Does road bike weight really matter?
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
So I know a lot of people are concerned with bike weight, and I was curious how much it matters, what the increase in speed actually equates to, and so on.
I know my bike for example is rated as sub-18 lbs, however, fully loaded with all its gear and such it's 24 lbs (water is heavy, plus the 2 25oz bottles themselves, cages, bike computer, bike bag with spare tube, CO2 inflator and 16g CO2 cartridge, tire levers, bike multitool, phone in the bag, keys for house, etc).
Myself, I'm 174 lbs. Even taking my weight into account, is there some formula that says x amount of weight loss yields more speed (or rather, less power required for same threshold)?
Just curious if an 18 lb bike is theoretically really much faster than a 22 lb bike. Is a 15lb bike that much faster than an 18lb bike. etc
Quoted: 5774 Post(s)
Liked 2,571 Times
There's always been debate about how much weight matters. Many do as you do, and consider the percentage difference in total weight, but that only relates to a small part of the story.
At constant speed on level ground, weight doesn't matter (in theory) because all the work is being done to overcome wind drag. In climbing, most of the work is done lifting the total weight, so in theory 5% more weight needs 5% more strength, or a 5% lower gear.
But, as I said, that's only a part of the story. Theory is fine, but bicycles are not like theoretical wheeled vehicles. The bike doesn't move at uniform speed, but instead is constantly being accelerated in small (tiny) bursts with every pedal stoke, and slowing down in between. By the same token, we constantly rock the bike side to side when riding and that also takes a bit of work. How much work this involved is hard for me to say, but anyone who has ridden light and heavy bikes knows how different they feel. That difference is reflected in total effort, speed and times on longer rides.
To get a sense of what I'm describing, buy a 10# sack of potatoes, and attach them to the bike or carry them in a back pack. Go ride, including some hills, and you'll see that that 5% weight difference makes much more than a 5% difference.
That said, there is a point of diminishing returns, so at some point the differences in bike weight will (seem to) matter less, and other factors like feel and comfort may matter more.
FB
Chain-L site
FB
Chain-L site
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,243 Times
For me it was in the gears.
Compact Double for acceleration.
Top Speed my Triple was Best.
Fred "The Real Fred"
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
It doesn't really matter on a flat road with a steady effort. Speed on a flat course is a function of power over frontal area; speed on a climb is a function of power over weight.
But lighter bikes accelerate and turn quicker under the same power, which may mean the difference between getting dropped or hanging on, or the difference between coming around in a sprint or bogging down. So even for crits or flat RR's, racers want a light bike.
This is a nifty little tool: Bike Calculator
Based on my amateurish understanding of physics...everything it calculates seems reasonably accurate.
Long story short if you want to avoid a few days of research and/or going back and forth on the forums: effect on speed both on flats and hills is measurable. It's probably measurable, but functionally negligible on flats unless you are literally a pro racer, assuming we're talking a few pounds and not 50+. On hills it makes a bigger difference. Will 5 lbs make a big difference on a hill? The bike calculator says 5lbs will make a difference of ~0.2mph on a 5% grade, which sounds about right to me. The calculator says the change in speed is about half that on flats.
As a test: leave your 2 water bottles, keys and phone at home for a ride. That's ~5lbs.
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
Is all always about bike weight and not so much total weight?
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
Quoted: 18883 Post(s)
Liked 10,646 Times
In Florida, no. In the North Cascades, yes.
Weight on the bike that doesn't move/turn on the bike relative to the bike works exactly the same way as your body weight. Examples: frame, cables, housing, brakes, etc.
Wheels and drivetrain parts - these essentially count double for weight. You have to overcome inertia to move their weight forward along with the rest of the bike, but you ALSO have to overcome their rotational inertia. This will be most pronounced in the wheels as they obviously turn the fastest, but the effect will also present itself in the cranks, chain, cassette, etc.
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
P.S. you should probably know I don't actually own a road bike, but the science behind them fascinates me lol
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
Yes and no.
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
Liked 10,646 Times
It's very similar. There are some subtle differences in the real world. But there are a lot of variables, too.
It's easier to carry a 15 pound bike up the stairs or out to your car than a 20 pound one. In some situations, it's easier to move it under you, like when you go to extremes to avoid a pothole.
Losing weight is hard (that's why it's a multi-billion dollar industry) and often impermanent; your bike will never gain 5 pounds back after binging. Losing weight tends to improve peoples' health, but it means some amount of muscle loss.
5 pounds is a pretty small difference and we're kind of majoring in the minors here.
Yup. Oh, I meant to add that the difference between the static and rotating parts only presents itself when accelerating. Zero difference at a steady speed. You can have a 1lb bike and 199 pound you, or 150 you and 50 lb bike with 30lb wheels and it won't make any difference at all if you're already at speed.
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
5 pounds was kind of my focus though, as the price difference between bikes that weigh 5 lbs less than others is quite significant. 20lb bikes are common. 15lb bikes cost LOTS more typically.
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
Quoted: 63 Post(s)
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
Very true. Coincidentally, today, I met my weight loss goal, LoseIt badge and all haha (was 207 and today I'm 174). I'm sure I lost some muscle which is an unfortunately part of weight loss.
Quoted: 4802 Post(s)
Liked 3,923 Times
But as said above (curse this forum format; that when I answer a post I don't see the thread so I have to take notes in advance or open another tab. I cannot remember who said this (calso???)) light wheel and bikes mean that in a race you might just make it onto that wheel and a little heavier almost make it. The difference between making it and almost can be 10 minutes. I rode the race of my life on very light wheels and tires. The pace was record breaking fast. I was the last to make the cut on the climb 15 miles from the finish. Beat the guy who fell off my wheel by that 10 minutes. Dropped my chain on each of the next two hills, using everything I had to get back on. Finished with that group, same time, under the old course record and in the money. No way that would have happened on heavier wheels. No way. There was no extra reserve to draw from. (And it took me two full days just to come back into my body. Good thing I worked for our club's sponsoring bike shop. I was paid two full days for being useless.(
I saved those really light wheels for the big races. If I had ridden them for say one of my really long solo training rides that summer (up to 175 miles), they might have made that 10 minute difference, maybe, but that would have been almost entirely because they were a lot nicer rolling tires than my training tires. (10 minutes on a 14 hour day. Big deal!)
Ben
Liked 10,646 Times
If you don't spend most of your miles going up or down hill, then the 5 pounds aren't worth paying an extra $1,500 for. But whenever you compare two bikes, there are differences beyond the weight. The 15 pound bike will be nicer than the 20 pounder in a lot of ways that aren't really related to weight. Better shifting, etc.
Bikes: Guru Evolo-R
Quoted: 92 Post(s)
