Shimano Ultegra 10 spd crankset compatibility with a 7 spd drive train...
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 335 Times
Any of you try a newer Shimano 10 speed compact crankset (Ultegra) paired with a 7 spd Shimano compatible rear? It would be all friction shifting?
I also asked this on my project thread and didn't know if anyone saw the question.
Quoted: 1872 Post(s)
Liked 692 Times
edit: don't forget to Google in the future: https://www.bikeforums.net/bicycle-m...rivetrain.html
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Mechanically, it should work just fine. Aesthetically, they may be incompatible.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 246 Post(s)
Liked 335 Times
Likes For mechanicmatt:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
I think it would work fine. I’ve used a Velo Orange compact crank (I believe designed for 10 speed ) with a 6 speed friction setup without problems. I use 8 speed chains on all my 6 thru 8 speed bikes.
Quoted: 656 Post(s)
Liked 469 Times
I use a Velo Orange compact crank with a 6 speed Shimano 600 Arabesque group and an 8 speed KMC chain. The Velo Orange crankset is 10 spd compatible so it has more narrow spacing between the rings. I bring this up because the front derailleur is pretty finicky when shifting to the big ring. If I shift too fast, the chain will bind mid shift between the rings. Not sure if this is due to the wider 8 speed chain or the Arabesque FD trying to handle the small-to-big walk on the compact crank. I’m using the appropriate VO BB but I suppose the chainline could be a contributor as well.
Bonus data point: The previous crankset was a Dura Ace 7400 7spd crank (not compact). All other parts remained the same (after resizing the chain) and the FD upshifted just fine.
Assuming OP is using a 7spd FD, I’d think there is a chance you might run into a similar issue. Not a show stopper IMO, just need to modulate FD upshift accordingly.
Quoted: 246 Post(s)
Liked 335 Times
Quoted: 246 Post(s)
Liked 335 Times
Quoted: 246 Post(s)
Liked 335 Times
This is what I have to work with.
Everything I have to work with. A nice Campy Strada crank but it may be the only campy components I have. Shimano 600 that I can convert to 52-39 rings. Sugino Impel mtb crankset that have a bcd less than 110bcd, I'd have to scavenge for chainrings for it. Some Bulletproof branded 110bcd crank that I think may be meant for single speed setups, got it extra in a trade. Then the Shimano compact crankset that I'm talking about. Lastly a bunch of chainrings.
Quoted: 246 Post(s)
Liked 335 Times
And it's going on this...
...what would you put on this bike?
Quoted: 246 Post(s)
Liked 335 Times
Thanks Robbietunes. I'll PM later. I only need a crankset. I have plenty of derailleurs long and short, shifters will be Suntour barcons, I may change the levers out to Shimano with cables coming out of the top. I want to build this up for the Cino and I'm just not using the Shimano compact because it doesn't look right. That's a seven speed rear, Sunrace 13-28 that I will be using.
Quoted: 576 Post(s)
Liked 1,002 Times
Similar is this tricolor derailleurs with 8sp XT cassette, 8 sp Shimano chain and 11sp GRX crankset.
Likes For DorkDisk:
Quoted: 246 Post(s)
Liked 335 Times
Perfect! that's the kind of proof i was looking for.
Quoted: 1949 Post(s)
Liked 2,010 Times
mechanicmatt
i couldn't not comment on your workbench. New? Pretty cool.
Likes For Classtime:
Quoted: 5888 Post(s)
Liked 3,471 Times
110 bcd cranks for vintage bikes are fairly inexpensive and easy to find if you are willing to use a 110/74 bcd triple and use only the 2 outer rings.
Likes For bikemig:
Quoted: 246 Post(s)
Liked 335 Times
mechanicmatt
Current state:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
