Sad state Peugeot; Anything salvageable?
Quoted: 84 Post(s)
Liked 5 Times
Found this sadly dishonored junkyard Peugeot and felt compelled to give its' last respects here where might be appreciated for what it once was. Appears to be an early 80's, and some of the details makes me wonder if this was a higher end "P" model? Anyway, I'd lover to hear any comments , guesses of the model, and suggestions of what to do with it. Is anything salvageable? It's been fun just reading and researching Peugeot.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Sure, crankset and stem are both sellable, as is bottom bracket if it is OK. Of course, it has stuck stem written all over it. Saddle may be sellable too (low price). Some people rebuild them. Seat post may be stuck too, if not, put in your parts bin or donate. I'd save the shift levers too.
You will probably have to cut out the stripped dust caps.
Since I keep a rust bath going for small parts, I'd save the headset too.
Rescuing those parts will not only bring you some $$, but you will be helping someone out with their bike restoration. Parts live on to provide value to others. Win/win.
Got to love the knot on the end of the shift cable......
Thrifty Bill
Liked 964 Times
Reference point, I got over $200 out of parts on this old UO8 with a large crack on the steer tube. Still have the early Mafac brakes which have value too. I bought it mainly for the non-original Belt leather saddle, which is now on my Sekai Professional 4000.
Bike was in the scrap pile when I found it.
1963 Peugeot UO8 by wrk101, on Flickr
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
Looks restoreable to me - But you're certainly looking at a repaint - And a fair bit of parts scrounging
That's IF you can get it all apart OK - Stem, seatpost, etc.
The chrome socks will clean up pretty nicely with an oxalic acid bath ...........
Quoted: 823 Post(s)
Liked 1,395 Times
What size is the frame and where are you located?
Quoted: 809 Post(s)
Liked 1,022 Times
I have never seen the front brake adjuster used in the back like this. Clever, if you are absolutely in a pinch. But not clever if you have any time to source the right part. If the seat post and stem come out, the frame doesn't look too bad if you are up for painting it or selling it.
Quoted: 3810 Post(s)
Liked 3,336 Times
Appears as if it may have begun life as a manner of PFN10.
1980 U.S. market brochure page -
The machine's stamped steel pedals appear below the balance of the cycle. They look to be replacements. Specification is Atom 440.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The saddle is missing the shackle clip and bolt, but you can get those from Niagara cycle supply and other vendors. I'm not sure anyone would be able to get the replacement bolt back into the saddle without further damage to the leather, though. Pretty easy to put new leather on the frame, of course.
Is the frame bent? It looks like the bike had a head-on crash that bent the fork and cracked the frame paint at the usual spot, but I don't see frame damage.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 796 Post(s)
Liked 522 Times
Oh come on most of that will buff right out....seriously not beyond salvation but it would need a lot of work, probably best to salvage what you can unless its a great fit and you have the desire to bring it back from the scrap heap
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
+1. And I'd be tempted to see if I could save that frame set if it were my size. Peugeots of that era tend to be rather nice.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Pfn10 ?
I was going to call PSV-10 or something like that, with a replacement fork
The fork crown threw me. I thought that it was a replacement from the early 70's until you posted the picture.
Worth stripping and cleaning up. It's on a par with the older PR-10 models. Vitus 172 butted main tubes, same wall thicknesses as Reynolds 531 used on most production bikes: 1.0mm x 0.7mm. About the same after brazing strength too.
@rhm on closer examination, the fork is bent at the base of the steerer and maybe the crown too. The frame looks OK.
Steerer should be replaced if the crown is OK because Peogeot (and Motobecane) used cheap straight gage tubes with a split sleeve brazed into the bottom for reinforcement. Wouldn't recommend straightening it.
verktyg
Chas. ;-)
Chas. ;-)
incazzare.
Fork looks bent.
I'd at least make an attempt at saving that frame. I bet you can do it.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
incazzare.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Quoted: 84 Post(s)
Liked 5 Times
Wow, thanks for all the feedback, you guys are inspiring! Yes, fork is bent (too bad because that crown is too cool) & there's a rust hole on non-drive stay. Frame & head tube doesn't appear to be bent but I'll know more as I proceed. Non-drive crank inside square is rounded so that's toast. Somebody drilled and screwed a bolt to try holding it to the BB, lol.
I'm going to use this as a learning experience and relive my youth. Had a couple decent race bikes in my younger days, collected dust, took up too much space, gave them away to a young kid who shown appreciation for what they were. And here I am now full circle looking to put together an old lightweight steel machine to ride again.
So far, took the bars off, pulled the cranks and bb came out no problem packed full of grease inside. Started chipping off the respray paint to reveal the cool original blue color trying to see of the PEUGEOT lettering was left on. We'll see. It'll be fun!
Again, thanks for the feedback!
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
Hmm - That doesn't look too good
If it were me (and it ain't), and I REALLY wanted that frame, I might strip it, soak a day or 3 in oxalic to remove the rest of the rust, and then braze a little patch over that, IF the stay proved not to be too weakened by internal rust.
I'm sure others might have a different opinion, as in - Fuggedaboutit , and move on .............
OTOH - Now that I look closer - Are you sure it was rust?
It looks like there might have been a severe tire rubbing issue there - Enough to wear though the stay ?
