Removing Top Tube
Removing Top Tube
Working on replacing the top tube on a bike, and am trying to salvage the tube to use on another project. In the past I have not had to preserve the tube as it was damaged anyway, so I cut the tube and was able to pull it out as the joint came to temp. This time I need to keep the tube in tact. Any guidance on this? Can it even be done?
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Assuming that the frame is lugged, I doubt you could without cutting the rest of the frame up.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Randomhead
Liked 3,698 Times
are you salvaging anything else?
Quoted: 4205 Post(s)
Liked 3,864 Times
Consider cutting through the HT just below the upper lug. Then heat and pull the TT from the ST lug.
This is not what I would want to do though as pulling a tube from a lug is ripe for a few problems that make the repairs get more involved or less nice looking. (metal likes to do weird things when it gets to filler melting temps. Lug tips break off, tubes tear, the heat level is hard to maintain evenly so usually there's a way too hot area and almost but not quite to temp area).
For the cost of a new TT I would suggest not saving the old one. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,698 Times
steel gets really weak at temperatures well below the melting point of fillers. I was a bit surprised at that, The conclusion I draw from this is you don't want to put much force on a tube when removing it from a lug.
When I removed the bb shell from a frame recently, I was pretty careful to not push on the tubing very hard. And I cut everything up except the tubing I was saving. I think you need a lot of heat to do this, as in multiple torches or firebricks and a gas burner.
There used to be some pages on a repair done by Yellow Jersey in Madison Wi. I would go look for that.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
…and make sure the joints are not pinned before trying to pull them apart!
