Torque value for clamp-on DT shifters
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,376 Times
I'm installing some clamp-on DT shifters, but I'm worried about crunching the tubing. Couldn't find a torque value anywhere.
Quoted: 3350 Post(s)
Liked 3,614 Times
In all seriousness, I wouldn't worry about it. Round tubes are incredibly strong in compression radially. Assuming you are using shifters with a steel band clamp and small screw/nut combo to secure them, I highly doubt you would be able to generate enough force to damage the tubing.
If you're still concerned, I would install them lightly, and progressively tighten them to the point that the shifters don't move around when you're operating them.
Likes For abshipp:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,458 Times
Use a 5/16" socket driver and you don't have to worry about torquing it too much. Do the same with all your anchor bolts.
I would think that the band would break or deform before the tubing
Be where your feet are.......Lisa Bluder
A more important question is whether or not there is a brazed on stop for it. If not, those things do tend to slip.
Nobody torque spec'd stuff like that BITD. I'd say typically it'd be around 5-7 ft/lb, about like a front derailleur, maybe a bit more.
Quoted: 985 Post(s)
Liked 2,376 Times
Thanks for the replies. Found some info on Park tools site. https://www.parktool.com/assets/img/...elp/torque.pdf
they suggest 44-60 in/lb for Shimano clamp-on front derailleurs, which should be close
Likes For rootboy:
Bikes: many
Quoted: 1441 Post(s)
Liked 1,386 Times
I suspect the only exception would be the Huret Jubilee front derailleur, whose clamp was extremely thin and fragile. In that situation, I think you'd iterate. Tighten just enough to hold in place, cable it up, see if it spins under load. If so, tighten it a bit more. Lather, rinse repeat until it holds while shifting.
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
aged to perfection
Quoted: 829 Post(s)
Liked 1,241 Times
Are you familiar with the concept of "running torque" ? Just clean the pinch bolt, put a dab of grease on it, and tighten until the running torque starts to increase in a non linear manner. Go just a tiny bit more - like 1/4 turn - and you're done.
BITD there were no torque specs on stuff like this. Learn to develop a feel for how tight is tight enough.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Quoted: 985 Post(s)
Liked 2,376 Times
Mark Petry
Mark Petry
While learning the concept of "running torque" I snapped the head off a screw.
This earned me a trip to the machining building where I had to ask "Green Head Ted" and "Five Eye Bob" to remove it for me. I was 23 and Ted and Bob were 5000 years old.
This experience cured me from using the "calibrated wrist".
aged to perfection
Quoted: 829 Post(s)
Liked 1,241 Times
well, it cured you ! kind of like BMW head bolts which are torqued by degree - tighten to xx torque and then 90 degrees from there.
many failed, resulting in blown head gaskets.
I do think the running torque technique applies for clamp band shifters, since you are tensioning the band around the tube - before the bolt is put into tension. Very difficult to come up with a torque recommendation in this application.
I don't think I've ever stripped a bolt ! I have developed a good feel for when a fastener is pulling up and for how much is enough.
Mark Petry
Mark Petry
