Crankset For Best Ankle Clearance
Hi!
I bought a Variado 3.0 last year. It has triple tiagra crankset. My problem is my ankles are rubbing against crank arm. I adjusted the cleats for max. clearance but my knees didn' t like it. I have the right arch support so shoe isn' t the problem. I think only way to solve this problem is buying a new crankset. I search for options but didn' t find much. For a price range I can' t buy more expensive than 105. Other question is can I put another crank arm to existing tiagra set. Someone is selling ULTEGRA FC-M6500 crank arm here. Looks like it has good clearance. Can it be fit into tiagra crankset?
Hope you can help.
Thanks.
Hope you can help.
Thanks.
Try lowering your seat by 3mm and see if it works for you. It's possible that your seat is too high and it is pulling your legs to where the ankle is not comfortable.
If you want to switch cranks, I think to get a narrower Q-factor, you need to go to a double. Given your price range, I would try to find a SRAM Rival compact.
Pedal to crank arm clearance is set by pedals, not the crankset. Your only option is pedal extenders. If you're having this issue with your knees in proper alignment, that indicates that you have extremely wide ankles or a really huge swing angle.
Given the overall weirdness of the whole situation, it seems like talking to a fitter is highly recommended in this case.
Quoted: 14 Post(s)
Liked 13 Times
SRAM BB30 cranks have the most clearance in that area that I've seen. The crank arm bends inward at the spindle is only sticks out a few mm beyond the plane of the large ring. This point is wider on cranks for wider BBs.
Thanks.
