage-trek.com/TrekBrochures.htm
Quoted: 1225 Post(s)
Liked 630 Times
I remember seeing a forum member treat an identical crack by simply drilling a small hole at the end of the crack to stop it.
Likes For GrainBrain:
Quoted: 394 Post(s)
Liked 346 Times
My guess would be to drill a hole at the end of the crack like others have said. It seems like as long as the seatpost was the correct size, the seatpost clamp bolt would prevent it from getting any worse.
Quoted: 1873 Post(s)
Liked 692 Times
There's no harm in drilling it and riding it till either it cracks worse, or nothing happens at all. Easy decision.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Quoted: 754 Post(s)
Liked 737 Times
If you drill the hole a little lower and carefully file down to it, no one will ever know...
If the object were to keep a beater operational a short time, then drilling a hole would be fine.
Assume the @#$%^ idiot who rammed in the oversize post has abused the bike beyond your imagination. Ramming in an oversize post is really hard to do. You are going to find one problem after another. There is no cure for idiocy.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
I would go with the vast majority of opinions voiced here...Drill&Ride..I'll add enjoy, very unlikely it will have a catastrophic failure.
Ben
Ben
Quoted: 1609 Post(s)
Liked 2,216 Times
Oh BTW, Nice find!
Seńor Member
Quoted: 1497 Post(s)
Liked 1,099 Times
+1 on drill, restore and ride. Enjoy the bike, it's meant to be ridden!!
aceves
aceves
It might be from a proper-sized post that was not inserted far enough and then ridden. Also note that these could have been ordered as frames and then equipped as the buyer wished. It's the same materials and dimensions as a 760 frame, but with different paint and decals.
Either way the bike has been abused. Abuse is seldom isolated. To easy to see a project that snowballs. A full and correct repair with new lug, new seat tube, new paint, easily exceeds imaginable value of bike. Who would want to take on that frame repair? Start over with a more promising frame.
If the only object is to cruise the neighborhood have at it.
Seńor Member
Liked 1,099 Times
Sure, that sounds plausible. Correct post would be 27.2 and 27.4 is not common.
SE Wis
Liked 3,408 Times
Looked around. Have the BB shell, brake bridge, DT mounts, headtube & lugs.
Didn't find the seat cluster lug. I must have turned that into a keychain and gave it to someone.
Likes For crank_addict:
Drill and ride. That was one of the best non italian racebikes back in the day. Concor saddle?
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Edumacator
Quoted: 2475 Post(s)
Liked 3,203 Times
Weld of glue the post in and enjoy...no need to ever take it out again...
Unfortunately it's not worth a ton of money. Fortunately, you own one of the best riding bikes ive ever swung a leg over. Just ride the heck out of it.
Quoted: 2367 Post(s)
Liked 1,756 Times
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 339 Times
Likes For mechanicmatt:
Quoted: 394 Post(s)
Liked 346 Times
In previous years the 760 & 770 were the same frame, while the 560 had a longer wheelbase, slacker angles, and used Reynolds 501 for the main tubes.
I have an '85 560 and an '84 760. Totally different riding frames. The 760 is much more lively, imo. I haven't ridden one of the later 560's built with Reynolds 531.
Likes For Hobbiano:
Quoted: 660 Post(s)
Liked 601 Times
The 760 & 770 had a different frame then the 560. In '86 the 560 had a main triangle of Reynolds 531 and forks and stays of chrome moly. The 760 and 770 had 531 main tubes, fork, and stays. In '86 the 560 & 760 shared geometry and the 770 had shorter wheelbase and slightly steeper angles.
