Replacing mech disc brakes with hydraulic?
Quoted: 6963 Post(s)
Liked 10,962 Times
Quoted: 1872 Post(s)
Liked 692 Times
Agreed. I also think the whole "disc brakes will rip the wheel out of the dropout" is completely over-inflated too.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Thread Killer
Quoted: 3137 Post(s)
Liked 1,704 Times
Liked 10,962 Times
Thread Killer
Liked 1,704 Times
The problem of disc brake alignment with quick release wheels, which is caused both by the variability of wheel location and by insecure wheel retention, is a strong argument for thru-axle design.
Sunshine
Quoted: 10960 Post(s)
Liked 7,487 Times
^ nickname checks out.
Thread Killer
Liked 1,704 Times
Sunshine
Liked 7,487 Times
Liked 10,962 Times
Thread Killer
Liked 1,704 Times
Liked 692 Times
Welp, once again, I just spent the last few days building up, working on, riding, adjusting, tinkering with my 2019 CAADX with a dreaded QR rear. Nothing bad happened, the disc didn't even rub once. *shrug*
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Bikes: TCX & CAAD3 SAECO
Quoted: 147 Post(s)
Liked 118 Times
When I purchased a new bike I only went hydro SRAM for the hoods. Those beautiful big SRAM hydro hoods..
As far as maintenance, I wish I had mechanical. As a beginner mechanic, it seems to be more manageable. Maybe I'm wrong.
Liked 692 Times
You're definitely not wrong. I'm not a beginner mechanic but I don't mess with hydro stuff. I always thought I would need to when I got my first hydro setup but time has proven otherwise. With a good shop in town, and only needing them once or twice a year, it just makes sense for them to do the work. If I didn't have them I'd have to learn how to do it for myself though.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 10,962 Times
If the wheels did not spontaneously fly off of the bike and cause a catastrophic crash, you are clearly doing it wrong.
Likes For Koyote:
I also concur that converting a drop-bar drive train from cable to hydraulic disc brakes is expensive and complex, especially with brifters. Including because the cable fittings might not be designed for hydraulic hose. TRP Spyre are moderately priced and work well, Paul Klamper are expensive, pretty, MUSA, and also work well. Both are easy to set up and maintain.
Likes For mack_turtle:
Quoted: 52 Post(s)
Liked 5 Times
Learned a lot on this thread and I found a bike with hydraulic brakes that I think I want to buy (used). Now my worry is that it is a QR set-up, and I had no idea that could be a bigger issue. Its 5 year old bike, carbon, awesome components, and pretty much pristine - but its got the QR. hmmmmm.......... Do I keep looking?
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
Quoted: 324 Post(s)
Liked 251 Times
it's not an issue. someone on this forum ignorantly made a big stink about it recently and now it's an inside joke. ("disc brakes and QR skewers are a SCAM!") thru axles and disc brakes are probably better, but wheels with QR skewers works just fine. it's probably a good idea to get a strong QR skewer if you're using disc brakes, but it should never be a deal-breaker. my last CX bike had QR skewers and hydraulic disc brakes and I never thought twice about it.
Thread Killer
Liked 1,704 Times
Yeah, I agree it’s not an issue and not a deal breaker. As I said before, I have both cable and hydro, and the cable discs are on qr hubs while the hydros on thru axle. Actually, I had hydros on qrs with the MountainCycle...Shimano Hone brakes. Anyhoo, while the hydro/thru combo is a little easier and less fussy with regard to wheel removal and installation, I’ve never had a problem with qrs coming loose while riding or braking. I’ve been riding the cable disc, QR equipped Novara Buzz for 15 years, three different wheelsets with either Shimano or no-brand internal cam skewers or external cam Ritchey skewers, and it’s my utility/winter bike, so it has pulled axle mount trailers and seen all the worst weather. QRs and discs were never a problem.
Quoted: 680 Post(s)
Liked 948 Times
after reading here Now I know why my two e bikes with hydro's get loose qr's. my e bike has front and back and both have come loose. I really crank them down and it seems that works. my e tandem has a through axel on back I can't remember if it came loose but the front is qr and it has.
Thread Killer
Liked 1,704 Times
Thread Killer
Liked 1,704 Times
Ah, sorry for being presumptuous. In any case, the failure of the QR to secure the wheel is a QR problem, not a brake problem. Perhaps what you think is really tightening them down hard is actually just right, and you were undertightening them before? If you are indeed closing them with a lot of force, it’s possible they have been overtightened, and you’ve got deformation of the pieces going on, which reduces clamping force.
Quoted: 680 Post(s)
Liked 948 Times
