Viscount BB conversion question
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
So for you Viscount nerds: Has anybody taken an old BB and crank from a Viscount and put it in a normal bike? Viscount spindles and cranks are not tapered and must be kept together.
1) Viscount used 35x17x10 (6003 bearings) press fit in their unique BB shell.
2) Modern sealed cartridge bearing BB (like the Shimano UN55) seem to use 31mm diameter cartridge bearings with those threaded sleeves that fit over the bearings.
3) 31x17x10 cartridge bearings exist (173110-2RS).
If a suitable sleeve could be made to fit between the two cartridge bearings so they wouldn’t migrate inward, would it be possible to press fit the 173110 cartridge bearings to the Viscound spindle, salvage the sleeves from a Shimano and install in a standard BB? (Does that make sense?)
Or is this a fool’s errand and the groovy chainrings should just be fitted to a TA crank arm and forget about it?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Industry guy
The only thing that might work in a threaded version it tapping the bb shell Italian thread as I recall.
The shell itself is a bit thin, so you will only get one shot at this.
That being said, it may be that some type of modern press fit bb will work.
rusty
rusty
Quoted: 3810 Post(s)
Liked 6,688 Times
If your goal is to use the crankset, some report success with taking a file to it and modifying to fit a tapered spindle.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
He's proposing to install a Lambert/Viscount BB into a conventional English/ISO threaded frame.
Not worth the effort, IMO.
Go to any industrial bearing shop and Im sure you can find an exact replacement. replacement is pretty easy with just hand tools.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
The shell has the same 40mm OD as other bottom bracket shells, i.e. it's no thinner than any other BB shell. The reason you only get one shot is because you have to ream the inside of the shell before you cut the Italian threads. Once you've done that, there's no going back. That said, it's a pretty straightforward operation, provided you have the necessary tools.
tantum vehi
Liked 992 Times
Sometimes we climb the hill just because it’s there. Sometimes that molehill becomes a mountain.
Something I didn’t consider is where cartridge actually sits on the Lambert/Viscount spindle compared to where the cartridge sits in a Shimano spindle. The Viscount sits flush with the face of the BB while the Shimano has a threaded sleeve over the cartridge and could be slightly inboard. I’ll have to measure.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
