front canti brake sqeal
Quoted: 722 Post(s)
Liked 353 Times
cantis on front make horrible sqealing noise.
what is fix.
pads relatively new.
just switched out wheels.
what is fix.
Quoted: 1439 Post(s)
Liked 1,094 Times
Use a fork crown-mounted cable stop to remove the root cause of canti brake squeal/shudder.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Normally, brake pad toe-in is the solution to this.
Likes For Phil_gretz:
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
Lots of good points here.
Pad toe-in is key. Additionally, pay attention to make sure the pivot-to-pad distances are as identical as possible so both arms are equidistant to the rim and the face of the pads are the hitting the rim at the same angle.
New pads on new rims can be really grabby and will get better as they wear-in in my experience.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
When I got new wheels for my CX bike, the cantilever brakes squealed and shuddered. I changed out Kool Stop black and salmon for Red Kool Stops, and the problem was solved. Red are softer, I believe.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Last tip!
Sometimes the pads can pick up a lot of new particles on new rims, or get contaminated by grease or lubes (it doesn't take much). Once you're done fiddling with pad setup, grab some isopropyl alcohol and wipe the pads' braking surface and the brake track to pull off any grease and brake dust.
Quoted: 722 Post(s)
Liked 353 Times
Last tip!
thank you.
this is what i have
Likes For thehammerdog:
The dropped
Liked 1,014 Times
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Just to throw something else into the mix, check your wheel bearings. You mentioned new wheels, if these are factory new you’re probably fine. If these are new-to-you used wheels I’d check them. I’ve made brake squeal go away by correcting loose hub bearings several times.
