Online Vendors - Bikeman.com? / Valve size question
Bikes: 2018 Fuji Absolute, Yokota mountain bike (199?), 1979 Schwinn Le Tour Mixte
Quoted: 82 Post(s)
Liked 34 Times
I need to buy some tubes and found the kind I'm looking for at Bikeman.com - has anyone had experience with this vendor before and how was it? I did a search on this forum and surprisingly there didn't seem to be much about this vendor recently - the most recent thread I found was from 2011.
For some reason I'm having a lot of trouble finding thorn resistant tubes for a schrader valve that are 700x28-32 but Bikeman has them. Also, any other suggestions for online vendors?
And one other somewhat related question - when I had a flat recently on my hybrid, my LBS were out of the schrader valve tubes so they used presta ones. I didn't think much of this at the time but I later talked to one of the mechanics over the phone and mentioned this and he said technically it could cause some issues but it's very unlikely - does anyone know if using a presta valve in a rim that is meant for a schrader valve is a big deal? Should I be concerned this could cause a flat or other issue? I assume these guys know what they're doing since the bike shop mechanics were the ones who decided using a different sized valve made sense to do, but him saying it could technically be an issue has me worried.
Quoted: 4259 Post(s)
Liked 1,361 Times
https://www.google.com/search?client=tablet-android-google&ei=CnJpXeq2JKGp5wKR7pr4Cw&q=schrader+to+presta+rim+adapter&oq=presta+schrader+adapter&gs_l=mo bile-gws-wiz-serp.1.0.0i71l5.0.0..17368...0.1..0.0.0.......0.CwwC1EGYYkI
Bikeman.com should be fine to use.
Quoted: 82 Post(s)
Liked 34 Times
With a rim adapter, it shouldn't be any issue at all.
https://www.google.com/search?client....0.CwwC1EGYYkI
Liked 1,361 Times
Thanks! The mechanic I talked to said they didn't do anything special so I'm guessing they didn't use an adapter. I hope this doesn't mean I'll have an issue, but I wonder how can they be doing this kind of thing on a regular basis and not have repeat complaints from customers. I hope it isn't an issue.
A presta tube might squeeze into the bigger Schrader hole and wear-through the tube. (This can happen with presta tubes in presta holes.)
The adapters fill-in the bigger Schrader hole.
I wouldn't have an issue using an adapter.
If you are using a pump without a hose to fill presta valves, be careful to not snap the valve stem. Wrap your finger/hand around the tire and pump head. And pump slowly and firmly (don't pump fast or throw your body into it).
(I wouldn't have a problem buying from bikeman.com either.)
Likes For njkayaker:
Quoted: 82 Post(s)
Liked 34 Times
I doubt they used an adapter. Of course, we are talking about your wheel, which means you could check! It might save you $3!
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Likes For JonathanGennick:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Likes For Marcus_Ti:
